OTT tune vs. OEM
Discussion in 'Performance and Tuning' started by Captains1911, Jul 17, 2023.
  1. Jul 17, 2023 at 3:31 PM
    Captains1911
    Captains1911 [OP] Well-Known Member
    2023 Tacoma TRD OR 4x4 AT DCSB
    I’m considering the OTT tune for my ‘23 OR AT, and have done a fair amount of research regarding the pros while finding virtually no cons, which really begs the question…
    If this tune (or any aftermarket tune for that matter), is so much better than OEM, then why is the OEM tune what it is? It can’t be a cost issue for Toyota, we’re just talking about computer code, right? There has to be some benefit to the way it’s tuned from the factory, I just don’t understand what it is.
  2. Jul 17, 2023 at 3:37 PM
    HKD LA
    HKD LA Member
    Probably a “why fix something that’s not broken?” OEM tune has proved itself through sales numbers, previously performed R&D.
    If they put a new tune in then more $$$ dedicated to R&D and then they are on the hook if something with the tune is messed up.
    Not sure if the real answer… just thinking out loud.
  3. Jul 17, 2023 at 3:37 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Fuel consumption. Toyota does the factory tune to eck out every last 0.1 mpg on the EPA drive cycle to meet CAFE requirements.
    The EPA drive cycle often doesn't match your actual drive cycle (for example, it never goes above 60 mph), so you may see no fuel economy hit.
    SoCaltaco65 and t2c like this.
  4. Jul 17, 2023 at 3:44 PM
    Captains1911
    IF something is messed up. That’s a big IF. That’s what I’m wondering, is this more of a gamble than it’s worth?
  5. Jul 17, 2023 at 3:44 PM
    Captains1911
    Most reports I’ve read say this tune improves fuel economy.
  6. Jul 17, 2023 at 3:50 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^On my 4Runner, the 5 tanks immediately before the OTT9 tune averaged 16.4 mpg, while the 5 tanks after the tune averaged 16.0 mpg, so it's 2% worse on my drive cycle (50 miles rush hour highway grind at mostly walking pace). This is with 87 octane.
    tcjacado likes this.
  7. Jul 17, 2023 at 4:00 PM
    KorbenMyMan
    KorbenMyMan Active Member
    E Tex
    2018 Tacoma SR5
    Way too many to list
    Simply put, engineers programmed the Tacoma’s ECU to seek out the lowest functional rpm at all times. This is what causes the gear skipping/hunting that we experience. This was done to maximize fuel economy in order to appease the EPA gods. It doesn’t seem to hurt sales because people either learn to live with it or seek out tuning since it’s a relatively simple and affordable fix. Toyota hasn’t made any efforts to improve it because their numbers aren’t hurting.
    In other words, it be what it be.
    ricphoto likes this.
  8. Jul 17, 2023 at 4:15 PM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    It's not that simple. Everybody drives their truck a little differently: I drive mountain roads at 8500ft where the naturally aspirated engines can struggle and has to work a little harder and I spend most of my time between 45-65 mph. Others spend 90% of their time driving a highway at 70. Others spend 90% of their time in the inner city driving at 35mph in stop and go. Some of us will gain fuel efficiency with a tune and some of us will lose it.
    Toyota's engine tuning optimizes for the EPA drive test which is a very specific test designed to mirror typical driver behavior. But none of us are typical drivers, by definition, because that's just an average not a reality. OTT and others tune for you and for your drive style. That's why each tune has a variety of options and why different tunes can co-exist in the same ecosystem without there being an obviously dominant tune.
    offroadguy651, Vlady and tcjacado like this.
  9. Jul 17, 2023 at 4:23 PM
    tcjacado
    tcjacado Well-Known Member
    It has to do with epa emissions and the consumption of fossil fuels. Not to get political, and trust me I don't want to go there. The people we have elected, make the decisions for the masses. You ever hear, you can't make all the people happy at the same time?
    Now for a bit of comedy.
    :D
  10. Jul 17, 2023 at 4:27 PM
    raidercraig
    raidercraig Well-Known Member
    Few days with KDmax 10.0 tune couldn’t be happier. It’s a new driving experience
  11. Jul 17, 2023 at 4:29 PM
    tcjacado
    Bro.BRO! Bro!. We don't live by mpg. It's smiles per gallon. Your truck looks the way you want it, bite the bullet on mpgs.
    Unless you are completely stock off the factory floor. No reason to complain, if the truck makes you happy.
    TacoTime55 likes this.
  12. Jul 17, 2023 at 4:59 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    If you’re even considering this tune or any tune, then you’re not satisfied with the OEM tune. There’s only one way to find out .
    Xx_Evilvirus_xX and tcjacado like this.
  13. Jul 17, 2023 at 5:07 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I've had the OTT tune for about 2 months now. I'm still very happy with it.
  14. Jul 17, 2023 at 5:36 PM
    Captains1911
    I bought my truck in Nov and I only have 5000 miles on it, I don’t drive much. But, my biggest complaint is what feels like no power when hitting the throttle from a full stop. The gear hunting and whatever else people tend to complain about with the transmission doesn’t bother me much, but, I can’t stand how weak it feels off the line.
    However, at the same time, I’m not willing to risk reliability or longevity of my truck for this issue, I plan to keep it a while and can learn to live with it if it’s the safest bet.
  15. Jul 17, 2023 at 5:44 PM
    Captains1911
    I agree. My only point in mentioning fuel economy is that most say the tune tends to improve it. My interest is in understanding the negatives.
  16. Jul 17, 2023 at 5:45 PM
    Captains1911
    thanks for the explanation.
  17. Jul 17, 2023 at 6:18 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    This has been discussed a ton.
    My bet is it’s just a financial decision by Toyota. Toyota spent a lot of time and $ getting each calibration ID through SEMA and CAFE (California). Once they’ve spent the $ there for each calibration ID to get certified, they are somewhat boxed in for the changes they can make without having to do costly recertifications. Toyota sells ~250,000 Tacomas every year and is leading mid-size truck sales. Why would they spend any of their $ to fix it when there is no return on that investment? It would only cost Toyota additional $ to pay their dealers to reflash trucks under warranty on top of spending the $ to recertify each calibration if needed. And there is an aftermarket satisfying customers, and they’ve moved onto the 4th Gen. It’s simply a business/financial decision by Toyota. If 3rd Gen sales were terrible and they were losing market share, it would have been fixed by Toyota.
    33yrsoftoys and tcjacado like this.
  18. Jul 17, 2023 at 6:42 PM
    33yrsoftoys
    joel
    mid Michigan
    I think you're spot on. I think it would be obvious to Toyota that these tunes exist by now. I haven't heard of one person that's been "turned down" for warranty work, based on a tune though. I think all of these tunes are working "within" Toyotas acceptable parameters without them having to recertify.
  19. Jul 17, 2023 at 8:06 PM
    tcjacado
    More people have been turned down for warranty work based on dirty engine bays than based on the truck being tuned.
    bulalo and BortisYeltzen like this.
  20. Feb 5, 2024 at 9:01 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I’ve got 87K and my extended warranty just ended. I’ve set an appointment to get an OTT tune job in a few weeks when the tune-guy is passing through town. My nephew got this on his 2021 a few months ago and brags about how much better the truck drives. He drives 20 miles each way to work with some hills and claims better shifts and a 1 mpg improvement so far around town.
