Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Dec 26, 2021 at 4:57 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Three days of driving in the snow and on my last site check of the weekend, a grader comes up the hill as I am driving back to my trailer. But, I won't complain too much, the 1-2.5 feet of snow on the road(depending on which fsr you come in on) kept it a quiet weekend with only a few people out and about.
    Willy-N likes this.
  2. Dec 27, 2021 at 6:44 PM
    Bobert14
    Bobert14 [OP] .
    Hwy 26 is an ice rink, but worth putting up with the idiots
  3. Dec 29, 2021 at 1:52 PM
    tcjacado
    tcjacado Well-Known Member
  4. Dec 29, 2021 at 2:05 PM
    BLT2GO
    BLT2GO Well-Known Member
    2011 White Tacoma TRD TX
    tcjacado[QUOTED] likes this.
  5. Dec 29, 2021 at 2:11 PM
    tcjacado
    I saw, and advised he change the thread title.
    Just asking, spreading the word a brother is kinda stranded.... looking for a little help.
    Steves104x4 likes this.
  6. Dec 30, 2021 at 4:43 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Anyone have a recommendation for a decent paint/body shop, or even shade tree who does paint?
    There was an acid leak in the engine bay that ate up some stuff pretty bad and I don't have a garage so doing the work myself isn't an option until after winter.
    This is a basically brand new truck so I'd like to get it fixed (right) sooner rather than later.
    More info: https://www.tacomaworld.com/threads/the-ugly-blue-truck.722492/page-2#post-26659229
  7. Jan 4, 2022 at 3:18 PM
    MattP.
    MattP. Member
    Looking for a WA individual or shop recommendations for a consistent water leak in my 2020.
    It's coming down in the passenger foot well, where the passenger would have their right foot, down along the A-pillar presumably. I don't believe it's the fresh air intake as the cabin air filter is consistently dry. It occurs during every rain. Michaels Toyota was no help; after paying an egregious diagnostic fee I was told "try resealing the roof rack." The rack is a Prinsu Cab Rack that has been on the truck for about 19 months. The leak started in November after parking the truck directly under a shedding tree for 2 weeks. I assume it's either a clogged drain hole under the windshield cowl or a bad seal on the Prinsu. The tree makes me think its a clogged drain hole but I did have one day in September where I had a leak at the passenger B pillar during a torrential downpour; that makes me think its the rack seal.
    So looking for some professional help to address this once and for all. Happy to pay fair rates and travel if needed. Located in Issaquah.
  8. Jan 4, 2022 at 3:32 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Do you have a sunroof? My vote is clogged sunroof drain.
  9. Jan 4, 2022 at 4:48 PM
    gpdx
    gpdx Well-Known Member
    Portland
    13 DCSB TRD Offroad
    5100/887, topper, rack, 265/75/16
    My father in law just had this happen on his 3rd gen. It ended up being something with the passenger door weather stripping. He explained it a little over the holidays, but I didn’t quite catch all of the solution. He took it to a portland area shop (which doesn’t help you) but the shop said they had seen this quite a few times now. Maybe it’s common enough that other shops will have a solution.
  10. Jan 4, 2022 at 5:03 PM
    MattP.
    MattP. Member
    I think you may be right. I just spent a while pouring water in discrete places. Sunroof drains fine, couldn't get the leak to appear while pouring water at the roof rack mounts. But this was all done with the passenger door open. I then closed the door, poured water over the weather stripping and the leak appeared.
    Any chance you could get more details from your FIL? Or maybe just the Portland shop he went to? I'm in Portland enough that I would love to give that shop a call.
    Thanks!
  11. Jan 6, 2022 at 8:13 AM
    NWTacoTime
    NWTacoTime Well-Known Member
    Nate
    WA - Seattle/Kent
    Cement SB 2019 TRD offroad -
    Car Seats
    Honestly i had this exact problem (water coming down the passenger A Frame and pooling below the floor mats, and it was due to the Prinsu cab rack not being properly sealed correctly. I'm surprised though that MIchaels was no help, i had gotten mine installed there years ago and took it in to them and they diagnosed and repaired for me.
  12. Jan 6, 2022 at 9:08 AM
    danadavenport
    danadavenport Well-Known Member
    2021 SR5 DCLB
    I posted this in the other thread but it looks like it pretty dead. Lots of talk on the kd max tune but not so much on the OTT. Does anyone here run the OTT tune?
    I got the OTT tune about 3 weeks ago and here are my thoughts. Throttle response is night and day better. MPG is down about 1.5 mpg but Im guessing that is because of colder weather. The trucks doesnt go into 6th gear unless im doing like 75 on a flat road with a tail wind. It seems that it holds onto the gears just a tad longer than it should.
    Does this sound right? My tuner here is great and offered to do it again or install another one if I wanted.
  13. Jan 6, 2022 at 9:38 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    If your tuner has unlocked files that they can manipulate they should be able to correct for any changes to suit your needs. If they are just flashing a locked tune from someone else then you are at the mercy of the tuner on the other end. I haven't driven on any of the N/A tunes but the amount we have tweaked and changed on the Magnuson replacement tune from Yotawerx has been pretty amazing.
  14. Jan 6, 2022 at 12:51 PM
    gpdx
    Portland
    13 DCSB TRD Offroad
    He went to this shop. https://libertywaterseal.com/
    It’s a one guy operation so can take a couple days to return calls sometimes.
    Sounds like the guy added extra weather stripping, or beefed up the existing weather stripping. I haven’t seen the work to say exactly what was done. I hope that helps!
  15. Jan 6, 2022 at 5:28 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Do you have a sliding rear window? Grab yourself a fan and put it against the window, seal around it so it positively pressures the cab. Grab a bunch of soapy water and spray down every possible spot like the roof rack, window seals,door seals, ETC… I’d also spray down the engine bay side of the firewall where you can.
    I’ve done had to do this on school busses a lot. Roof emergency exits are a constant source of leaks
  16. Jan 7, 2022 at 1:45 PM
    danadavenport
    2021 SR5 DCLB
    Anyone know of a good wrap shop in Portland Vancouver area?
  17. Jan 7, 2022 at 2:50 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Well one differential is in.
    well they are both done, got caught in the act by one of the tech’s. Now the long break in.
  18. Jan 12, 2022 at 7:03 AM
    jsackspot
    jsackspot Well-Known Member
    Getting 5.29 in after the 3 year warranty expires (or earlier?) in the coming November timeframe. Looking at Paden in Portland; after browsing the 5.29 thread, are there any specific details we need to bring to them that addresses nuances (bearing sleeve? Spacer?) or will they know how to manage this?
    Also, will they have the gearing in stock or are we expected to get the parts? Clearly, I’ll call, but currently on a trip and get some info in advance. Thanks!
  19. Jan 12, 2022 at 7:56 AM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    I've called them a few months ago and they were having trouble getting parts, and I would suggest asking them if they use the master install kits or mini kits. Since I'm in the Seattle area and reading thru some install issues, I chose not to risk it by using Padens.
  20. Jan 12, 2022 at 8:05 AM
    danadavenport
    2021 SR5 DCLB
    I also posted on the PNW tacoma facebook page an a bunch of people suggested pdx wraps. Another person DM'd me saying he has been doing wraps for 15, sent me a bunch of photos of his work. He said that he works as a subcontractor for a bunch of wrap companies in the area. Seems super nice an knowledgeable but no real info about him online. So against my better judgement I venmoed him a deposit and have $1500 worth of wrap material coming this week. Follow along for more questionable life choices from me.
