Other Relentless Fab. products
Discussion in 'Relentless Fabrication' started by RelentlessFab, Jun 4, 2010.
  1. Jul 27, 2012 at 2:19 PM
    #241
    Jib Bandits
    Jib Bandits Pork eating crusader. An "infidel".
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    Red devil horn emblem, All-Pro Expo leafs, Fox shocks, K&N CAI, aFe throttle body spacer, Flowmaster american thunder dual exhuast, Defender roof rack, Hell Bent steel level kit, Rigid Dually LED lights, smoked halo headlights, smoked LED taillights, Cobra CB, red badge mod(+30 HP), Spider-Trax wheel spacers!
  2. Jul 27, 2012 at 2:20 PM
    #242
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Yep I believe thats what most guys do
  3. Jul 27, 2012 at 2:26 PM
    #243
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
  4. Jul 28, 2012 at 11:41 AM
    #244
    JNome
    JNome Made in Maine.... Yessah bub!
    Jake
    Pace, FL
    '10 BSP SR5 4wd
    WeatherTechs, TRD Skidplate, Hidden Hitch Reciever, Tractor Supply Toolbox, Bedmat, Hayden Transmission Cooler, Leer 100R cap, yakima roof rack, Bilstien 5100's all around, Eibach lift coils, Toytec AAL w/ TSB springs, All Pro Flip Kit w/ Timbrens, Line X'd Rocker Panels, Magnaflow 17115 Exhaust, Cobra CB w/ PA Horn, Hi-Lift Jack w/ custom mount, Relentless Fab Sliders, Satoshi Grille w/ Hella 700's HID mounted behind
    Had same issue with mine today... need the right angle thing. Did you get the one that accepts the male end of your coax and then inserts into the bottom of your antenna?
  5. Jul 28, 2012 at 12:01 PM
    #245
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
  6. Jul 28, 2012 at 2:51 PM
    #246
    Sje1124
    Sean
    Louisiana
    Just a few
    So you still have to ground it even though it's on the hood?
  7. Jul 28, 2012 at 3:43 PM
    #247
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    That first coax has the ground terminated out of the cable so you have to run it somewhere. I drilled a small hole in the mount to attach it with an SS mach screw & nylock. I later switched to the 'firering' style (2nd link) coax for reasons of my own stupidity (was trying to get SWR incorrectly and blamed the cable). Also, your hood bolts are painted which can have an effect on how well it grounds. You'll just have to see if you can get your SWR down once everything's mounted, and if you can't maybe re-work your ground situation.
  8. Jul 28, 2012 at 5:51 PM
    #248
    Sje1124
    Sean
    Louisiana
    Just a few
    Ohh ok. I have a lot to learn about all of this stuff then.
    Can you post a pic of how your is hooked up?
  9. Jul 30, 2012 at 12:42 PM
    #249
    shallcallhimtim
    shallcallhimtim Member
    Connor
    Rexburg Idaho
    would the hood mount fit on the 4runners?
  10. Jul 30, 2012 at 1:00 PM
    #250
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Sorry it took me so long to get these, but here's the Firering style coax connection. My SWR isn't as good as it could be (I haven't bared any metal to improve it), but it's reasonable and I have talked with a guy that was 5 miles away and it was loud and clear on both ends.
    From underneath-
    From Above. You can see the hole I drilled for ground when I had the other style coax-
  11. Jul 30, 2012 at 1:22 PM
    #251
    Sje1124
    Sean
    Louisiana
    Just a few
    Sweet thanks a lot. If this connector dosent work that u bought I'll have to get the Firering coax
  12. Jul 30, 2012 at 1:28 PM
    #252
    EVILSTI
    EVILSTI Well-Known Member
    Ray
    Catskill, NY
    1994 FZJ80 / 2022 Tacoma TRD Pro
    2022 Tacoma TRD Pro ......................................... 94 FZJ80 Land Cruiser Slee 6" lift kit 37" KM2s 17" procomp wheels Snorkel .......................................... SOLD: 06 TRD OFF ROAD OME Suspension lift kit with: Front OME 90000 shocks, 886 coils, top plate spacers, complete OME Dakar leaf spring packs, Front Diff drop kit, Rear N182 shocks, OME trim spacer, OME carrier bearing drop bushings, American Racing Chambers 16X8, Yokohama Geolandar A/T-S 285/75-16s (Winter tires), BFG MT KM2's 285/75-16, satoshi grille mod, TRD CAI, AP front bumper, AP skid plate, Cobra 75 WX ST CB, 2' Firestik antenna, Pioneer Avic-U310BT, Beefed Sliders, LR UCA's, Tinted Headlights, AP Rear bumper, DTLTH, Smittybilt XRC10 comp winch, Yellow top D35, pAP custom Transmission Skid ;-) , NFab spare tire holder, DT Pipe Bomb,
    Pmd you for shipping price on 2 bed bars. :D
  13. Jul 30, 2012 at 1:47 PM
    #253
    RelentlessFab
    Eric
    Sparks, NV
    Havent tried fitting one, though I'll have a 4th gen in my shop next week and I could take a look to see if one will fit. :)
    :thumbsup:
    Thanks for the order.
  14. Jul 30, 2012 at 2:14 PM
    #254
    shallcallhimtim
    Connor
    Rexburg Idaho
  15. Jul 30, 2012 at 6:46 PM
    #255
    mccarroll
    mccarroll Well-Known Member
    Newfoundland, Canada
    2012 DC 4X4
    how much for a set of cb ant. hood mounts shipped to Torbay, Newfoundland, Canada? A1K 0C6. I am planning on putting a couple of lights up there too.
  16. Jul 30, 2012 at 7:18 PM
    #256
    RelentlessFab
    Eric
    Sparks, NV
  17. Jul 30, 2012 at 7:26 PM
    #257
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
  18. Jul 30, 2012 at 9:39 PM
    #258
    Sje1124
    Sean
    Louisiana
    Just a few
  19. Jul 30, 2012 at 10:01 PM
    #259
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Because a 'regular' type antenna mount has the coax screw straight into the bottom of the mount like this-
    http://www.rightchannelradios.com/firestik-flat-universal-cb-antenna-mount-pl-259.html
    This causes problems with the relentless mount because of the underside clearance issues. And yes, I'm using a lot of rightchannelradio's links, but that's only because they have an easy access to what I'm referring to. I am in no way connected to them in any way whatsoever other than as one of their customers.
  20. Jul 30, 2012 at 10:33 PM
    #260
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I suggest following my buddy Benson X's build instructions, he did an incredibly detailed instruction thread and makes things very easy to follow. You can also look at my build thread for an alternative method, but I'd do the FireRing attachment if I had to do it over.
