OTT vs the rest
Discussion in 'Performance and Tuning' started by BillyE, Jul 3, 2023.
  1. Jul 4, 2023 at 6:20 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    We use a VVT schedule that provides similar part throttle output as the SFOB tunes.
    Junkhead and 33yrsoftoys like this.
  2. Jul 4, 2023 at 6:30 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yes!
    That’s what actually surprised me the most, way more power but MPGs were actually better than when my truck was stock. I noticed the engine starts quicker too and that power surge at 3500k RPMs is gone, it’s smooth throughout the RPM range. There is an occasional “buck” or two when in second gear at like 1000ish RPMs while giving it quarter or so throttle, doesn’t bug me though.
    Now with 33s, lift and 650# of constant weight, I’m still able to get advertised MPGs if driving conservative. IMHO Atkinson cycle idea was a complete fail. Thank you mr OV Tune!
    33yrsoftoys[QUOTED] likes this.
  3. Jul 4, 2023 at 6:43 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I get that same little "bump" at low RPM 's too. Once I got used to it I was able to work around it for the most part. I'm running 6112-5160's and around 2 3/4" of lift. 285/70/17 nitto Terra's, which have the lowest rolling resistance of any tire I've ever dealt with. 44.5lbs apiece. I'm still getting 22+ MPG's on 55-60 mph roads with the OTT tune. Very happy.
    JustDSM and Junkhead[QUOTED] like this.
  4. Jul 4, 2023 at 6:52 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I’ve tried multiple different tunes with an MT and honestly, I can not tell a power difference between any of them or stock. They all felt mostly the same, but with slightly different amounts of throttle sensitivity…that’s about it. Obviously stock throttle sensitivity was much different but the overall power felt the same. Anyways, I decided on stock after spending lots of money and time on tunes. :notsure: Many folks are happy with their tunes, especially OTT, so I am the odd man out.
    But, I did regear and that made a huge difference in a positive way, so I stuck with that for my use.
    33yrsoftoys and Junkhead like this.
  5. Jul 4, 2023 at 6:54 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    My truck drove just fine on a stock tune to be honest, my biggest complaint was poor throttle response for rev matching.
    Quite a few guys were raving about this tune on TW so I decided to try it. I’ll tell you for sure that im not going back.:)
  6. Jul 4, 2023 at 6:59 PM
    BLtheP
    Plano, TX
    When I had stock gears, I was happy enough with tune life. Now that I’m considerably lower than stock, the tunes being eager to get moving make it really hard to control my low 1st gear at times. I am certainly capable of driving it normally with gears + tune but it’s just a lot more effort on my part. I am much more smooth with stock and as long as I rev it to where it makes some power, I have no complaints. I just find it a lot easier to drive on stock calibration.
    I do want to swap to the RC60F/RC61F transmission eventually for even lower 1-2-3-R and taller 5-6. But that’s far in the future, if ever.
    Junkhead[QUOTED] likes this.
  7. Jul 4, 2023 at 7:01 PM
    33yrsoftoys
    joel
    mid Michigan
    Check this out. This is before adjusting for MPG's for tire size. Central Michigan flatland. I'd be shocked if elevation changes 5ft the whole trip. One town, 3 stoplights and 6 stop signs. 55-60 mph. This is after the OTT tune. Very happy.
    Junkhead[QUOTED] and Amorak like this.
  8. Jul 4, 2023 at 7:14 PM
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    I get 24 mpg regularly in my stock truck and average over 12mpg when towing a 5k TT.
    I considered a tune but I’m happy with the power, just need to rev it. Biggest thing would be getting 3rd gear to lock up 100%, that I’d pay for. Can cruise in 5th, 1,700rpm @63mph whilst towing quite comfortably.
    This dash screenshot was driving from Bend, OR to Reno, NV on one tank, 3.7 gallons remaining. Plenty of hills, got 24mpg on the return too.
    This was towing a 5klb TT from Spokane, WA to Bend, Or. plenty of hills too.
  9. Jul 4, 2023 at 7:24 PM
    33yrsoftoys
    joel
    mid Michigan
    24mpg for a stock AT doesn't shock me and is really good too. I can't tell you what I would have gotten stock as I lifted it shortly after I bought it new. I very probably wouldn't have gotten my tune with the MT if I hadn't bought my camper. I wasn't unhappy with the way the truck drove before. Now that I did I wouldn't go back. The extra torque between 2000-3000rpm is a game changer.
