Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Apr 23, 2012 at 12:50 AM
    #9321
    rvcahawaii808
    rvcahawaii808 Well-Known Member
    cameron
    beaverton
    04 limited T4R 4x4
    thanks for the info. my living room area is about 500sqft which is the main area i want to keep cool. i looked online and was finding that 10,000BTU is about the right size for 500sqft. right now im leaning towards a portable one because i want to be able to move it to and from the bedroom, and im also worried about how hard it will be to install a window unit.(really like the idea of just having to plug it in and turn it on). so if you went with a portable would you go with at least 20,000btu or would that be overkill.
    edit: i also saw those "evaporative air coolers" are those just bad? should i stay away?
  2. Apr 23, 2012 at 1:08 AM
    #9322
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Just getting a little practice in before moab. my wheeling experience is limited to sand and snow never really done trails or rocks before.
  3. Apr 23, 2012 at 5:15 AM
    #9323
    NetDep
    NetDep Well-Known Member
    Tim
    Southern Utah
    2011 Toyota Tacoma Off Road MGM
    Thanks for that info!!! Did not think you had a build thread -- which would be great but, as you said, not good for me either!! Thanks again and happy wheelin'!!!!
  4. Apr 23, 2012 at 10:37 AM
    #9324
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I’m doing some route planning for our trip to Moab for the upcoming TW meet. Looking for some feedback on our route thru Oregon. Mark (The Raisin) and I are going in his Tundra towing my rig on a 17 ft car trailer.
    We will be staying in La Pine on our first night on the road. I am thinking Salem to Sister/Bend over Santiam pass. In fact, thinking hwy 22 past Detroit Lake to hwy 20 then on to Sisters. We’ve never been this way and are looking for a scenic drive.
    Anyone done this route while towing?
    Since it will be May 11th, it doesn’t seem like snow/ice would be an issue but not sure about that. We have experience towing a Tacoma over mountain passes in Wa and the Tundra is quite capable.
    Thoughts?
  5. Apr 23, 2012 at 12:05 PM
    #9325
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Cameron: Windows can be a challenge, but I've done it. If you are in an apartment, yeah, I wouldn't want to try it again.
    Overkill. if they say 10k, you probably want 12, 14 at the max. I can't remember if I went 2 steps up or just 1, I'd probably do 2 steps if you can swing it.
    I think it's just gimmicky. I have this model and I never use that setting. I don't know if I'm using it wrong or if it's the wrong climate to use it for. My advice is that it doesn't matter.
  6. Apr 23, 2012 at 12:16 PM
    #9326
    Chickenmunga
    Keizer, Oregon
    We have a '99 Dodge 250 diesel and we pull a 24' 5th wheel. We usually take that route during September, there isn't anything difficult towing-wise. SE Oregon is somewhere I've never been, but it's pretty barren of anything. On our Utah trip we went to Boise and then down, the only parts we didn't like were Twin Falls to Ogden (boring, literally nothing out there), and Salt Lake City (traffic).
  7. Apr 23, 2012 at 1:58 PM
    #9327
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks Mike. We'll come back the route thru SLC, Twin Falls and Boise but we thought it would be interesting to mix it up a bit when going. Good to hear Santiam shouldn't be an issue.
  8. Apr 23, 2012 at 2:29 PM
    #9328
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Skids came in...
  9. Apr 23, 2012 at 3:23 PM
    #9329
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
  10. Apr 23, 2012 at 5:24 PM
    #9330
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    It is almost as good as a chemical bath cleaning for the motor, fuel system, and oil. i recommend doing it about every 30,000 miles. that is often enough that you will notice the difference, but you won't blow a bunch of money trying to clean what is still clean.
  11. Apr 23, 2012 at 9:39 PM
    #9331
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Just make sure if you are going to do it that you plan on an oil change soon afterwards
  12. Apr 24, 2012 at 2:41 AM
    #9332
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Koreans....at the Tulip Festival...
    EDIT I took the picture because of their face mask :spy: never have I seen so many DSLR camera in one place...
  13. Apr 24, 2012 at 2:43 AM
    #9333
    JoeTacoma02
    hMM, interesting. I think I'd be more scared to do it than anything,
  14. Apr 24, 2012 at 7:26 AM
    #9334
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Trying to gauge interest for either day @ Tahuya. I think this will be a day-trip, but camping may be an option if there are enough people interested.
    Let's get some feedback on which day would work best for everyone who's interested in going. (Note: I can go either day)
    *NOTE: Washington Discover Pass required. Info/purchasing HERE
    Tahuya Maps:
    http://www.nwjeepn.com/Maps/Tahuya.pdf
    http://www.dnr.wa.gov/Publications/eng_tahuya_both.pdf
    Camping Info: All camping is first come/first serve
    Tahuya River Horse Camp - couldn't really find anything on this one...
    Camp Spillman (*FREE, right near the 4x4 trailhead) - http://www.freecampgrounds.com/detail.aspx?id=1643
    http://www.eugenecarsey.com/camp/tahuya/spillman.htm
    Kamenga Campground (*FREE, right near the 4x4 trailhead) - http://www.eugenecarsey.com/camp/tahuya/kammenga.htm
    Saturday, May 12th
    Ben (Benson X)
    -OR-
    Sunday, May 13th
    Ben (Benson X)
  15. Apr 24, 2012 at 9:21 AM
    #9335
    2011TacoBeav
    2011TacoBeav Well-Known Member
    Bret
    Oregon
    2012 Sr5 v6 auto DCSB
    Self made rear bumper Colormatched Bush Wackers CB Center console lock box Camo seat covers Weathertech Digi blk Bilstein 5100s set at .85 Eibach coils LR UCAs Rear 1.5" block
    I'm interested in tahuya. Leaning towards Sunday. It's just out by hood correct?
    Is there any special passes needed to recreate in that area?
  16. Apr 24, 2012 at 9:54 AM
    #9336
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    See above...or not.
    Located just West of Belfair, WA. The local Safeway is the preferred meeting area.
    WA Discovery Pass required ($11/day or $35 Annual)
    This may turn into a camping trip, but I think Saturday would be the best option so more people can join, and we can spend a good portion of the day/evening out there without cutting the trip short.
  17. Apr 24, 2012 at 12:36 PM
    #9337
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Are OR ORV passes valid? Or is the WA Discovery Pass something totally different?
  18. Apr 24, 2012 at 12:43 PM
    #9338
    Chickenmunga
    Keizer, Oregon
    No. Oregon passes are not recognized at all for anything in Washington.
    Yes. You must have one. I think I've seen a trooper every trip to Tahuya
  19. Apr 24, 2012 at 12:46 PM
    #9339
    SteelheadPDX
    SteelheadPDX Well-Known Member
    David
    PDX
    02 Tacoma TRD
    Anyone interested in them? $600 with brand new 650# springs.
  20. Apr 24, 2012 at 12:47 PM
    #9340
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    I thought the Oregon tags were good in Washington, and vice versa. :confused:
