Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Feb 27, 2012 at 6:01 PM
    #7861
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I wish i lived closer I'd go wheeling with you guys
  2. Feb 27, 2012 at 6:44 PM
    #7862
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Thanks to you I am, gonna pick up those MT/Rs after work tomorrow. Now I just need some Relentless sliders....
    ...and a winch
    ....and a winch mount
    .....and dual ARB lockers
    ......and OBA
    ........and some 4.10 gears
    .........and chop my body mount
    ..........and maybe some wheels with more B/S
    Dammit, what did I get myself into. :eek:
  3. Feb 27, 2012 at 7:04 PM
    #7863
    rwalker
    rwalker Well-Known Member
    Rian
    Portland
    Tacoma Baja TX
    Does anyone have/had toytec coilovers?
  4. Feb 27, 2012 at 7:07 PM
    #7864
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    yes
  5. Feb 27, 2012 at 7:38 PM
    #7865
    rwalker
    Rian
    Portland
    Tacoma Baja TX
    Want to share you knowledge of raising them? :D
  6. Feb 27, 2012 at 7:51 PM
    #7866
    KalamaKid
    Oregon
    You mean adjusting them to a higher setting?
  7. Feb 27, 2012 at 8:11 PM
    #7867
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I wish. This is just a general "want to" list. Maybe some wheels by then, or sliders. :notsure:
  8. Feb 27, 2012 at 8:13 PM
    #7868
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Whoaaaaa my truck is on the front page of this thread!
  9. Feb 27, 2012 at 8:13 PM
    #7869
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    A lot of our trucks are. :laugh:
  10. Feb 27, 2012 at 8:34 PM
    #7870
    rwalker
    Rian
    Portland
    Tacoma Baja TX
    Yes. I just bought a winch and I have noticed my front has started to droop. I didn't install them so I am not really sure how it goes.
    Have you adjusted them while on the truck?
  11. Feb 27, 2012 at 8:40 PM
    #7871
    KalamaKid
    Oregon
    Yes. You need to clean the top collar with alcohol and make sure you get all the grit off of it. Then spray some penetrating oil on the top collar and let it soak into the adjustable ring. Wait at least an hour then use your small wrench to anchor down against the spindle and take the large wrench to adjust it up. Make sure you use either a breaker bar or pipe on the large wrench or you won't get enough force to move the coil and you WILL BREAK THE WRENCH. You have to remove your tire and jack up the truck to do this. The drivers side is much easier if you take off the sway bar first. About a 10th of an inch equals about .25 inch in lift.
  12. Feb 27, 2012 at 8:49 PM
    #7872
    rwalker
    Rian
    Portland
    Tacoma Baja TX
    Cool that's about what I had read.
    Don't you adjust it from the bottom of the coilovers?
  13. Feb 27, 2012 at 8:55 PM
    #7873
    KalamaKid
    Oregon
    no you will break the wrench
  14. Feb 27, 2012 at 9:00 PM
    #7874
    rwalker
    Rian
    Portland
    Tacoma Baja TX
    I dont see holes to put the wrench in on the top.
  15. Feb 27, 2012 at 9:03 PM
    #7875
    KalamaKid
    Oregon
    use a pipe!
    Both of my wrenches have holes for a breaker bar? I always just use a pipe though...
  16. Feb 27, 2012 at 9:10 PM
    #7876
    rwalker
    Rian
    Portland
    Tacoma Baja TX
    Sorry, I mean the only place to put the spanner wrenches is near the bottom of the coil over. Is there another place on the top?
  17. Feb 27, 2012 at 9:13 PM
    #7877
    KalamaKid
    Oregon
    No? There should be two collars. The smaller one on the bottom and the larger one on the bottom just below the spring.
    The holes you can see just below the spring are where the larger wrench goes and about 2 inches below that is a smaller ring where the small wrench goes. Its hidden by my sway bar.
  18. Feb 27, 2012 at 9:23 PM
    #7878
    rwalker
    Rian
    Portland
    Tacoma Baja TX
    Ok yea. I misunderstood what you had said. For some reason I was thinking of another places with holes on the top of the spring.
    Thanks for the help.
    I will probably have to pay someone to do it {blah}.
    Anyways I got a good deal on an Engo e10000, so its almost adventure time....almost.
  19. Feb 27, 2012 at 9:24 PM
    #7879
    KalamaKid
    Oregon
    It takes less then ten minutes in your driveway or a street corner or even a wallmart parking lot :anonymous: Save the coin!
  20. Feb 27, 2012 at 9:25 PM
    #7880
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    Want to buy some 35" MT/Rs on 17x8 Konig Countsteer X wheels?
