Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Feb 7, 2012 at 11:35 AM
    #7161
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    Do you have any pictures of your engine bay? I'm mainly interested in the intake area. From the pictures I've seen it looks like your MAF sensor is located on the lid of the intake box which could be a problem.
  2. Feb 7, 2012 at 11:37 AM
    #7162
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'll post up some engine bay pictures after i get out of class
  3. Feb 7, 2012 at 12:37 PM
    #7163
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    My maf is built in to my air box lid can you post some pictures of your engine bay maybe I can move my maf to make it work
  4. Feb 7, 2012 at 12:45 PM
    #7164
    all.on.black
    Auburn, WA
    The 4.0 MAF is attached to the air box which is attached to the engine and the breather tube comes out from that. On the 4.0 you can just cut the tube and attach the snorkel to that. On your truck you'd need to add a tube that has a MAF holder built into it.
  5. Feb 7, 2012 at 4:05 PM
    #7165
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    that's easy enough to do a little fiberglass and a maf holder should do the trick
  6. Feb 7, 2012 at 4:07 PM
    #7166
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  7. Feb 7, 2012 at 4:15 PM
    #7167
    all.on.black
    Auburn, WA
    Depending on how badly you want the snorkel, you could dremel out the factory MAF retainer, glue it to some PVC pipe, and connect the snorkel to your air inlet tube.
  8. Feb 7, 2012 at 4:17 PM
    #7168
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Do it.
  9. Feb 7, 2012 at 4:19 PM
    #7169
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    do you have any engine bay pictures?
    I have no problem moving or machining out a plate to make this work i got some fiberglass skills i could use too to fab up a pipe and a holder so the MAF is centered in the tube
  10. Feb 7, 2012 at 4:47 PM
    #7170
    all.on.black
    Auburn, WA
  11. Feb 7, 2012 at 4:50 PM
    #7171
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    It looks like i can just use the tube from the fender to my air box and be good to go i may need to make something to seal up any gaps but other than that the hole is in the same place on my truck.
  12. Feb 7, 2012 at 5:06 PM
    #7172
    all.on.black
    Auburn, WA
    I completely spaced out on this. For some reason I forgot that you need the filter element and will need to keep the stock air filter. If you have a tube that comes out from the air box and goes into that hole then yes you can just use a coupler and connect the snorkel to the tube and be done.
  13. Feb 7, 2012 at 5:12 PM
    #7173
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    that's exactly how it's set up already so just get a coupler and I'm done.
    when do you want to do this?
  14. Feb 7, 2012 at 5:15 PM
    #7174
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    n0rth has one on his 4 banger looks and it looks awesome. Once i get my safari rack it'll look even cooler
  15. Feb 7, 2012 at 5:17 PM
    #7175
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Anyone jumping on MetalTech 4x4's sale for LR UCAs?
  16. Feb 7, 2012 at 5:25 PM
    #7176
    Mitch
    Mitch
    Spokane, WA
    Bad experience? Do tell please
  17. Feb 7, 2012 at 6:21 PM
    #7177
    all.on.black
    Auburn, WA
    Are you Spokane? If so there's a five hour difference between us.
  18. Feb 7, 2012 at 6:30 PM
    #7178
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    yea but i go to portland twice a month I can swing by on the way there or back
  19. Feb 7, 2012 at 6:45 PM
    #7179
    all.on.black
    Auburn, WA
    Whens the next time you'll be around?
  20. Feb 7, 2012 at 6:48 PM
    #7180
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    presidents day weekend in not scheduled to go but i can make a trip any way
