Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Nov 10, 2012 at 9:07 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    air down if you find yourself having a hard time. dont drive in the water.
  2. Nov 10, 2012 at 9:21 AM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    sounds easy enough. thanks
  3. Nov 10, 2012 at 10:17 AM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Ben, you're a genius. The hairdryer worked perfectly. No more dent
  4. Nov 10, 2012 at 10:38 AM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    take a shovel with you. if you start to dig into the soft sand, dig out trenches that you can get a little momentum up before trying to climb out of holes.
  5. Nov 10, 2012 at 10:41 AM
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    if you have 4wd you dont need to air down. Of course if your not feeling confident your welcome to. Also stay out of the water and try to.avoid wet sand. The salt content doesnt cope well with vehicles.
  6. Nov 10, 2012 at 10:43 AM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Don't forget your offroad permit and a flag!
  7. Nov 10, 2012 at 10:47 AM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Hell yeah man, good to hear. I realized my phrasing was a little confusing in my post, I hope you weren't banging on it with the hairdryer :p
  8. Nov 10, 2012 at 10:47 AM
    Bennett707
    Oregon
    depending where you go you might need a flag or offroad permit like Moe said, other places you just have to stay on x side of the sign.. bullshit LOL
  9. Nov 10, 2012 at 10:52 AM
    GeoTaco
    Freeda Feltcher
    Denverish
    Car seats
    good to know. ive got 4x4 on 285 duratracs, just don't have any experience on sand.
    Thanks guys.
    Also anyone in the Portland area know a good place to get a topper. I have a best top, but looking for a hardshell.
  10. Nov 10, 2012 at 11:14 AM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Watch your speed :) I believe on beach it's 25mph.
  11. Nov 10, 2012 at 11:14 AM
    JoeTacoma02
    Bump, anyone?
  12. Nov 10, 2012 at 11:29 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    Joe, first check where the water mostest from. I take it the seal from the fan exit isn't solid. Depending how much water danger their is you either A) need to replace a large chunk of the sheetrock/drywall, or B) if their isn't much water damage make sure leaks are fixed and ample time to try. Then patch the hole.
  13. Nov 10, 2012 at 11:31 AM
    snowgod06
    Rob
    06 Access Cab
    Damn phone changing words. Don't pay attention to my errors. Stupid phone!! Lol
  14. Nov 10, 2012 at 11:37 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Do you own the house or rent? If you rent, call the landlord ASAP, as it will be their responsibility.
    First, you need to determine where the water is coming in from. Most likely a vent on the roof that you may need to seal/re-tar.
    Next, determine how much of the ceiling is damaged, and make sure any load-bearing wood isn't damaged or rotting. You will most-likely need to cut out the damaged area, since it won't simply dry out. You can use a Sawzall to cut the damaged sheetrock and replace with a new piece and spackle it up.
    I don't have much experience with home repairs, but I hope this helps a little bit. Good luck. :thumbsup:
  15. Nov 10, 2012 at 12:17 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Ben let me know when you are buying/installing those lines. I'd like to do the same
  16. Nov 10, 2012 at 4:18 PM
    Mitch
    Mitch
    Spokane, WA
    Accessory Outfitters in Hillsboro
    I didn't read it like that. I read it like "heat your plastic up, take hammer to inside and push out"
  17. Nov 10, 2012 at 4:18 PM
    JoeTacoma02
    Thanks guys, I did a google search and it looks like a pain. Maybe I should leave it to the professionals :eek:
  18. Nov 10, 2012 at 6:03 PM
    Mitch
    Mitch
    Spokane, WA
    Always a good idea. Especially if you don't know what you're doing
  19. Nov 10, 2012 at 8:03 PM
    Smar969905
    Zach
    Deer Park, WA
    if you do decide to fix it yourself, make sure to get out all the wet sheetrock and any insulation that got wet. even after insulation dries out, it loses its insulating value. any sheet rock that got wet is liable to get moldy, and once that is in the walls, it is bad news.
    having the vent resealed professionally isn't a bad idea. fixing the drywall is easy enough to do on your own if you want.
  20. Nov 11, 2012 at 6:00 PM
    GreasyTaco
    GreasyTaco Member
    Jake
    Whidbey Island, Wa
    Armor, Softopper, Hella's, Corbeau's, 32" Km2's
    Went out and played in some snow today
