Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Dec 13, 2013 at 1:30 AM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    he ruined it. I don't care if it has the ability to drop down or raise up. that ride height in the second pic is still lower than factory. looks almost like he took an older low boy tacoma chasis and put the 4runner body on that.
  2. Dec 13, 2013 at 11:21 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    Can someone explain how much more this is beneficial? I don't see the cost in this making it worth it.
  3. Dec 13, 2013 at 11:27 AM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Being cool
    But probably just being unique. Tucks everything up out of the way
  4. Dec 13, 2013 at 11:38 AM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
  5. Dec 13, 2013 at 11:55 AM
    Mitch
    Mitch
    Spokane, WA
    And it keeps your bed intact. Your "bed cage" is under the bed
    I would be worried about weight distribution. That's a lot of weight right there
  6. Dec 13, 2013 at 1:02 PM
    Bobert14
    Bobert14 [OP] .
    Allows you to keep the bed functional is the main benefit.
  7. Dec 13, 2013 at 5:30 PM
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
  8. Dec 13, 2013 at 8:16 PM
    bigbirch887
    bigbirch887 "Initial Success or Total Failure"
    chris
    Mesa, AZ
    2011 DCSB TRD 4x4
    Extended Travel ICON fronts Extended Icons Rear w/leafs Built Right UCAs BAMF LCA Skids and Rock Rails US Offroad Hideaway winch bumper insert 9.5K Smittybuilt Synth Winch Custom Bedrack Mt. Shasta CVT Extended Braklines F/R Diff Breather Mods CB Stealth center console install and a few other things......
    Anyone from the Eastern WA area? Around the Yakima/TriCities/Kennewick area..... I'm looking for an off road shop local and somewhat quick. I'm new to the area and have a 3.3" lifted 2011 DCSB with 33" tires. Just had the Toyota Dealership re-align the truck and they jacked the front tires backward and now my Cab Mount Chop Mod isn't doing shit for me!!! If I can't fid a place this next week, I will probably cancel my trip to MT over the holidays...... won't be able to turn let alone flex at all while going to the mountains!
    Thanks in advance for any references!
  9. Dec 13, 2013 at 8:20 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Fix it yourself mang. The front alignment cams (closest to the front bumper) control caster. Turn the driver side one clockwise when viewed from the front bumper and the pass side counterclockwise. This will push your tires forward away from the cab mount. Just make sure they are even. If you don't feel comfortable take it to an alignment shop and tell them you want more caster to clear the mounts. If you are clusterfucked and can't figure it out I'm an hour out from tri-cities, but it will cost you beer. Good beer, as I've spent some time at GTA myself.
  10. Dec 13, 2013 at 8:35 PM
    bigbirch887
    chris
    Mesa, AZ
    2011 DCSB TRD 4x4
    I haven't put a wrench on them yet because I'm waiting for my Housing Shit to still come from overseas with my tools (have only been in town for 3 weeks and just picked up the truck from the Port). the dude at the dealership said today that the caster bolts where seized up! Due to him or just corrosion idk? He supposedly put a breaker bar on them and felt like he was going to snap them so he stopped.... I might just buy a wrench or 2 this weekend and give it a try.... but if not I think its going to need new hardware for the LCAs. Just kind of PO'd cause it only has 28000 miles. I will take what you said into account if I attempt it in the Hotel parking lot HAHA
  11. Dec 13, 2013 at 8:51 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Oh shit I didn't realize that. Well if you feel like a road trip I have a shop, and did ten years active duty so mi casa su casa. We can try to put some heat on them and get them busted loose, or hit them with PB blaster. Make it down here by 1000 tomorrow and I'll take you shooting too! Later, Logan
  12. Dec 14, 2013 at 9:43 AM
    Smar969905
    Zach
    Deer Park, WA
    PBlaster is fucking awesome stuff. It makes WD40 look like spray glue. Another good one to use is CRC brand. I use that stuff at work and in my opinion, it is a little better than PBlaster.
    As for buying wrenches, I suggest Kobalt crap, or craftsman. Kobalt is exclusive to Lowes, and Craftsman is primarily through Sears, with a little through Ace Hardware. Both have the lifetime warranty on their hand tools. Kobalt will probably be the cheaper way to go.
    If Toyota did the alignment and cranked the wheels back, I would say first take it back to them and tell them to fix it on their dime. Good luck on getting it fixed in time.
  13. Dec 14, 2013 at 2:59 PM
    bigbirch887
    chris
    Mesa, AZ
    2011 DCSB TRD 4x4
    Thanks for the input! I ended up going to les schwab down the road and with the PB blaster and an impact we got them loose and adjusted them. A little bit positive caster made the difference but I think I need to still re-do the Cab Mount Chop so when I flex I don't make any contact, I figure take off another 1/2" to where the hole is on the mount and it will be good! I am honesty no happy with the dealer and don't think I will go back there unless I have drivetrain issues, they didn't try and just said they needed to be replaces.... seems lazy to me. I will be turning my new garage into a shop hopefully once I get settle here!
  14. Dec 15, 2013 at 6:52 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
  15. Dec 15, 2013 at 7:52 PM
    Bobert14
    Bobert14 [OP] .
  16. Dec 15, 2013 at 10:05 PM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    'Murica!!!
  17. Dec 16, 2013 at 9:17 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Why did they feel the need to 'paint' the mud on the side of a mud truck? LoL
    On a side note, hows the snow on Hood? I might come up in January and snowboard on my old turf.
  18. Dec 16, 2013 at 11:21 AM
    Spoon93
    Spoon93 Well-Known Member
    Rogue valley
    06 DCSB SR5
    Anyone looking to go drive some snow covered service roads and camp out? Went with a buddy this last weekend up Lolo Pass on Hood.
    Some pics. My DCSB (stock :( ) and his AC. My A frame actually got too hot I had to move into my truck.
  19. Dec 16, 2013 at 3:10 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Hey guys I've decided to go with a new look. Going to try it out for a few weeks, think it will catch on?
    Pretty cool, I sold the spare metal to Benson X
  20. Dec 16, 2013 at 3:17 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
