Other than tires......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cajunman_83, Dec 23, 2016.
  1. Dec 23, 2016 at 11:49 AM
    cajunman_83
    cajunman_83 [OP] Well-Known Member
    Kevin
    Cajun country Louisiana
    09 double cab long bed base SR5 4x4
    Tool box, rain guards , decals , K&N CAI , throttle body spacer , FlowMaster exhaust , 4X4 switch mod and tires and rims , pics coming soon !
    I have a 09 DCLB Tacoma. I running some Goodyear Duratracs. Yes the tires aren't great for the ride on the road but I wanting to see what's out there to help smooth out the ride. I didn't know if knew shocks would work or not. I have about 82 thousand miles on it now. Our Louisiana roads aren't the best but I know she could ride better. Any and all recommendations would be appreciated. I'm trying to get my tires to last just one more year then I will be replacing them.
    TXpro4X4 likes this.
  2. Dec 23, 2016 at 12:43 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    What's going on with the ride? Vibes at highway speeds? Rides too stiff? Rides too soft?
    Kyitty and TXpro4X4 like this.
  3. Dec 23, 2016 at 12:44 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Yes more info would be better to help
    Fitz235[QUOTED] likes this.
  4. Dec 23, 2016 at 1:06 PM
    Troyotasportrd
    Troyotasportrd Active Member
    Troy
    2011 Silver Tacoma TRD Sport
    Check your tire pressure, those are probably load range E tires and should be around 35-40psi depending on your truck weight
    Fitz235 and HawkShot99 like this.
  5. Dec 23, 2016 at 1:18 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Are your duratrac's C or E rated? What's your tire pressure? What don't you like about the ride quality?
    Kyitty likes this.
  6. Dec 23, 2016 at 1:24 PM
    cajunman_83
    Kevin
    Running about 35 psi in them , maybe a little more. I do get wheel shake on most roads but it's not uncontrollable. It's that I'm finding the ride in general to be more stiff. The tires have roughly 35 percent tred left.
  7. Dec 23, 2016 at 1:54 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    What load range are the tires?
  8. Dec 23, 2016 at 1:56 PM
    cajunman_83
    Kevin
    I believe E
  9. Dec 23, 2016 at 2:44 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    E rated tires are going to be stiffer. You can try to drop a few PSI to see it that makes a difference.
  10. Dec 23, 2016 at 3:03 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Wheel shake might indicate an alignment problem or a balance problem with your tires/rims.
    A stiff ride could indicate: A) Too much tire pressure. B) Stiff suspension.
    Do you have any kind of aftermarket lift, shocks, coil springs, spacers installed?
  11. Dec 23, 2016 at 4:07 PM
    cajunman_83
    Kevin
    Running no aftermarket products on my suspension. Under the hood is a different story but I tried different tire pressure. Tried balancing the tires multiple times. An alignment might be the way to go.
  12. Dec 23, 2016 at 4:10 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    There's balancing... and then there's Road Force Balancing.
    One works on Tacomas and the other doesn't.
  13. Dec 23, 2016 at 5:14 PM
    cajunman_83
    Kevin
    Need to find me a shop around here that does that road force balancing. I thank y'all. Surely didn't know about that type of balancing for the tires.
  14. Dec 23, 2016 at 8:25 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Personally, if your tires are almost done I wouldn't waste the money getting them balanced.
    Crazydave likes this.
  15. Dec 23, 2016 at 8:45 PM
    badger
    badger Well-Known Member
    07 SR5
    35 PSI should be perfect for your truck. It could be tire balance, but I would also check your tie rods ends, inner and outer, for wear. Your shake could be coming from there. I cannot imagine your stock suspension being too stiff!! More than likely, it is so soft that it is landing on the bumpstop at every pot hole. Take a look and see how much room there is between your bump stop and the lower control arm. I'll bet it is very close.
  16. Dec 23, 2016 at 9:21 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    82k on the stock shocks? Plus e-rated tires? Yeah, that's not going to be the greatest ride.
