Oregon/Washington Craigslist Ads
Discussion in 'North West' started by Mitch, Oct 20, 2012.
  1. Apr 14, 2020 at 8:57 AM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
  2. Apr 14, 2020 at 9:06 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    bobsuruncle and ST77[QUOTED] like this.
  3. Apr 14, 2020 at 9:08 AM
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    EXPEDITION ONE! Two posts above this :D
  4. Apr 14, 2020 at 9:09 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Especially when you don't gain any clearance. Weird to see a dual swing-out that maintains the factory hitch.
  5. Apr 14, 2020 at 9:16 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Are these extended for the leaf pack ? Or did they send you OEM length
  6. Apr 14, 2020 at 9:18 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Well... They fit with the Deaver U402 Stage 2 leaf pack, which is 2.75" thick. Not much threads exposed after that, but enough to not be alarming. So, I suspect they're longer than stock.
  7. Apr 14, 2020 at 9:20 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Only Stage 2?? Why didn't you go all out for 3?!
    Bertw192[QUOTED] likes this.
  8. Apr 14, 2020 at 9:24 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I ordered the stage 1, and they sent me the stage 2 by mistake. I had it installed for 3 weeks and was causing all sorts or problems. Finally contacted Deaver directly (ordered through Wheelers) and they realized their error and shipped out the stage 1.
    Stage 2 (even with 300 lbs of sand in the bed) was too much lift (3"+), had nasty driveline vibrations, and rode fairly rough. I imagine the stage 3 would be the equivalent of welding in 3" solid steel plate for my leaf springs.
  9. Apr 14, 2020 at 9:25 AM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Mmmm deavers :drool:
  10. Apr 14, 2020 at 9:26 AM
    YF_Ryan
    Kent, WA
    Your truck must be a little lighter than mine, lol. I have the stage 3. Rides great!
  11. Apr 14, 2020 at 9:26 AM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    How much weight are you carrying?
  12. Apr 14, 2020 at 9:27 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i have those deavers too. need a one piece driveshaft now. effing vibes suck.
  13. Apr 14, 2020 at 9:28 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Yeah, not much weight back there.
    • aluminum bed bars
    • Shovel
    • (4) maxtrax
    • tonneau cover
    • RCI bumper (20 lbs over stock)
    • full size 265/70/17 spare and T4R Pro wheel
    • BAMF sliders
    but that's about it for added weight.
  14. Apr 14, 2020 at 9:29 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    What stage are you running and how much lift did you get. I had nasty vibes with the stage 2 at 3". With the stage 1 at 2", I have very minor, if non-existent vibes.
    I think it's critical to run these at the proper load, otherwise it throws of the designed angles.
  15. Apr 14, 2020 at 9:34 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i have the u402 i think. with 1" blocks. tried to keep similar height from the block lift when i switched axles. db front lift is kinda permanent. trying to sort out the front now. i usually have 2-400lbs of payload. after checking my angles i still have vibes 0-15mph. drives me nuts!:bananadead:
  16. Apr 14, 2020 at 9:37 AM
    YF_Ryan
    Kent, WA
    Too much?
    Habitat 350
    Batteries and such 150
    Maxtrax x4 30
    Camping stuff (that's always in truck) 80
    Fridge 70
    Also just added a high clearance rear bumper which added a good hunk of weight. And finally, I tow a trailer, a lot. 16 foot flatbed car hauler used to haul my SxS and ATV.
    And when I do head out camping, add 100lbs water, food, drinks, 20lb propane tank, 30 pound hot water system... and everything else, lol.
    EDIT: fully loaded
  17. Apr 14, 2020 at 9:42 AM
    YF_Ryan
    Kent, WA
    I will admit to some serious vibrations between 55 and 61ish. I just make an effort not to drive at that speed, lol. Other than at that speed, no other issue.
  18. Apr 14, 2020 at 10:17 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    At that point, why not a fullsize? Or do you normally leave the other toys at home.
  19. Apr 14, 2020 at 10:24 AM
    YF_Ryan
    Kent, WA
    I bought the truck new back in 2011. Wasn't until 3 or so years ago I started modding the rig. It's 100% paid off, and less than 100K miles on it. I like the smaller size, came from a full sized chevy before. I wouldn't doubt if over half my miles anymore are towing the trailer. We like to camp at the dunes and ride. Also tow the 4 seat SxS to use with Search and Rescue. Other than that, I usually just drive the truck 7 miles round trip to work each day. And it tows my toys fine, as long as you don't mind getting 10mpg.
  20. Apr 14, 2020 at 1:12 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    The following is free I want it gone located in tacoma, wa
    Behind the seat DCSB 2017 storage with sound deaden. Comes with hardware FREE I WANT IT GONE 20200414_131145.jpg
    cemented likes this.
