Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Jan 7, 2013 at 10:18 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
  2. Jan 7, 2013 at 10:31 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yellow tops are a deep cycle battery meaning they can be drained and fully recharged many many time with no performance loss.
    Red tops aren't like that. They are considered a starter battery as they get constantly recharged all the time but can flow tons of amps quickly when needed. But they aren't designed to be drain and recharged like yellow tops.
    This is why yellow tops make a great second battery as they get isolated from the alternator for periods of time.
    The die hards are great too they are basically the same as an Odessey.
  3. Jan 7, 2013 at 10:33 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    thanks for your input monte, after research i noticed my brother was wrong about the vibrations on the yellow. i'll see what his discount is for a yellow top, considering i want some lights and ideally a winch one day. i doubt ill go with a die hard, but i might look into them.
  4. Jan 7, 2013 at 11:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  5. Jan 7, 2013 at 11:12 PM
    Bennett707
    Oregon
    Thanks Mike, I still hope I don't have to replace my battery, but at least I won't spend a half a day without my truck tomorrow. It's one thing when you don't drive your truck, but when you can't... it's completely different!
  6. Jan 7, 2013 at 11:22 PM
    Bennett707
    Oregon
  7. Jan 8, 2013 at 1:40 AM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    I gave my dad a blue top and he wheels his jeep pretty hard (not your average jeep). Hasn't had any problems with it yet. He runs a lot off it and has a small block with winch and bunch of other stuff.... My 2 sense haha
    Cents
    Have you checked your starter solenoid?
  8. Jan 8, 2013 at 2:28 AM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Yeah I talked to him and he still has it. Or I'm talking to Tim about designing and building one.
    I already have 1" spacers. I think my truck sits perfect right now. I need to find a lifted Tacoma to see where I am on height
  9. Jan 8, 2013 at 3:04 AM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    I really like that bumper as well. I'd go with Tim's over an all pro any day though. Much stronger and well fitted.
  10. Jan 8, 2013 at 3:11 AM
    Mitch
    Mitch
    Spokane, WA
    In the end its gonna be a cost factor. I know what I can get the all pro for. With Tims we will have to design it from the ground up
  11. Jan 8, 2013 at 9:22 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    If you talk to cam-shaft on gitout, that guy is sort of a battery wiring genius. he might have some advice for you.
    It's a Revenge fab in case you were wondering who the fab shop was. ;)
  12. Jan 8, 2013 at 1:00 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    The Die Hard has a higher CCA and larger reserve. It's a better battery. I've had a number of yellow tops and they've all failed early.
  13. Jan 8, 2013 at 1:01 PM
    JoeTacoma02
    Lol this guy. Every time I hear someone mention his business I just want to talk shit :rolleyes: :mad:
    Mitch, how cheap of a deal are we talking for that All Pro hybrid? You don't have to list price or answer but if you're not doing any kind of serious off road I think you should be fine. Like Jason mention, I'm sure Tim will make something more beefier than the hybrid but I'm sure you know your budget and will be happy regardless of which bumper you choose.
  14. Jan 8, 2013 at 3:32 PM
    Mitch
    Mitch
    Spokane, WA
    The hardest thing is going to be selling to the the wife. I'm suppose to be "saving" money
  15. Jan 8, 2013 at 4:22 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    Ill make yu a good price :) for a local
  16. Jan 8, 2013 at 5:15 PM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Hey Joe, did you ever figure out that weird noise on your truck?
  17. Jan 8, 2013 at 5:25 PM
    JoeTacoma02
    Understandable.
    BOOM! There ya go :D Tim, are you getting crazy PMs from potential future customers?
    Nah, I'm almost tempted to take my drive shaft off to see if I can find anything haywire and then take apart my 3rd member again. It almost sounds like it's something from that area. I know people have mention to check u joints and such but to be honest I'm mechanically retarded and I don't know the the first place to check.
  18. Jan 8, 2013 at 5:42 PM
    Bobert14
    Bobert14 [OP] .
  19. Jan 8, 2013 at 6:45 PM
    Fivespeed
    Fivespeed Well-Known Member
    Tualatin, Oregon
    '12 TRD Offroad w/ Entune
    Well 2 days after owning my '12 Tacoma I get it stuck in mud in Canby. Like a boss
  20. Jan 8, 2013 at 6:48 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    Ya I get quite a few Pm's and emails and I'm back to taking orders just haven't really announced it so that things will stay slow haha
