Other Relentless Fab. products
Discussion in 'Relentless Fabrication' started by RelentlessFab, Jun 4, 2010.
  1. Jun 4, 2010 at 11:05 AM
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Here are some products other than bumpers and sliders that I offer:
    You can find all these things available for order on my online store at
    www.relentlessfabrication.us
    - Hi-lift bed rail mounting brackets (pair, bare steel):
    Easily mount your hi-lift jack to either side bed rail, or front of the bed of the 05+ Tacoma with only a 3/4" wrench and about 5 minutes required.
    Jack is held tight with a wing nut for easy no-tools securing and removing from the mounts.
    - Bed corner tie down brackets(pair, bare steel)-
    These brackets are specially made from CNC cut and bent 3/16" steel to tie the front and side tie down rails together for additional strength, rigidity, and tie down locations. They allow a more secure tie down point for heavy or awkward loads like dirt bikes/street bikes, construction or garden equipment, or anything else large and bulky.
    Also has a hole for mounting CB/whip flag/backup or bed lights.
    -Skid Plates:
    All skid plates are CNC cut and CNC formed on a press brake. If a skid requires any hardware to mount, that hardware is included with the skid plate. Skids ship as bare steel.
    Standard duty IFS skid from 3/16" steel
    Upgrade to 'Relentless Duty' 1/4" steel skid for only $30 more if you really want a bash-proof skid.
    Mid(transmission) skid out of 3/16" steel and T-case skid out of 3/16" steel
    Special offer: order all 3 skids and get a package price!
    We also offer the IFS and mid in 1/4" 5052 Aluminum for a lighter option for those that dont beat on their truck but want skids there for peace of mind if they were to hit something. Ifs is only 24lbs and mid only 18lbs!
    IFS skid:
    Mid(transmission/cat) skid
    Mid skid looking forward where attached to IFS skid
    ** The little corners sticking down on the prototype mid skid pictured above have been removed from the CAD/cutting files, so those will no loger stick out past the IFS skid.
    Attaching the Mid skid requires the IFS skid to be installed, but the mid skid is not required in order to use the T-case skid.
    T-Case skid plate
    Bolts behind the transmisssion/tcase cross member and protects the vulnerable tcase and factory exhaust cross over from damage.
    Can also be ordered without the cross over drop for more clearance and smoother skid but will require the cross over to be rerouted on V6 trucks. 4cylinder trucks can take advantage of no cross over cutout/drop due to not having the cross over. Please specify what engine your truck has when ordering.
    http://i120.photobucket.com/albums/o179/maxama10/skids/IMG_7311.jpg
    1st gen Tacoma skids will be available soon as well.
    - Headache racks.
    I can do them with formed plate uprights, or just out of square/round tube like others out there. PM me and we can talk about the style and functionality vs cost. I can build them out of 1/8" CNC cut steel or aluminum plate, custom lettering available in plate formed uprights. Mounts to factory bed rail mounting location and replaces the factory plastic bed caps on 05+ Tacomas.
    Long bed:
    short bed:
    - 05+ Tacoma Tube bed cargo/accessory bars-
    Made from 1 3/4" x.120" wall tubing with 3/16" steel CNC cut mounting brackets.
    Includes the necessary mounting hardware (1/2" gr8 bolts and T-slot nuts).
    2 mounting tabs for lights/CB standard by request, additional for $5/ea. add hi-lift holder brackets for +$15
    Bars are $80ea or order a pair for $150, + shipping.
    96-04 Tacoma bed cargo/accessory bars(should also fit 89-95 pickups)
    Here is a 1st gen bar with tabs for lights/CB as well as a hilift jack holder on it ($95 as pictured).
    - 2005+ Tacoma Hood hinge CB antenna/light mounts. great mount for auxiliary LED lights, or whip antenna's for the dunes as well.
    Standard bracket is for driver side, but passenger side is available too.
    Or order both brackets at a discount.
    Sample images of CB/light bracket installed:
    - High-flotation steel plate Hi-lift off road bases.
