OTT
Discussion in 'Technical Chat' started by dirt clod, Feb 1, 2025.
  1. Feb 1, 2025 at 12:27 PM
    dirt clod
    dirt clod [OP] Active Member
    Greg
    2023 Tacoma
    I’m considering an Ott. Once it’s programmed, is it a forever deal ? Or is it possible loose it ?
  2. Feb 1, 2025 at 12:47 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'm assuming you mean a tune by Overland Taylor Tuning?
    One a tune is flashed/programmed to the ECM it's permanent unless the ECM is replaced or the ECM is reflashed/reprogrammed with the stock tune or a different tune by say a dealer in the event of a TSB/recall that has an accompanying programming update or another tuner/tune device.
    JustDSM and dirt clod[OP] like this.
  3. Feb 10, 2025 at 3:14 PM
    dirt clod
    Greg
    2023 Tacoma
    So how long does the Overland Taylor Tuning procedure take ? 1/2 hr, 2 hrs
  4. Feb 10, 2025 at 3:15 PM
    OLDTRAP
    OLDTRAP Well-Known Member
    2021 TRD OR
    Stock
    4-6 minutes.
    dirt clod[OP] likes this.
  5. Feb 10, 2025 at 3:41 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Depends on what we’re tuning. It can range from a few min to load a file, to several hours depending on the build and ECU we’re working with.
    Typical naturally aspirated trucks with typical bolt ons using our base files only take a few min to actually write the file. Your retailer will generally be able to assess your build config. and driving needs/habits and get you set on the first attempt. But if adjustments are needed after a test drive, those can be made.
    Typically, the real long appointments are reserved for the heavily modified supercharger configurations.
