OTT tune question
Discussion in 'Performance and Tuning' started by rbdudeman, Jun 22, 2024.
  1. Jun 22, 2024 at 9:05 AM
    rbdudeman
    rbdudeman [OP] Well-Known Member
    I'm looking to have the OTT tune this week. I've done a lot of forum reading regarding the tune. Looks like a lot of guys from what I've read have gone with the mild - moderate tune. From what I understand the mild is the daily driver that improves the stock experience, the moderate is the ECT button which gives more 'pep' when needed. With that understanding, it seems doing a moderate for the daily driver would be better than the mild. What's the argument to stay with mild over moderate. Is it a huge mpg hit? Any other negative's? Thought's?
  2. Jun 22, 2024 at 3:20 PM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    Your tuner will ask what settings for throttle you want, after it’s tuned go take a test drive and see how you like it. It will take a little getting used to, if you are kind of heavy with your right foot the more mild setting will probably be ideal.
    Where you are going to see improved MPG is cruising on the highway and the ability to stay in 6th longer. Premium fuel will help with this as well, although not required.
    JustDSM likes this.
  3. Dec 27, 2024 at 6:51 AM
    jrhzn
    jrhzn Well-Known Member
    Westminster MD
    2015 TRD PRO
    Icon stage 10 suspension, Falken Wildpeak AT3 33” tires, Leer Cap, AuCar Headunit, Morimotyo headlights and more.
    my buddy and I both got the OTT tune done. His is a 2022, mineca 2015 both are experiencing significantly improved performance, but only marginal MPG increase.
