OTT Tune
Discussion in '4th Gen. Tacomas (2024+)' started by Gmak621, Apr 24, 2025.
  1. May 23, 2025 at 7:08 AM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    It’s all about what you want out of a vehicle. I purchased new 2015 BMW X5 M sport twin scroll turbo and within one month I installed a tune to increase HP by 120 and tq by 80. I still own this X5 10 years later with the tune. It drives fast, powerful in all speeds, and very torquey. It’s all about more power and smoother power delivery. I have the hybrid TRD OFF-ROAD with 326 HP and 465 TQ. I will always welcome more power if it can be had safely and reliably. These turbo engines are built for it.
    WilliamJames likes this.
  2. May 23, 2025 at 7:25 AM
    GrrrMaker
    GrrrMaker 2024 Tacoma SR5 4x4
    Woodstock, GA
    2024 Celestial Silver SR5 4x4
    DV8 OE Plus Side Steps MCX Skid Plate Bonobo Front Recovery Points Bonobo Hitch Recovery Point (2" Soft Shackle) Redline Hood Struts Volume Knob for 8" Infotainment Screen (TacoMods on Etsy)
    Completely understand your points there and agree in principle. Does the tune affect the factory warranty?
  3. May 23, 2025 at 7:49 AM
    deuce189
    deuce189 Well-Known Member
    Kev
    Charleston, SC
    2019 Cement SR5 Prerunner *SOLD*
    Hunting for a 4g
    Is there anywhere that states the estimated hp/tq number increase between the hybrid and non-hybrid? I was holding off on my decision to go hybrid or not based if a non hybrid after a tune is quite comparable to a hybrid engine and/or how far off the numbers between the two tune to tune.
    Taco Ji likes this.
  4. May 23, 2025 at 8:03 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    deuce189[QUOTED] likes this.
  5. May 23, 2025 at 8:07 AM
    Goin2drt
    Goin2drt Well-Known Member
    Yes it absolutely will if you have any engine issues and potentially transmission or other powertrain issues. If Toyota can make the stretch that your tune broke something, they will.
    WilliamJames and TurboDA6 like this.
  6. May 23, 2025 at 9:11 AM
    TurboDA6
    TurboDA6 Well-Known Member
    Vehicle manufacturers have the right to deny a warranty claim if they are aware of a tune.
    However, they don't go looking for a tune unless they have a reason or policy to do it. The ECU won't show a tune through normal scanners. There's an involved process to deep scan and ECU with with a manufacturer specific software system. Typically this is a step they don't perform unless they suspect something, as it adds cost and time to the repair.
    Additionally, the dealership has some say in requesting a scan for tune. They usually won't.
    I had a tuned up GTI, the DSG transmission failed. VW replaced the transmission under warranty, no questions asked, but I was also prepared to accept that they could decline me. They didn't ask or look.
    People will claim that a tune is "invisible", that is true for the typical scanner. But OEMs can see how many times your ECU has been reprogrammed. Even returning back to stock, the counter will keep track. This is a value in the ECU that can't be reset or changed, even by the OEM. The counter will be at zero or one for the stock tune. Any counts above the stock tune lets the OEM know it's been modified.
    WilliamJames and Goin2drt like this.
  7. May 23, 2025 at 10:01 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    The Denso ecu’s in these platforms have no flash counter, fwiw.
  8. May 23, 2025 at 11:03 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    say if toyota was going to do a reprogram of the ECM for whatever reason wouldn't it show an unrecognized program in the ECM?
  9. May 23, 2025 at 11:25 AM
    Taco Ji
    New Jersey
    This guy knows what’s up.
    For 10 years I’ve serviced my X5 with a tune and I’ve had zero issues.
  10. May 23, 2025 at 11:44 AM
    JustDSM
    Justin
    Ogden, UT
    With our Calibration and flashing methods, it will not lock out a dealer from performing a critical TSB update or recall.
    Should there be a factory update, if applied it will overwrite our calibration. We can however reapply the calibration (with all the factory updates) if desired. No charge.
  11. May 25, 2025 at 3:39 PM
    bigd9247
    bigd9247 Well-Known Member
    WA
    2024 TRD ORP, 2018 F150
    Thanks for the info! I got mine tuned today by PNW Tuning. I went with the "Base" throttle and stage 1. So far it's a nice improvement. I'm looking forward to putting some more miles on it next week.
  12. May 25, 2025 at 4:07 PM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    @Gmak621 hows boost in 1-2nd compared to stock? More early boost or still not much till 3rd gear in normalish driving?
  13. May 25, 2025 at 4:58 PM
    JustDSM
    Justin
    Ogden, UT
    1st will still be limited (but more than) stock. 2nd will be raised but still slightly less than 3rd-8th.
    We're working on a patch that will address this for future updates, but we're still in development on that.
    Norsk and Gmak621[OP] like this.
  14. May 25, 2025 at 7:13 PM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    When you buy the tuning pack, can you mix and match the throttle curve with the engine tune? Say, if I wanted to keep the stock throttle curve but flash the Stage 1 tune?
    The stock throttle feels reasonably linear to me -- can OTT confirm? Manual transmission here (not sure if the auto/manual has different throttle curve).
  15. May 25, 2025 at 7:16 PM
    #35
    JustDSM
    Justin
    Ogden, UT
    Stock throttle is pretty linear, yes.
    And yes, you can retain the OE throttle mapping entirely within the Stage 1 calibration; that's a standard option.
    Goin2drt and BearWithMe[QUOTED] like this.
  16. May 26, 2025 at 3:22 AM
    #36
    BaltimoreMD
    BaltimoreMD Well-Known Member
    4gen Taco Ltd HV
    If this resolved the indecisive shudder on the hybrid in the 37-47mph range without a negative mpg effect, is pretty much be sold. Never realized how much driving was in that range until I had this. No clue whether it's fighting a gear change choice or a ice vs hybrid choice. Haven't been able to tease it out and dealer claims unable to replicate even though the tech did a drive along and confirmed they felt it.
    I do not believe it has anything to do with the TSB that some panic about.
  17. May 26, 2025 at 3:20 PM
    #37
    pnwoctane
    pnwoctane Active Member
    2024 Tacoma TRD Offroad Solar Octane
    Hey I was looking to do the same with PNW tuning. What are the biggest things you noticed immediately after tuning?
  18. May 26, 2025 at 5:53 PM
    #38
    bigd9247
    WA
    I need to put more miles on my truck before I can give you a fair review, but right off the bat it's more responsive and seems to use the turbo more frequently. Paul at PNW Tuning was a very nice guy and I'd highly recommend using him for your tuning.
  19. May 26, 2025 at 10:27 PM
    #39
    TurboDA6
    This sounds like drivetrain protection.
    I own a non-toyota truck with an impressive amount of power, but the tune keeps all that power at bay until around 40 mph, and it appears to be because the OEM is trying to protect the drivetrain, at least through warranty.
    We now have a tune that gives all the beans in lower gears, but can the drivetrain take it?
  20. May 27, 2025 at 9:55 AM
    #40
    JustDSM
    Justin
    Ogden, UT
    The hybrid models (with more torque) do not have this load limiting and allow "all the sauce" from the get-go. Note the hybrid models also use the same drivetrain.
    It's there to keep the hybrid vehicles feeling 'more powerful' IMO to justify the increase in cost.
