Oregon/Washington Craigslist Ads
Discussion in 'North West' started by Mitch, Oct 20, 2012.
  1. Oct 25, 2018 at 8:33 PM
    #9561
    AugustusJack
    AugustusJack Well-Known Member
    A.J.
    NW WA
    '19 DCLB OR, '00 XC 3.4L 4wd MT
  2. Oct 25, 2018 at 8:40 PM
    #9562
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Maintenance on those is a real pain in the grass.
    the_tacocamper likes this.
  3. Oct 25, 2018 at 8:41 PM
    #9563
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    That camouflage game is on point.
    Benzdriver81 and bobsuruncle like this.
  4. Oct 25, 2018 at 9:10 PM
    #9564
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Who needs a deer blind when you can just sit in your fuckin car?
  5. Oct 25, 2018 at 9:32 PM
    #9565
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  6. Oct 25, 2018 at 10:15 PM
    #9566
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    #roadhunter #eatmybush
  7. Oct 26, 2018 at 7:54 AM
    #9567
    obhuan
    obhuan Well-Known Member
    Tacoma, WA
    09 DCSB TRD OR
    Looking for an OEM or aftermarket roof rack for a 2nd gen DCSB :fingerscrossed:
    And one 285/75/16 tire in decent shape that I can use as a spare.
  8. Oct 26, 2018 at 8:49 AM
    #9568
    Dales
    Dales Member
    Dale
    Pnw
    2007 Tacoma
  9. Oct 26, 2018 at 9:31 AM
    #9569
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    From the listing:
    Open box (never used)
    Brand new never mounted it cost me just over $1,000
    Based on the pictures, no way is it "brand new" it looks a little beat up. But it appears to have the mounting stuff in bags, so probably stored outside and moved around a lot....
  10. Oct 26, 2018 at 9:47 AM
    #9570
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    What year Tacoma is it for? Seller failed to mention that in their ad.
  11. Oct 26, 2018 at 9:53 AM
    #9571
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    Def not for a 12-15, although you can fit an early 2nd gen bumper on the later year model. Can’t tell if it’s for a first gen or early second tho. Maybe @bobsuruncle can eliminate the early 2nd gen option.. $450 is a steal too.
    bobsuruncle and cemented[QUOTED] like this.
  12. Oct 26, 2018 at 10:36 AM
    #9572
    scollins
    Scott
    Renton WA
    No clue, someone will have to contact the seller and ask. Might be a good deal if someone wants to have it powdercoated to match their truck.
    But based on the pictures, I think it is for a Gen 1 Tacoma:
    From internet:
    From Ad:
  13. Oct 26, 2018 at 10:57 AM
    #9573
    Lifted360
    Lifted360 Well-Known Member
    Evan
    Fort Sill, Oklahoma
    2011 4x4 DCSB
    SAS
    He said his brother bought it for his 95 Toyota
  14. Oct 26, 2018 at 11:21 AM
    #9574
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Any clue if 95 is interchangeable with 01-04 years? :spy:
  15. Oct 26, 2018 at 1:23 PM
    #9575
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    What about just getting the bumper installed and then mounting the winch later? I think they only said it was like 1800 for the steel bumper installed and 2000 for the aluminum with no winch.
    I picked up their aluminum one and did the install with another member here. On a side note, does anyone know how to grind or file off about 4mm of aluminum? My lightbar is about 4mm too wide for the mounting points and would need to shave off about 2mm on each side for a good fit.
  16. Oct 26, 2018 at 1:30 PM
    #9576
    PacNW_Taco
    PacNW_Taco Get lost.
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    Peachy Peach air fesheners
    I asked Jon about that, and he explained it's that much more work to get the bumper back off and then reinstall with the winch. I agree in that I would just much rather do it all at once.
    That's awesome! It looks great man! Can't wait to get mine at some point.
    rlx02 likes this.
  17. Oct 26, 2018 at 1:44 PM
    #9577
    scollins
    Scott
    Renton WA
    What are you shaving, the $2,000 bumper or the $100 lightbar? If it's the $2,000 bumper, don't. Why risk the most expensive piece instead of the cheap one? If it's the $100 lightbar, a belt or flat disc sander would probably be the best.
  18. Oct 26, 2018 at 2:41 PM
    #9578
    PacNW_Taco
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    How long from start to finish for the bumper install?
  19. Oct 26, 2018 at 3:00 PM
    #9579
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    It took us about 6 hours (not including lunch and bullshitting), but honestly, you could probably knock it out in 2 or 3. The directions I used said to take the whole bumper off first, mark the line and then cut. There's zero reason to do. Just tape/draw your line first then cut. We did a lot of cuts and test fittings to get a good fit and flat line. So a large portion was taking the bumper off, marking it, cutting, testing, marking it again, cutting and repeat ad nauseum until you get your perfect line. In reality just leave the bumper on when you go to cut, saves so much time.
    Also, use big angle grinder to cut instead of a sawzall or a dremel so you get a smooth, flat line across the whole way. Smaller discs or a sawzall will leave jagged or wiggly cuts.
    PacNW_Taco[QUOTED] likes this.
  20. Oct 26, 2018 at 3:05 PM
    #9580
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I don't think I can shave 2mm off each side of the light bar without damaging some internal components or mitigate its water resistance. The only part I'd be shaving are the light bar mounts, which are thick pieces on the inside the bumper. I was thinking about getting a file and just going to town on it.
