Oregon/Washington Craigslist Ads
Discussion in 'North West' started by Mitch, Oct 20, 2012.
  1. Jan 24, 2020 at 9:28 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    Wait, so to avoid blinding people with your ditch lights, you flip on your high beams and blind them that way?
  2. Jan 24, 2020 at 10:05 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Why not wire them to only come on with high beams. So, flip to low beams and all blinding light turns to low beam.
    bobsuruncle likes this.
  3. Jan 24, 2020 at 10:17 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Have you seen the snellfab behind the grill mount? You'll have to ask @JimSnell about it. :anonymous:
    PNW/TRD Steve likes this.
  4. Jan 24, 2020 at 10:18 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    You missed the part where I wrote that I don't have high beams since my projectors don't have the cutoff shield motor wired in. Low beams only 100% of the time since the cut off shields never flip up to expose the full light source even when the switch is flipped to the forward/high beam position. All it does it cancel the fog lights which the ditch lights are wired into. Everyone does the fogs on with high beam mod bypassing the factory setup. Washington has a law that says high beams and fog lights cannot be used/illuminated simultaneously.
  5. Jan 24, 2020 at 10:28 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Honestly, I discovered the high beam/ditch light cancel trick by mistake one night when I bumped the high beams on and the ditch lights went out. Never intended to use it that way, I just started to after that. I guess I could use the passenger side headlight connection and pull from the high beam circuit to trigger the ditch lights since it's unused. Thanks for that idea. Never thought of that before. I'll add that to the todo list, and that will free up a slot for my backup/headache rack lights. :cheers:
    The wiring for my projectors ballasts are fed from the drivers side headlight plug, with it's own relay and fused harness which also feeds the passenger side housing.
    I still need to figure out a spot for my power rear window switch since I installed the 2017 power rear window into my 2006.
  6. Jan 24, 2020 at 10:33 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Even at 5'8", getting in and out of a lotus elise was not an easy chore.
  7. Jan 24, 2020 at 10:34 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Or you could swap in an add-a-fuse in your high beam fuse and trigger it there.
    bobsuruncle[QUOTED] likes this.
  8. Jan 24, 2020 at 10:36 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    I've already got wires everywhere. I've got a few h4 plugs that I can use with the high beam pin only and make it plug and play, and no extra wires to run or hide. Just reroute my current ditch light wires. I should probably figure out what the high beam circuit is rated for and see what my pods are supposed to pull.
    Don't need an electrical fire. :anonymous:
    Again. :bananadead:
    Actually each pod is 12v 15watts, so 1.25amp per. I'm good to go.
    Shadowhunter[QUOTED] likes this.
  9. Jan 24, 2020 at 11:28 PM
    20somethingwidataco
    Will
    Washington State
    Jesus, how many laws am I breaking simultaneously while driving? High beams and fogs with red halos.....
  10. Jan 25, 2020 at 6:23 PM
    tacoma_amateur
    tacoma_amateur Member
    Addison
    Olympia, WA
    2018 Black Tacoma OR
    Still got?
    TacoJova[QUOTED] likes this.
  11. Jan 25, 2020 at 7:22 PM
    ttime4four
    ttime4four Well-Known Member
    West Linn, OR
    10 Tacoma 4x4 SR5 DCSB
    This is the Jesse motorcycle tie down bar for the Tacoma. It's super solid and I loved how it kept the tire from slipping and provided tie down spots. It is in like new condition with all needed hardware (no drill).
    I'm now running a shell and carry my moto on a hitch mount.
    Here's the original thread where Jesse was selling these, but it appears he's out of this game and can no longer buy these new.
    https://www.tacomaworld.com/threads/fs-motorcycle-tie-down-bar-the-best-one-you-can-buy.334216/
    I'm in West Linn OR and its offered for $180
    buckmaster243 likes this.
  12. Jan 25, 2020 at 7:27 PM
    ttime4four
    West Linn, OR
    Extang Trifecta Soft Folding Tonneau Cover - Fit's 2nd Gen Tacoma Short Bed.
    Google it for pictures - in good shape, no tears, not faded, all hardware needed.
    Located in West Linn - $100
  13. Jan 25, 2020 at 8:43 PM
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    Busted window on one side, still worth it IMO. Not mine:
  14. Jan 25, 2020 at 8:46 PM
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    Any idea if it'll fit a 2019 Tacoma? (any reason why it wouldn't?)
    Thanks.
  15. Jan 25, 2020 at 9:11 PM
    ttime4four
    West Linn, OR
    As long as the side to side dimensions are the same -- pretty sure it's the same.
    The front rail is taken off and the five bolts go into the stock rivnuts. If you don't have a stock front rail, then some drilling / rivnuts may be needed.
  16. Jan 25, 2020 at 11:16 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Yep
  17. Jan 26, 2020 at 10:13 AM
    ROlla-Xrs
    ROlla-Xrs Well-Known Member
    Roman
    Elk,WA
    1st gen Trd Tacoma
  18. Jan 26, 2020 at 2:39 PM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    Not mine: free true fold bed cover
  19. Jan 26, 2020 at 3:30 PM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
  20. Jan 26, 2020 at 5:57 PM
    PacNW_Taco
    PacNW_Taco Get lost.
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    Peachy Peach air fesheners
    Have a 3rd gen stock tow hook if anyone is interested. Some light reading as well. Free ninety nine.
    Bertw192 likes this.
