OTT Tune
Discussion in 'Performance and Tuning' started by Taco821, Oct 13, 2023.
  1. Oct 13, 2023 at 2:24 PM
    Taco821
    Taco821 [OP] Well-Known Member
    I currently have the OV Tune on my 3rd gen. I got it a couple years ago. I met up with someone off Facebook and got my truck flashed. It solved my problem of gear hunting...but it created a new problem. When taking off from a stop light the throttle doesn't respond when I first begin pushing the gas pedal then once it does respond it is jumpy...not a smooth easy throttle. Anyone else had that same issue?? I am considering getting the OTT Tune. Will that correct the throttle??
    Thanks in advance.
  2. Oct 13, 2023 at 2:45 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Ott and I'd say all the other tunes will correct for that. Tunes have come a long way since the OVTune days.
    I'm a KDMax tuner, if you're interested I can send you the contact info of your nearest tuner or you can find that info manually on our respective websites
    KDMax: https://kdmaxprotuning.com/locations
    OTT: https://overlandtailor.com/retailer-locations
    Along with on our respective Tacoma world threads under the performance section
  3. Oct 13, 2023 at 2:51 PM
    Taco821
    Is the weird throttle response I described common in the older OV Tunes or is it just mine?
  4. Oct 13, 2023 at 4:46 PM
    joba27n
    Nolan
    Alberta
    It is common with the older versions of all the tunes.
    However because by the way it's written i'm feeling that it's a newer concern compared to when you were initially tuned, I would also recommend cleaning your throttle body. Use either carb cleaner or preferable throttle body cleaner. Don't use brake clean though, it could compromise the throttle body.
    If you've never cleaned a throttle body before, "the car care nut" on youtube has an excellent video on how to do it properly on drive by wire vehicles.
  5. Oct 13, 2023 at 4:48 PM
    Taco821
    It's always been that way. I've just dealt with it.
  6. Oct 13, 2023 at 6:06 PM
    joba27n
    Nolan
    Alberta
    I would still clean your throttle body as general maintenance but, also a more modern tune will sort you out well for sure.
  7. Oct 13, 2023 at 8:11 PM
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    RCTuningFL likes this.
  8. Oct 17, 2023 at 3:05 PM
    RCTuningFL
    RCTuningFL OTT Florida Tuner
    RC Tuning FL
    Melbourne / Brevard County, FL
    2020 Tacoma TRD Pro @rctuningflgarage
    OTT + Magnuson Supercharger - 5.29s etc etc.
    Stick with OTT. Proven and honest results unlike other options out there trying to cockaroach their way into posts.
    LukeLifts, GilbertOz and 3GTCMLMTD like this.
  9. Oct 17, 2023 at 3:16 PM
    RCTuningFL
    RC Tuning FL
    100%. More and more customers are confirming their tunes on the dyno. They are quickly finding that what they were told or promised isn't true... and even worse making less power than stock o_O
  10. Oct 17, 2023 at 3:57 PM
    3GTCMLMTD
    2022 Limited
    LOL, yep. Thankfully, more and more are catching on to that fact before giving away that amount of money.
  11. Oct 17, 2023 at 7:18 PM
    joba27n
    Nolan
    Alberta
    I gotta say, I notice the OTT gang goes into attack mode very easily. Fair enough though, creative marketing does make you and your product stand out which is the idea I guess
    Magiriano and QwickC like this.
  12. Nov 19, 2023 at 11:10 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    came across this thread. ive had the ott founder tuning my truck from day 1 after abandoning the ovt tune bs. best tuning support ever. got my very particularly modded truck to run like a champ. sorry to hear anything but amazing feedback. id urge people to reach out to ott and solve issues. ive been nothing but happy and would refer anyone.
    mine is a heavily modified s/c 2nd gen truck fwiw.
  13. Nov 19, 2023 at 11:20 AM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    I can vouch for OTT as well!
    Got my truck tuned a month or more ago and it was far and away the best thing Ive done to my truck.
    100% recommend.
    No jerkiness, delay or any other throttle issues. Just great on demand power with 0 gear hunting.
  14. Nov 19, 2023 at 11:33 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    +1 on the OTT Tune since May 23, 2022.
    Currently on V9, Mild Drive/Spicy ECT.
    Got my fist patch too!
    33yrsoftoys likes this.
  15. Nov 19, 2023 at 3:58 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I've been running the OTT tune for awhile now myself. Your OTT patch is pretty cool. If you don't mind me asking, how do you get one.
    TacoTime55[QUOTED] likes this.
  16. Nov 19, 2023 at 4:51 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    My Tuner, Master Yota hooked me up!
    Ask your tuner if they have any to spare.
    33yrsoftoys[QUOTED] likes this.
  17. Nov 19, 2023 at 5:25 PM
    33yrsoftoys
    joel
    mid Michigan
    Thanks! I'll give him a shout out. By the way, I'm right with you on the OTT tune. Best mod I've done so far. The extra torque between 2000-3000rpm is a huge deal for me. Very noticeable with the MT. :thumbsup:
    3GTCMLMTD and TacoTime55[QUOTED] like this.
  18. Dec 22, 2023 at 12:03 AM
    3GTCMLMTD
    2022 Limited
    If you didn't know about this site, there are more than just patches that you can purchase here:
    https://overlandtailor.myshopify.com/
    JustDSM and 33yrsoftoys[QUOTED] like this.
  19. Dec 22, 2023 at 4:06 AM
    33yrsoftoys
    joel
    mid Michigan
    I've been on the OTT site before and wasn't aware of this until now. Thank you!:thumbsup:
    3GTCMLMTD[QUOTED] and JustDSM like this.
  20. Dec 22, 2023 at 8:06 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    If you’ve been tuned with OTT; reach out to your tuner, as he may have a discount code he can give you!
