Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Oct 17, 2011 at 2:39 PM
    #4541
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I should mention that I have an ARB strap and I'm not really worried
  2. Oct 17, 2011 at 3:31 PM
    #4542
    Chickenmunga
    Keizer, Oregon
  3. Oct 17, 2011 at 3:45 PM
    #4543
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    What? HOW!!?! You're the one not going anymore.
    Gotcha! Well my brother in law says he has a strap I can have/use so I will hold out for now and as far as the deflators..yeah I've read customer reviews on Amazon and some mention how the preset is not accurate. Found some cheap-o's..not sure if they're worth a shot or not..
    http://www.amazon.com/Quick-Air-Tir...2PNK/ref=sr_1_2?ie=UTF8&qid=1318874228&sr=8-2
    Not sure if it's the right word/terminology but maybe its the wheel bearings(???) :confused: I hope you get it figured out soon..going to be interesting to see what Toyota charges you just to "take a look at it".
  4. Oct 17, 2011 at 4:16 PM
    #4544
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I'm guessing at least $90. That's what the dealership by my house in San Diego charged for their "inspection fee". :rolleyes:
  5. Oct 17, 2011 at 4:22 PM
    #4545
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    Mike, check your wheel studs.
  6. Oct 17, 2011 at 6:21 PM
    #4546
    snowgod06
    Rob
    06 Access Cab
    What you guys think of the new '12 front ends?
  7. Oct 17, 2011 at 7:07 PM
    #4547
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Meh. The front end itself is fine, but I hate the way the fender flares get all.....weird.
  8. Oct 17, 2011 at 7:58 PM
    #4548
    Chickenmunga
    Keizer, Oregon
    I re-torqued this evening, ~slightly~ loose but no issues. Are you thinking the studs themselves are somehow busted?
  9. Oct 17, 2011 at 8:01 PM
    #4549
    snowgod06
    Rob
    06 Access Cab
    It was just an idea. Because I can't really think of what it could be from the items you checked.
  10. Oct 17, 2011 at 8:09 PM
    #4550
    Chickenmunga
    Keizer, Oregon
    worth a guess. It did get me thinking and I tried to rock the passenger tire back and forth at the 12:00 position. If I get rocking it like a mofo I can ~maybe hear a slight tap...
  11. Oct 17, 2011 at 8:15 PM
    #4551
    snowgod06
    Rob
    06 Access Cab
    With your truck at full lock, can you see anything binding? Or rubbing?
  12. Oct 17, 2011 at 8:45 PM
    #4552
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Beer... Or more homework...
  13. Oct 17, 2011 at 8:50 PM
    #4553
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Beer! I mean.....Capri Sun. :)
  14. Oct 17, 2011 at 9:00 PM
    #4554
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Mike, I know you've already considered this, but are you certain the front diff is not engaged? It sure sounds like it might be.
    If you lift one front wheel off the ground, does it spin freely? Does the front drive shaft rotate when you spin the wheel?
  15. Oct 17, 2011 at 9:02 PM
    #4555
    KalamaKid
    Oregon
    This!
  16. Oct 17, 2011 at 9:44 PM
    #4556
    Chickenmunga
    Keizer, Oregon
    I can't make it happen at full lock, I have to be a few degrees before that.
    How the heck do I do that? Do you mean if I lift the front and try spinning the wheel by hand? Or did you mean put it all up on blocks? I'm not educated enough on how to remove the driveline, otherwise I'd see if it went forward with the selector on 2WD.
    I only have a hi lift at the moment and there's nothing creative around to use as jack stands. I absolutely hate apartment life.
  17. Oct 17, 2011 at 9:58 PM
    #4557
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah,I was thinking a floor jack under one of the lower A arms to lift the tire off the ground, then spin the wheel. Maybe the stock bottle jack instead, strategically placed?
    If the front diff is still engaged, that front wheel will not spin freely.
  18. Oct 17, 2011 at 10:21 PM
    #4558
    KalamaKid
    Oregon
    I'd love to rock that sticker but I don't want to suffer the wrath of the ASS-HAT that might not like it so much...
  19. Oct 17, 2011 at 10:34 PM
    #4559
    Chickenmunga
    Keizer, Oregon
    Read my latest in the other thread. Should be informative. At least my diff isn't engaged.
  20. Oct 18, 2011 at 9:34 PM
    #4560
    KalamaKid
    Oregon
    So which one of you guys said your father works for the ASA company that makes FAA test prep software for A&P licenses? I have all the 2012 books but I'm looking for some computerized study tools... I'm searching this thread with no luck...
    EDIT:
    Found it :D