    These offer over 3 times the surface area of the standard hi-lift jack base, so the jack doesnt sink into soft surfaces under the weight of your vehicle. It also bites into the ground for more secure use of the jack, yet the base can also be flipped over so it can still be used on hard surfaces like concrete.
    Includes a 1/2" bolt/nut for quick removal or flipping the base.
    N0M4D72 and ChadsPride like this.
  2. Jul 2, 2010 at 3:36 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    When you say tube bed bar. do you mean like a roll bar type setup because that would be awesome!
  3. Jul 2, 2010 at 4:12 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    - Hi-lift bed mount brackets
    Win!
  4. Jul 2, 2010 at 12:53 PM
    RelentlessFab
    Eric
    Sparks, NV
    I was meaning one that goes between each side of the bed and can hold a hi-lift, lights, cb antenna, etc. But one like you said could be done. :)
    haha, thanks man. :thumbsup:
  5. Jul 2, 2010 at 9:31 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Ah i gotcha now, i see alot of them on here with lights mounted on them. Didnt click when i read it. thanks now a bed bar with two slots for dirtbike tires... thats up my alley haha
  6. Jul 2, 2010 at 11:10 PM
    RelentlessFab
    Eric
    Sparks, NV
    I'll fab any product which I believe I can sell, so a bed bar that can hold dirtbikes could be a possibility for sure man.
  7. Jul 9, 2010 at 2:10 AM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black,.... well faded satin flat black lol, it has 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a tan rings! brush bar with 30 in led light bar , Custom rear Bumper, Straight Pipe. Led Hi/Low, and led fog lights, Flat Black Interior!
    so whats the bed bars look like?
  8. Jul 9, 2010 at 2:18 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    So.......... pics?
  9. Jul 9, 2010 at 3:03 PM
    RelentlessFab
    Eric
    Sparks, NV
    I don't have a pic of the finalized design at the moment. It is a 1" tube, bent to about 45* at each end to raise it a few inches above the height of the bedrails, and has a mounting bracket to tie into the tiedown cleats. They come with 2 tabs for lights standard, and can be placed wherever desired, and front or back of the bar. Additional tabs available. Also, mounting tabs off the bottom can be added to hold a Hi-lift.
    Which part are you interested in?
  10. Jul 9, 2010 at 3:24 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    what all are we looking at for the steel hi lift base?
  11. Jul 9, 2010 at 3:47 PM
    RelentlessFab
    Eric
    Sparks, NV
    You mean cost wise, right Jamie?
    Kinda still TBD, but I'd say around $30-40 + shipping
    They'll be made out of CNC cut 3/16 steel with reinforcing/mounting ribs on top, and a claw at each corner to bite into the ground
  12. Jul 9, 2010 at 8:01 PM
    The_Hodge
    SC
    i'm thinking that too...but also in comparison to the base that is already in the market. i know that the main difference is plastic vs. steel....but u know what i mean? i would love to have a base, but i wouldnt put that money down for a plastic one
  13. Jul 9, 2010 at 8:04 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  14. Oct 7, 2010 at 8:35 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Sent a PM
  15. Oct 7, 2010 at 10:40 AM
    RelentlessFab
    Eric
    Sparks, NV
  16. Oct 7, 2010 at 10:44 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    why dont you make a flippin rack for the AC's yet damn it. :D
    JK, interested in the looks of your final design on these bars.
  17. Oct 29, 2010 at 9:51 AM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
  18. Nov 17, 2010 at 9:42 PM
    munkel
    munkel fka unregistered lurker...
    PDX
    2004 Dbl Cab V6 4WD Tacoma
    Icon Suspension, 285/75/16 BFG MT's, Steeeckers, Custom Bed Mounted Tool Storage, Wilderness Trail rack, SoftTopper, K&N CAI, Hella Aux lights, PIAA Fogs, Warn M8000, Elite Front Bumper, BAMF sliders, All-Pro leafs and shackles
    I would be interested in a tube bed bar but only if it would clear a dirtbike tire in the back even with a hi-lift mounted to it. Anyone done this yet?
  19. Nov 17, 2010 at 9:48 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Any of them, to spark ideas ideas of mine.
  20. Jan 13, 2011 at 11:23 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Any pics of this?
