Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Aug 13, 2013 at 3:38 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    They are self regulated. If one piston is compressed then the rest of the pressure is directed to the next piston. That's why there is one bleed nipple and not 4. If there is no air in the system then the pistons will compress with the same pressure.
  2. Aug 13, 2013 at 3:51 PM
    rvcahawaii808
    rvcahawaii808 Well-Known Member
    cameron
    beaverton
    04 limited T4R 4x4
    Ok thanks for the great info. Gonna give it another try tomorrow after work. So engine running . And go in order from passenger rear, driver rear, front pass, and the front driver side
  3. Aug 13, 2013 at 3:57 PM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I believe his '04 Runner has an electric brake booster, so having the IGN On or the vehicle running would produce the same results.
    You can feel the difference in pressure if you press the brakes when the vehicle is off - it will be very stiff with each press, and eventually you can barely press it down. Now switch the Ign. ON, and you will feel the pressure release into the brake lines, and the pedal will depress further. You should feel the same thing when you start the engine. Each pedal pump will create more pressure in the lines until you release it by opening the bleeder valve.
    Try it either way and let us know how it goes :thumbsup:
  4. Aug 13, 2013 at 4:02 PM
    all.on.black
    Auburn, WA
    Yes, you want to start with the furthest wheel from the brake cylinder and work your way in.
    Can you send a picture of your brake cylinder from the engine bay?
    I didn't even notice he had a 4 runner. I thought it was a Tacoma.
  5. Aug 13, 2013 at 4:14 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    :rofl: Shit, I thought he had a 4-Runner.
    Hey Cameron, what're driving (or not driving :p)?
  6. Aug 13, 2013 at 10:00 PM
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    I still need to put my rear extended length lines on. This is all good info...
  7. Aug 13, 2013 at 10:06 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    My wife & I took a drive up to Mowich Lake today and then drove through Evans Creek on 7930. Rounded a bend in the road and found this! I had no idea we were going to see the summit from there! It was so cool! I stayed off of the 'fun' trails because I don't have any trail armor yet; and we were by ourselves.
  8. Aug 13, 2013 at 10:53 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Correct. http://autohowtovideos.com/how-to-bleed-brakes-by-yourself-gravity-bleeding/
    Essentially fill master cylinder and reservoir with fluid. Then go through the same steps of opening bleeder beginning with rear passenger wheel. Takes a bit longer but can be done by yourself and is effective.
  9. Aug 13, 2013 at 11:07 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I will again stress the benefit of having flare nut wrenches
  10. Aug 13, 2013 at 11:14 PM
    rvcahawaii808
    cameron
    beaverton
    04 limited T4R 4x4
    haha youre correct. its an 04 4runner. i actually did drive it into portland today to go to work. im getting good stopping power (both rear brakes have new pads), and im guessing that the driver side rear is working since it seems like the electrical thing was my problem.
    ill try with the ignition on first. is it going to be bad or anything if the car is actually running? i also bought a small thing of brake fluid and a new set of cotter pins and that other tension spring thing for the front brakes
  11. Aug 14, 2013 at 1:58 AM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    ^^ this. I've seen what can happen to a very tight flare nut with a regular wrench. It's not pretty.
  12. Aug 14, 2013 at 2:25 AM
    penguins_cc
    Will
    Bellevue, WA
    Nice back seat co-pilot, Arty :)
  13. Aug 14, 2013 at 10:42 AM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    ^^ haha. The dog did pretty good this time. She gets too hyper when in any vehicle. We're trying to train her to take it easy. The 6+ hours of driving around helped.
    We left the house at 12:30 and got home around 8pm.
  14. Aug 14, 2013 at 2:41 PM
    Bobert14
    Bobert14 [OP] .
  15. Aug 14, 2013 at 5:19 PM
    RyanC
    RyanC Well-Known Member
    Puyallup WA
    95 Tacoma 4x4
    Lifted, 33/1250/15's, canopy.
  16. Aug 14, 2013 at 5:56 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    I know its a long shot, but anyone going/camping the WCMF this weekend?
  17. Aug 14, 2013 at 10:01 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Moved to Eagle Point Oregon. Got a decent little garage to start some kind of shop. If anyone heading south on 5 needs a pit stop hit me up. It's a little country down here :D
  18. Aug 14, 2013 at 10:11 PM
    55chevy05taco
    55chevy05taco Well-Known Member
    Tallon
    lewis county, Washington
    05 V6 SR5 4x4 DCLB
    3" rough country spacer lift, mastercraft wild cat AT2, dual pipe magnaflow, billet grill, rocker guards(?), weld kit front plate winch bumper, 4x55w hella black magic 500's, k&n cold air intake, black badges, smoked OEM tails, bestop supertop,
    ROAD TRIP!!!! lol gl we better see u at tsf next year
  19. Aug 14, 2013 at 11:09 PM
    KalamaKid
    Oregon
    Probably see me before that for sure. Looks like the $$ will be there for good mods. Ill be up for all kinds of winter wheeling (my fav). Need new tires though. Thinking MTR's but out here I need something that can handle a lot of road miles and still be sticky. Looking at 305/70/r17's. I really like the BFG AT's but they are less aggressive than my BFG KM2's. open for suggestions as new tires are coming soon.
  20. Aug 14, 2013 at 11:13 PM
    KalamaKid
    Oregon
    Actually to correct the above post. I'm going to keep my 33" KM2's for the summer they are at 40%. Then get a larger winter set on 16"s soon that can handle the snow.
    So glad I don't have to sell the rig any more!
