Ouch! Broke My Under Hood Fuse Box
Discussion in 'Technical Chat' started by ClickBoomWasted, Mar 19, 2010.
  1. Mar 19, 2010 at 3:29 PM
    ClickBoomWasted
    ClickBoomWasted [OP] Member
    Knoxvegas, Tennessee
    97 Tacoma 5 Speed Lowered
    lowered, 225/40 18s on the front 245/40 18s on the back
    i was jump starting my battery today (left my interior light on) with one of those rechargeable jump starters and i dropped right on my fuse box :mad:
    anybody ever replace one of these?
    do i need to find one that has the same options as mine? (which is almost zero)
  2. Mar 19, 2010 at 7:22 PM
    ClickBoomWasted
    bump i need this info Please!
  3. Mar 19, 2010 at 7:25 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I would imagine that any cover for the same year would be fine- The options and extra fuses don't make the cover fit any different.
    Try a junk yard or toyota used parts website??
  4. Mar 19, 2010 at 7:32 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    x2^^ junkyard probably ur best bet
  5. Mar 19, 2010 at 7:33 PM
    ClickBoomWasted
    the cover was gone its the actual fuse block itself
  6. Mar 19, 2010 at 7:42 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    What broke then?? The mounting points?? the block itself?? (Photos would be awesome)
    You should be able to get any fuse block for the right year/engine and just replace fuses you need for the options you do have.
  7. Mar 19, 2010 at 7:51 PM
    ClickBoomWasted
    the mounts were already broke lol
    the plastic is cracked but the truck still runs no problem
  8. Mar 20, 2010 at 7:05 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Well- If the truck still runs- You could probably just seal the box up with some silicone and get a cover- Call it good.
    Or find a box and cover from a junk yard or someone on here who has wrecked a rig.
  9. Mar 20, 2010 at 7:15 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    First off, how in the hell did you drop the charger on the fuse box? You're not Charging Under the Influence are you?
    Second, I would think it would be less of a hassle to repair the mounts and re attach the fuse box. Also for christ's sake man, get a cover.
  10. Mar 21, 2010 at 9:52 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  11. Mar 24, 2010 at 7:47 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    ^Post some pictures please.
  12. Jul 15, 2013 at 5:25 PM
    tacomeontherange
    tacomeontherange this ain't no picnic
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    I just had to replace my AC relay (aka MG CLT) -- got the mitsubishi part off ebay for like $12 -- and discovered that the lid on my under the hood fuse & relay box is not well seated and that the plastic latch mechanism is kaput. Must have happened under first owner or when they did my frame swap.
    BTW: a few months back I had to replace the check valve control relay or something like that which threw a code. The AC relay doesn't throw a code but makes the AC button light flash (see other threads about that specific issue).
    anyway. I am checking in to this thread because the parts in question seem to be:
    82741-04020 FUSE & RELAY BOX
    82741-04010 FUSE & RELAY BOX
    82662-04040 FUSE & RELAY BOX UPPER COVER
    82662-04050 FUSE & RELAY BOX UPPER COVER
    82663-04010 FUSE & RELAY BOX LOWER COVER
    82730-04050 JUNCTION BLOCK
    If anyone has any ideas on how I can secure my existing lid and housing let me know. hook & eye latches? I'm thinking that anything that's adhesive based (velcro or whatever) is not going to survive the under hood heat.
    ideas?
