Our AC system SUCKS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 30, 2018.
  1. Jul 3, 2018 at 8:42 PM
    #261
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    New condenser/drier assembly, high and low pressure hoses etc out the door $1064.00. The killer is you need to replace the drier and the drier is connected ( part of the condenser ). My condenser was actually fine it was the drier that had the issue, but it is physically part of the condenser and not separate as it is on most vehicles. Condenser/drier alone was $600.00.
  2. Jul 3, 2018 at 8:44 PM
    #262
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    My compressor also "clunks" loudly when I turn it on after it has been sitting for a while, not running. An expert in the HVAC industry I know told me it's probably the clutch. We did some research, and apparently it's not possible to buy the clutch and the compressor separately.
    I plan on keeping my Taco for a long time, so getting replacing a bunch of A/C parts might be worthwhile...
  3. Jul 3, 2018 at 8:46 PM
    #263
    PennSilverTaco
    Charlie
    Still cheaper than a new truck...
    Did that include refrigerant and the state sales ripoff, I mean...uh, sales tax?
    LocoLocal likes this.
  4. Jul 3, 2018 at 8:46 PM
    #264
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Some guys might be more adventurous and try retrofitting bigger components and trying different things, but to me you're pretty limited to what came stock with the truck. Once you change the size of one component you have to change everything else to match the increased displacement . it's not just as simple as throwing a bigger compressor in it when everything else is normal size
  5. Jul 3, 2018 at 8:47 PM
    #265
    PennSilverTaco
    Charlie
    Is the compressor in the 2.7L any different from the 4.0L?
    b_r_o[QUOTED] likes this.
  6. Jul 3, 2018 at 8:49 PM
    #266
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Honestly I'm not sure @Jimmyh might have access to that info
  7. Jul 3, 2018 at 8:51 PM
    #267
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    And it might simply come down to the size of the passenger cabin on the vehicle. a big stretched-out sedan or a van is going to have the capability for better Cooling. the cab on our trucks is relatively small so Toyota uses smaller AC components to save on efficiency
  8. Jul 3, 2018 at 9:02 PM
    #268
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes, that was out the door. Cold and shit now.
  9. Jul 3, 2018 at 9:04 PM
    #269
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    If rockauto is to be believed, they are the same compressor.
  10. Jul 3, 2018 at 9:07 PM
    #270
    Jimmyh
    SC
    2012 Prerunner SR5
    Looks like the same on both using the Toyota Parts listing.
    AC Compressor 88320-04060 $1,254.65
  11. Jul 3, 2018 at 9:08 PM
    #271
    PennSilverTaco
    Charlie
    If that's where the leak is, I'll replace the parts...
  12. Jul 3, 2018 at 9:17 PM
    #272
    PennSilverTaco
    Charlie
    I know a guy who lives in Hong Kong, and he is admittedly "not a truck guy." He prefers Rolls-Royces and thinks that it is one thing if the A/C in an old (and rare) Rolls-Royce fails, but it might not be worth it to repair the A/C in an 8-year old Toyota...
    I disagree!
    LocoLocal and b_r_o like this.
  13. Jul 3, 2018 at 9:30 PM
    #273
    PennSilverTaco
    Charlie
    @LocoLocal
    Would you say it's worth it to just keep fixing wear-and-tear items on an old Tacoma instead of eventually buying a new truck? I don't plan on using my Tacoma as a daily driver forever, but I do plan on keeping it forever...
  14. Jul 3, 2018 at 9:34 PM
    #274
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    I think so. As someone said earlier, cheaper than buying a new truck!
  15. Jul 3, 2018 at 9:35 PM
    #275
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Oh shit, son! Subbed cuz my AC is a punchline to a bad joke!
    My 98 Jeep Cherokee has sub-Arctic AC, hard to believe a vehicle 15 years newer can't compare.
    12TRDTacoma[OP] likes this.
  16. Jul 3, 2018 at 9:41 PM
    #276
    PennSilverTaco
    Charlie
    That was me, wasn't it...?
  17. Jul 3, 2018 at 11:33 PM
    #277
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The only thing which I would consider upgrading to be a bigger unit would be the condenser itself. That would allow more refrigerant volume in the system as a whole which is what this system needs, even like .3 or .4 lbs more would be a huge help. The compressor doesn't need to be any larger, the system as a whole just needs more capacity.
  18. Jul 4, 2018 at 8:56 AM
    #278
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Anyone have like a "how to" for physically cleaning the fins of the condenser? I feel like that may help.
    Also, really liking the fan idea... just unsure of how to mount it.
  19. Jul 4, 2018 at 9:22 AM
    #279
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I clean mine pretty regularly. I'm no expert. But I always keep a pressure sprayer (the kind you pump to build up pressure) with a 50/50 mix of water and Simple Green around for different cleaning needs. With a cold engine I spray as much of the condensor down as possible and let it sit for a couple of minutes. Then I hose it off with some low pressure water from a garden hose.
    I have one of those nozzles that's got multiple setting. One of them has a circular fan pattern that puts out just enough pressure to help clean the coils without damaging them.
    I generally do this when I clean my engine....every 2-3 months, or so.
    I like the idea of a supplement fan as well. But I'm skipping that idea for a couple of reasons. One...my A/C is quite good. Two...I'm under the remainder of my Platinum Warranty for another 5 years or 78K miles. So I'm reluctant to make those kind of changes....and risk possible warranty denial on something that could be linked to that.
    Roostfactor likes this.
  20. Jul 4, 2018 at 9:26 AM
    #280
    Plain Jane Taco
    USA
    BTW.....this was my inspiration for the line insulation. I was cleaning up behind my heat pumps a few months back and thought....hmm....they go to the trouble to insulate those lines. Figure it couldn't hurt trying it out.
    jross20 and Roostfactor like this.
