Our AC system SUCKS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 30, 2018.
  1. Jul 5, 2018 at 8:34 PM
    #341
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    He put dye in it...
  2. Jul 5, 2018 at 8:44 PM
    #342
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Then you should be able to locate the leak with a UV Light and glasses.
  3. Jul 5, 2018 at 8:53 PM
    #343
    PennSilverTaco
    Charlie
    Am I doing the right thing by opting to put potentially hundreds of dollars into 2010 Taco with almost 85K miles? I think I am...
  4. Jul 5, 2018 at 8:57 PM
    #344
    Jimmyh
    SC
    2012 Prerunner SR5
    That is nothing. But only you can answer that question for yourself.
  5. Jul 5, 2018 at 9:00 PM
    #345
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    None? I'm not sure what regular service is. It is not changing the oil if that's what you mean. The system holds 5.6 oz, iirc. So, adding any oil would just be a guessing game.
  6. Jul 5, 2018 at 9:01 PM
    #346
    PennSilverTaco
    Charlie
    I'm attached to my truck; It was a gift from my dad. My truck has new brakes all around (Front brakes in March 2018 and rear brakes last month), new tires (October 2017), Subwoofer and amplifer (March 2018) Window tint (July 5th, 2018). I've got a clear Pennsylvania title in my name, and my goal is to drive my Tacoma until at least 2025 so I can save up for a house and not have to worry about monthly payments on a vehicle...
    george101 likes this.
  7. Jul 5, 2018 at 9:23 PM
    #347
    PennSilverTaco
    Charlie
    @Jimmyh
    Random question...
    Should my A/C condenser be hot? Like REALLY effin' hot?!?!
  8. Jul 5, 2018 at 9:42 PM
    #348
    PennSilverTaco
    Charlie
    Obviously not boiling, but hot enough that I can't stand to touch it for very long. I've never even felt the outdoor condensers on my parents' central air get that hot!
  9. Jul 5, 2018 at 9:47 PM
    #349
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The hotter it is, the harder it's working.
    It means it's working normally.
  10. Jul 5, 2018 at 9:47 PM
    #350
    PennSilverTaco
    Charlie
    It gets so cold in my truck when I'm actually driving (45+ MPH) that any female passengers not wearing a bra could end up being rather embarrassed...
    At idle however, like the OP said, it's rather lackluster!
    12TRDTacoma[OP] likes this.
  11. Jul 5, 2018 at 11:06 PM
    #351
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Because as stated the condenser is essentially removing the heat from the cab and taking it outside where it can be cooled by ambient air.
    At speed there is enough airflow over the condenser to remove the heat but while stopped and at idle the stock fan/clutch combo doesnt pull enough airflow through the condenser to cool it sufficiently and because of that ac efficiency decreases.
  12. Jul 5, 2018 at 11:07 PM
    #352
    PennSilverTaco
    Charlie
    At this point I'm glad I have A/C, period!
    Until recently, one of my coworkers drove a shitty '96 Ford Ranger. It had no A/C and the heat didn't work!
    Roostfactor[QUOTED] likes this.
  13. Jul 5, 2018 at 11:14 PM
    #353
    Roostfactor
    TX panhandle
    They are independent systems but I see where you are coming from.
    First of all the temp gauge on the truck wont rise until you are way overtemped.
    2nd. The radiator will get more airflow while stopped than the condenser because it is closest to the fan and the condenser is not sealed to the radiator.
    3rd. As long as the radiator can lower temps to 20 or so degrees below the engine thermostat temp then the engine will not overheat. Stock thermostat is around 182° iirc.
    I dont know what temp the condenser needs to be below for max efficiency but it's probably below 160°F.
  14. Jul 6, 2018 at 3:03 AM
    #354
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    No need for the f-bombs...
  15. Jul 6, 2018 at 3:04 AM
    #355
    PennSilverTaco
    Charlie
    I put that in the wrong post...
    6am and I'm barely awake...
  16. Jul 6, 2018 at 12:28 PM
    #356
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    115 F right now. While stopped my AC completely shuts off. Confirmed the AC on these trucks sucks.
    Last year when it was this hot out in Arizona, my engine got to 220 F and trans 240 F. I am happy to report atleast my CSF radiator is keeping my temps way down. 204 Engine 200 Trans.
  17. Jul 6, 2018 at 1:24 PM
    #357
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Where are you at that it's 115? It's not even that hot here.
  18. Jul 6, 2018 at 1:26 PM
    #358
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    111*f out right now here in thousand oaks area.... today is gonna be a record breaking day for sure, way way to hot for the area compared to the average.
    That stated, completely stock AC system and engine cooling system... AC froze me out of my truck on speed 3 and recirc.
    AC does not shut off when the truck is stopped, works just fine at idle.
  19. Jul 6, 2018 at 1:35 PM
    #359
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Southern California. Winchester area.
    I think I am going to buy a new condenser. Some may see it as throwing parts at the truck, but I think mine might just suck. My stock radiator was pretty jacked up when I replaced it. I wish I would have payed more attention to the condenser when I was in there.
    Even revving the truck up didn’t get it to blow “cold”. It basically went from not working at all blowing hot air, to blowing more of a luke warm/ barely cool air.
    TXpro4X4 likes this.
  20. Jul 6, 2018 at 1:37 PM
    #360
    nd4spdbh
    SoCal
    Big plate bumper and supercharger arent helping you out there. Honestly before id buy a condensor, id try to move the inner cooler out of the way to see what the condensor looks like, and if it looks good get a supplemental fan that will fit to push air at least through a portion of the frontal area.
