ORI-Struts Available from BAMF
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jan 7, 2013.
  1. Jan 7, 2013 at 3:45 PM
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    BAMF has become one of the newest ORI distributors if your doing a SAS or have a jeep or buggy then ORI-Struts are for you :D
    I run these struts on my rig and they are awesome! The 1st few 2nd Gen Tacoma IFS sets will be installed soon we are testing fitment on 1st Gens as well.
    Specifications:
    Dual pressurized chamber design for unmatched body roll stability in fast turns, and on off-camber side hills. Can be set to mid-stroke ride height and still control body roll, and not push off. Most users dump the sway bar.
    With ORI’s internal features, most users also dump the external bump stops and limit straps.
    3-stage velocity-sensitive compression damping Soft ride changes to firm compression damping as piston shaft speed increases.Conventional air shocks are typically set to low ride height to prevent push-off, but bottom quickly over bumps as a result. ORIs set at mid-stroke, will both suck up the bumps, and will drop out quickly over the whoops. No trade-offs in performance.Coil-Overs are set close to full extension to help reduce body roll. ORIs set at mid-stroke, are ready to react, whether to compress when hitting a bump, or to drop out in an instant over a rut, maintaining a more level, comfortable ride at speed.
    Tunable anywhere from firm ride to loose articulation by simply adjusting nitrogen gas pressures.
    Higher load capacity than conventional air shocks. Nitrogen gas charge over 2” piston can support up to 1900 lbs/strut.
    Compact, simple installation fits tight spaces, and replaces a lot of unnecessary hardware.
    Velocity-sensitive, 7-position externally-adjustable rebound damping
    Internal hydraulic bump stop on compression stroke
    Hydraulic end-of-stroke cushioning at full extension
    Cooling fins dissipate heat
    Lightweight construction
    Billet 6061 aluminum, stainless and high-strength carbon steel
    Hard chrome steel cylinder and tough 1 ¾” piston shaft
    Teflon-lined spherical bearings for 1/2” & 5/8” mounting bolts
    High pressure 5000 psi seals for extreme off-road abuse
    Corrosion resistant anodize outer coating
    ORI Struts do not Unload, or Push Off
    Piston shafts can be set to extend to a park position, then wheel and axle weight can still pull the struts to full extension.
    Strand31p likes this.
  2. Feb 2, 2013 at 11:03 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
  3. Feb 2, 2013 at 12:01 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    So this is a gas spring and hydraulic damper in one? What is the effective spring rate?
  4. Feb 2, 2013 at 7:18 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    second gen here in CO is using them now too...LT w/ 4 link rear
  5. Feb 5, 2013 at 12:19 PM
    JLee
    Jerry
    Benicia, CA
    The spring rate depends on the gas pressure in the lower chamber.
  6. Jun 24, 2013 at 11:07 AM
    JLee
    Jerry
    Benicia, CA
    Fitment has been checked ORI's will be available as a bolt on replacement for 2nd Gen IFS. :cool:
  7. Jun 24, 2013 at 11:09 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    THAT is awesome!
  8. Jun 24, 2013 at 11:10 AM
    Manwithoutaplan
    ID
    Interesting :popcorn:
  9. Jun 24, 2013 at 11:12 AM
    JLee
    Jerry
    Benicia, CA
    I'm sure they will fit the 1st Gens as well I just need to check it first.
  10. Jun 24, 2013 at 11:16 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    im assuming you would have to measure for the oris the same way you do for a coil over?
  11. Jun 24, 2013 at 11:52 AM
    JLee
    Jerry
    Benicia, CA
    Kinda
  12. Jun 24, 2013 at 12:07 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Are you building a top plate for them? I can kinda see the 8" working if there's a really low profile top plate.
    Anyway...subbing just to see!
  13. Jun 24, 2013 at 1:25 PM
    JLee
    Jerry
    Benicia, CA
    Yes I am and the 8's will fit just fine the suspension will have to be strapped. Just from the measurements I took these will provide more travel then any mid travel set up out. With the CV joint being the limiting factor.
  14. Jun 24, 2013 at 1:30 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Aw man....you figured it out lol, might be giving you a call man, depending on how much fabrication there is I might have to do this
  15. Jun 24, 2013 at 1:33 PM
    JLee
    Jerry
    Benicia, CA
    You were too slow :eek: and I'm going to try my hardest to make them a direct bolt on. It's the limit straps that will be tricky.
  16. Jun 24, 2013 at 1:37 PM
    benbacher
    Anchorage, AK
    Lol, yeah, any idea of cost? I'm just a week or so out before pulling the trigger on front suspension. Uca's already found and purchased. And how would these handle winch, dual battery, abd heavy bumper? I was planning on the 14" 700# spring from icon so I'd need it to outperform that. Just so you know what i'm workin towards :)
  17. Jun 24, 2013 at 1:40 PM
    DHwreckage
    DHwreckage Well-Known Member
    Boulder, CO
    Moby Dick (FZJ-80)
    hmm a first gen LT with these would be sweet, what are the struts running ($)?
  18. Jun 24, 2013 at 2:05 PM
    JLee
    Jerry
    Benicia, CA
    I'm going to try and keep it under $1200.00 a set. And they can handle 1900lbs per corner so unless your front end is 3800lbs I think you will be good :D Just note ORI's have a long wait time if there is a lot of interest I'll stock them in the future but the first few orders will have at least a 8 week wait time.
  19. Jun 24, 2013 at 2:16 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    dam, 1200 is a pretty good deal for something that seems to be a one shock does everything set up.
    and these clear the cvs alright too?
  20. Jun 24, 2013 at 2:26 PM
    JLee
    Jerry
    Benicia, CA
    Yes they are thinner then CO's at 3.25" there is plenty of room for the CV's and you guys wont be hitting them like some do on coils at full droop due to them being thinner.
