Original tires brand and type
Discussion in 'Wheels & Tires' started by Calion, Mar 12, 2018.
  1. Mar 12, 2018 at 9:16 AM
    Calion
    Calion [OP] Well-Known Member
    2002 Black Tacoma SR5 4x4
    Came used with brush guard, winch and bed cover.
    I'm curious: Is there a way to find out what brand and model tires came with your Tacoma when new? For instance, I have a 2002 base 4x4. The sales brochure says that it comes with P225/75R15 All-Season radials, but gives no other information. Does anyone have this info?
    ANSWER:
    Tirerack.com seems to have this information. Type in your vehicle info, and up will pop the Original Equipment tire—at least in my case, which turned out to be BFGoodrich Rugged Trail T/A's.
  2. Mar 12, 2018 at 12:01 PM
    LR45
    LR45 Well-Known Member
    2011 TRDS DCSB
    May not help, but I was able to look up a lot of info on my truck here: https://www.toyota.com/owners/my-vehicle
    Funny you ask this question, because I was thinking this very thing a few hours ago and was planning on signing in to see if this info was there...it wasn't, unfortunately.
  3. Mar 12, 2018 at 5:20 PM
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    I think its safe to say your truck would have come with BFGoodrich rugged trail T/A's...
  4. Mar 12, 2018 at 5:22 PM
    Calion
    Thanks! Where did you get that info?
  5. Mar 12, 2018 at 5:27 PM
    Pot_Lickr
    Ontario, Canada
    PDF brochure
    You listed the size so I looked it up at the back in specs... Then saw a TRD model in the pictures which also used this size with the BFG's..
    This was a popular factory tire
    My 2002 F150 had a set on it when I got it in 2008.. 32k km on it..
    Calion[OP] likes this.
  6. Mar 13, 2018 at 12:15 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Bfg Rugged Trails are horrible. Imo
  7. Mar 13, 2018 at 12:17 PM
    Calion
    So I've heard, from several sources. You guessed correctly, I was thinking about getting stock tires, whatever they were, but with how terrible the Trails are, that seems like a bad idea. I'm thinking about the Rugged Terrains.
  8. Mar 13, 2018 at 1:34 PM
    Pot_Lickr
    Ontario, Canada
    What makes you say that?
  9. Mar 13, 2018 at 7:50 PM
    Calion
    It seems to be pretty much the general consensus. They're popularly known as Rugged Fails. Poor performance, rapid wear—I'm not sure I've heard anyone say anything good about them.
  10. Mar 13, 2018 at 7:51 PM
    Calion
    Give the man a prize. According to Tirerack.com, you are indeed correct.
  11. Mar 14, 2018 at 3:48 AM
    Pot_Lickr
    Ontario, Canada
    Well.
    They aren't to bad of a tire if you use them accordingly..
    The tire in question is not good in the snow, but it gets you good gas mileage... And the tire doesn't spit stones.
    If you are looking for something similar, try the Firestone Transforce A/T2
    They only come in LT, but are lighter than most LT..
    Like a set in 245/75/16 is around 42lbs and its E rated..
    I've run these tires for years on my GM's, for the fact they come the 17/32's of tread.. Are of the ribbed design, and spit 0 stones on gravel roads..
