Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Oct 30, 2012 at 6:06 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    What valving did you go with? I'm sure you will be happy with them, they can sure take some abuse!
  2. Oct 30, 2012 at 6:29 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Sonny said they can have ICON lessen the slow speed dampening so at lower speeds the shocks will not be as firm but won't give up performance at speeds
  3. Oct 30, 2012 at 7:21 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Sweet, it will ride like a cadddy but still take a whompin'. Downsouth is good to deal with and if you don't like it they will revalve for you. You'll be as happy as a puppy with two peters when you go for your first ride.
  4. Oct 30, 2012 at 8:30 PM
    Mitch
    Mitch
    Spokane, WA
    I can't wait. Should be here within 3 weeks. Since it is a 2-3 week build time
  5. Oct 30, 2012 at 9:05 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I got a chance to install Office 2010 tonight. Some observations:
    -It spews all the icons onto the modern interface desktop. I had to one-by-one hide tiles for stuff like XPS viewer and stuff that you don't normally open.
    To open Word, I start at the modern desktop and click the Word tile
    It moves to the traditional desktop and loads Word
    I then press the Windows key to return to the modern desktop, then click the Excel tile
    It moves back to the traditional desktop and loads Excel
    I can use Windows+Left or Right to snap the windows around, just like Windows 7. However, this only works in the traditional desktop. In modern desktop, you have to use the mouse to create a 80/20 split
    I mentioned before that Alt+tab and Windows+tab didn't work, but I just got an update that has enabled that feature.
    Windows + tab doesn't do the sideways thing like in Windows 7. Instead, it opens a bar at the left side with a vertical listing of my running apps/programs. It disappears once I let go of the Windows key, just like before.
  6. Oct 30, 2012 at 9:13 PM
    Mitch
    Mitch
    Spokane, WA
    Man that sounds way to confusing
  7. Oct 30, 2012 at 9:51 PM
    Chickenmunga
    Keizer, Oregon
    It's slightly easier when you are actually doing it, but the problem is there's no "do it this way every time" sort of method. Needs more unification.
    In other news, I don't think even Toyota can get me to buy a Hummer
  8. Oct 30, 2012 at 10:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Rear steering?
  9. Oct 30, 2012 at 10:30 PM
    Chickenmunga
    Keizer, Oregon
    4 wheel
  10. Oct 31, 2012 at 12:27 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    So win 8 is just as horrible as advertised, rgr. Too bad, Windows 7 was actually, a masterpiece.
  11. Oct 31, 2012 at 7:10 AM
    Mitch
    Mitch
    Spokane, WA
    Negative son. No bracing = no jumping
  12. Oct 31, 2012 at 7:10 AM
    Mitch
    Mitch
    Spokane, WA
    I don't think it would be that bad if the roof line was redone.
  13. Oct 31, 2012 at 10:02 AM
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    Bastard! :p
    Gonna be badass Mitch.
  14. Oct 31, 2012 at 10:10 AM
    Mitch
    Mitch
    Spokane, WA
    Now I just have to wait patiently. For a couple weeks.....Damn it.
  15. Oct 31, 2012 at 10:11 AM
    Mitch
    Mitch
    Spokane, WA
    I need to give a shout out for DownSouth Motorsports. If you are thinking of getting something for your truck. Sonny is awesome to work with
  16. Oct 31, 2012 at 10:25 AM
    Chickenmunga
    Keizer, Oregon
    I had a nice response for you, but Comcast ate it. From what I can remember:
    -At least it's stable from what I can see
    -It's stupid fast
    -There's signs of really great concepts happening, and forward thinking. Impressive from a giant enterprise that's built a product that people expect to be both monolithic and futuristic
    -got to hand it to them for venturing away from the same input devices we've been using for the past 40 years.
    -also give them points for changing their pricing structure ($40 for upgrade disc). Seems out of character, but shows they can be hip to the times.
    It feels like a concept car. I think that if they try building incrementally and have quick, inexpensive releases, they can hammer out a lot of issues.
  17. Oct 31, 2012 at 10:43 AM
    Oregon TRD
    Ross
    2005 Mall Krawler
    That's the tough part.
  18. Oct 31, 2012 at 12:55 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    :spy: sup lol
  19. Oct 31, 2012 at 1:31 PM
    snowgod06
    Rob
    06 Access Cab
    What I miss? Haha
  20. Oct 31, 2012 at 1:43 PM
    snowgod06
    Rob
    06 Access Cab
    Ive got a few. You on a PC or Mac?
    Also, their between 4-6gigs , I can't email a file that big. Any ideas?
