Oregon/Washington Craigslist Ads
Discussion in 'North West' started by Mitch, Oct 20, 2012.
  1. Nov 20, 2019 at 2:30 PM
    gnardoggie
    gnardoggie Well-Known Member
    This intrigues me, actually. I've got a 6spd 2gen also....but I want to know how you're hitting 17-18mpg avg!! Do you have a canopy or anything? I think I'm pretty heavy vs the average truck.
  2. Nov 20, 2019 at 2:34 PM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    265's are wider than 255's. there is no "technically" about it, straight up fact. Your graphic shows tire 1 (265) as 10.4" wide and tire 2 (255) as 10.0" wide. So yes, the difference is 0.4", but in favor of the 265 NOT the 255 tire....
    265mm is greater than 255mm, which is what "265" and "255" represent.
    2DaMtns likes this.
  3. Nov 20, 2019 at 2:35 PM
    gnardoggie
    sorry, bros. i might have had my specs swapped when i quickly looked it at. no need to fight :). either way the .4 was correct, at least.
  4. Nov 20, 2019 at 2:39 PM
    scollins
    Scott
    Renton WA
    thread in emoji:
    :crapstorm:
    :smack::duel::argue::fistbump:
    :cheers::drunk:
  5. Nov 20, 2019 at 2:44 PM
    gnardoggie
    that's what i get for doing truck stuff while i also do actual work.
    scollins likes this.
  6. Nov 20, 2019 at 2:57 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Yes I do.
  7. Nov 20, 2019 at 3:03 PM
    TacoJova
    Central Oregon
    Still have 4 of these sitting around. Make offer
    They are 285/75/16 Cooper Stt Pros
  8. Nov 20, 2019 at 3:25 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    My new wheels are 3 lbs heavier. Not sure what that equates to or how much it'll play a factor in MPG but I was just done with 10ply tires. My wheels were pretty beat up from my off road days so I figure I'd get a new set up when I switched to all terrain tires.
    20tacoma17 likes this.
  9. Nov 20, 2019 at 3:31 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    The distance of the weight from it's rotational axis is also a factor. So, it's not a simple as comparing 1lb here to 1lb there.
  10. Nov 20, 2019 at 4:17 PM
    JoeTacoma02
    Gotcha. Well, I went from ~15mpg to ~18mpg with the tire/wheel change. Kidding lol I've gotten ~15mpg all my taco life (with my old 1st gen and this truck) and I stopped tracking many years ago. Just wanted to switch to an SL all terrain tire since I've only ran 10ply MT tires.
    On a separate note: I still have my All Pro 1.5" wheel spacers if anyone wants them or else they'll end up in the trash.
    Benson X likes this.
  11. Nov 20, 2019 at 4:23 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I'm sure someone on this forum would be interested. Otherwise, recycle them. That's a good chunk of aluminum. :spending:
  12. Nov 20, 2019 at 4:55 PM
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    I don't believe that someone with 285s is getting over 20mpg. No one had claimed that much from what I've read. I run SL 265 and am lucky to average 19
  13. Nov 20, 2019 at 5:04 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Mine... anyone with an SSO slimline bumper interested in the stage II wings? Not sure I'm ever going to get around to installing these.
    Asking $400. No savings here, but you get to skip the incredibly long lead times.
  14. Nov 20, 2019 at 5:11 PM
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    When I was running those fucktarded 285 C range wildpeaks I was still at 20 and some change on the freeway. 19ish commuting. with 45 pounds of air in them, of course.
  15. Nov 20, 2019 at 5:32 PM
    Jasonstacoma
    Stock
    I can't run psi that high. I tried 37 and got slightly better, but chalk tested then and I was way over inflated, runs correct at 32. Why do you call them fucktard, what didn't ya like?
  16. Nov 20, 2019 at 5:35 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
  17. Nov 20, 2019 at 5:37 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    I can vouch for those numbers but with a 285/70/17 load range E. At the 200mile mark the E light comes on and you better find a station quick because you'll be lucky to hit 260 miles before you're calling someone to bring you some gas.
    PNW/TRD Steve and Jasonstacoma like this.
  18. Nov 20, 2019 at 5:39 PM
    Jasonstacoma
    Stock
    I wont go to e rated, I will never push the truck that hard offroad so I'm not gonna waste the money on gas. I'll go to c or d rated possibly.
  19. Nov 20, 2019 at 5:40 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I think the cause of the rack and the cause of the rollover share a common factor...
    ^ This high-level thinker
    ...End result for both is no good
    ST77 and bobsuruncle[QUOTED] like this.
  20. Nov 20, 2019 at 5:41 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Yeah in hindsight, it's overkill for what I do, but the extra sidewall strength is comforting when down at 8psi.
    ST77 and Jasonstacoma[QUOTED] like this.