    Junkhead likes this.
  10. Jul 4, 2023 at 7:50 PM
    mosccat
    Mark
    2020 OR
    I towed 8k miles last year and the biggest issue I have with this truck is 3rd gear not locking up.
    I’m from England and have driven manuals my whole life but I was unable to get the truck
    I wanted in a manual so I went with the auto, had I realised I would buy a camper a couple of years later I may have bought a different config and got a manual. 3rd gear not locking is a big thing but the truck towing did fine, just need to set expectations and understand where this truck makes it’s power and understand the torque converter. On my dashboard above, the red circle behind the gear turns green when the TC is locked. This helps considerably with mpg and temps.
    Junkhead and 33yrsoftoys[QUOTED] like this.
  11. Jul 4, 2023 at 8:06 PM
    33yrsoftoys
    joel
    mid Michigan
    I haven't had a chance to get a good read on my MPG's pulling my camper yet. I've only done an 80mi round trip with it so far but I can say it pulls it way better. It looks like it'll be around a 2mpg gain. Before I had to do kinda like you, rev it. I had to stay in 4th, which is 1/1 and it pulled ok. After the tune I can pull in 5th, which is the first overdrive, and I can actually accelerate. Had a slight headwind too. The instant mpg guage told me I wasn't straining the engine at all. That will make a big difference pulling on the highway at higher RPM. If it was me I'd have a conversation with Justin about that converter lockup and see if there's anything they can do for you.
    BortisYeltzen likes this.
  12. Jul 4, 2023 at 8:45 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    That's some golden good stuff right there - thank you!
    But a question then. My cross over pipe where the exhaust runs under the transmission, it's pretty pinched through there - from the factory. Are you saying that's OK too? If so I'm glad but also surprised and amazed.
    JustDSM[QUOTED] likes this.
  13. Jul 5, 2023 at 3:47 AM
    OBXPaul
    OBXPaul Just do what you say you're going to do!
    Paul
    Kill Devil Hills, NC (Outer Banks)
    2016 Black Tacoma Limited, 1983 Blue Deluxe Pickup
    1983 restoration in progress, major mods so far new 6" lift and 35" Mickey Thompsons.
    What app do you use for the screen shot you have the picture of?
  14. Jul 5, 2023 at 8:01 AM
    mosccat
    Mark
    2020 OR
    OBD fusion with the Toyota pack.
  15. Jul 5, 2023 at 8:22 AM
    #35
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    same area (central michigan), with the KDMax v10. noticeably more mpg's than your example. every truck reacts different. do your research. Ski
  16. Jul 5, 2023 at 8:31 AM
    #36
    mosccat
    Mark
    2020 OR
    If we’re comparing short distances… stock tune…
    33yrsoftoys and disk_55FL like this.
  17. Jul 5, 2023 at 8:57 AM
    #37
    Crash415
    Crash415 Well-Known Member
    22 TRD OR MT
    I had my OTT tune appointment this morning. The tuner never showed up. That was a nice waste of time
  18. Jul 5, 2023 at 9:30 AM
    #38
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    Are all 6MT OTT tunes SFOB or is it an optional “thing” on request?
    Also I am a little unclear with all the acronyms and such that get thrown around; is OTT the specific tune, and OV Tune is the tuner, or are they separate beasts?
    Junkhead[QUOTED] and BillyE[OP] like this.
  19. Jul 5, 2023 at 10:08 AM
    #39
    JustDSM
    Justin
    Ogden, UT
    Who were you scheduled with?
    All OTT tunes use the same VVTi mapping, it's no extra or special feature that needs to be requested.
    OTT is a separate brand/tune than the OVTune (including the SFOB variant).
  20. Jul 5, 2023 at 10:36 AM
    #40
    33yrsoftoys
    joel
    mid Michigan
    That's really good mpgs. I'd say it's apples to oranges though. MPG's adjusted for tire size difference it's actually 22.6. My truck is lifted almost 3" with 33" tires. I did do my research.
    Junkhead and mosccat like this.
