Our AC system SUCKS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 30, 2018.
  1. Jul 6, 2018 at 1:38 PM
    #361
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Yea, I think humidity plays a role also. Your humidity is under 15% . When the humidity is over 70% my AC takes longer to cool.
    I think the heat index is what needs to be looked at
    What is the heat index?
    "It's not the heat, it's the humidity". That's a partly valid phrase you may have heard in the summer, but it's actually both. The heat index, also known as the apparent temperature, is what the temperature feels like to the human body when relative humidity is combined with the air temperature. This has important considerations for the human body's comfort. When the body gets too hot, it begins to perspire or sweat to cool itself off. If the perspiration is not able to evaporate, the body cannot regulate its temperature. Evaporation is a cooling process. When perspiration is evaporated off the body, it effectively reduces the body's temperature. When the atmospheric moisture content (i.e. relative humidity) is high, the rate of perspiration from the body decreases. In other words, the human body feels warmer in humid conditions. The opposite is true when the relative humidity decreases because the rate of perspiration increases. The body actually feels cooler in arid conditions. There is direct relationship between the air temperature and relative humidity and the heat index, meaning as the air temperature and relative humidity increase (decrease), the heat index increases (decreases).
    Murphinator[QUOTED] likes this.
  2. Jul 6, 2018 at 1:41 PM
    #362
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    The front bumper honestly has plenty of openings that I would bet it flows just as much if not more air than stock. As far as moving the intercooler. I would have to be extremely creative with it. It’s actually pretty big and there isn’t many good places to put it. I would like to do a pusher fan. Maybe I can some how space out the intercooler from the condenser to fit a fan in there. I doubt it though.
    I just want to say I find it interesting my 05 tundra appears to have a smaller condenser and the ac works better than my taco. It does suffer slightly when stopped, but I’ve always attributed it to the 353k miles on it.
  3. Jul 6, 2018 at 1:45 PM
    #363
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Not sure how to calculate it, but it’s currently 114 F @ 8% humidity
    TXpro4X4 likes this.
  4. Jul 6, 2018 at 1:52 PM
    #364
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Im just saying move it so you can peak down at the condensor to see its health.
  5. Jul 6, 2018 at 1:55 PM
    #365
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Time to head down to Zuma!
  6. Jul 6, 2018 at 2:25 PM
    #366
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I dont think it’s the front that is the problem. My stock rad was all bent up on the side close to the motor (no clue how).
    Or I guess I could try using some NuBrite to clean the condenser maybe that will help. I think the issue is an air flow and efficiency problem.
  7. Jul 6, 2018 at 2:43 PM
    #367
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Lol over here in DC area they would’ve put us in a “heat wave warning” from the national weather service. They did this this past week and I was like wtf is this? I had never seen such a thing living in Georgia with 100+ degree humid summers.
  8. Jul 6, 2018 at 3:13 PM
    #368
    nd4spdbh
    SoCal
    Oh we are definitely in a heatwave warning right now
  9. Jul 6, 2018 at 4:13 PM
    #369
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    115 one minute and rain the next..
    Also I shut the far passenger vent. Holy crap I wish the fan blew that hard all the time, I could actually feel cold air.
    12TRDTacoma[OP] likes this.
  10. Jul 6, 2018 at 4:24 PM
    #370
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    For those of you who've installed condenser fans, which brands, models and sizes did you use? I seem to remember a 10" fitting in the front. I can't seem to find anything over 800cfm. I know static pressure plays an important role with fan selection too, the cfm will drop when static pressure increases
  11. Jul 6, 2018 at 4:49 PM
    #371
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes it will be hot.
    Roostfactor and DoorDing like this.
  12. Jul 6, 2018 at 7:09 PM
    #372
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Yep, condenser temp should be 20-30f over ambient temp.
    Roostfactor and Yuma Taco like this.
  13. Jul 8, 2018 at 9:36 AM
    #373
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    So, a follow up on my previous post. Yesterday, I spent 30 minutes sitting in my truck, idling in the heat. 113° 20% humidity.
    Now, depending on how much I trust the scale on the AC machine that I used the other day to evac and then recharge (dye added too); My system had been running basically half full. After meddling with it, I can say that AC performance is definitely improved when driving. At idle though, I’m having a difficult time concluding that it’s much better than before.
    My truck idles at about 750 rpm. Even an rpm increase of just 250 rpm to 1000 rpm made a huge difference in vent register temps. So, just throwing an idea out there, what about a mild pulley ratio change to spin the fan just a bit faster? Then, seal up the shroud as well as possible to maximize the amount of air it pulls through the radiator. Further sealing between the radiator and the condenser could also be of benefit. But, I’m hesitant to do that fearing that it could restrict airflow through the radiator during normal driving.
    12TRDTacoma[OP] and Roostfactor like this.
  14. Jul 8, 2018 at 10:48 AM
    #374
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Now that is been hot in SoCal I’ve been testing my fan more. 95 degrees today and at idle I’m blowing 62 at idle and the fan did NOTHING. 62 at idle I’m sweating my balls off in this truck. I’m pissed at this ac system. Shit blows in the 40s on the freeway even when it’s 90-100 degrees out
  15. Jul 8, 2018 at 10:50 AM
    #375
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Mine is only blowing at 60 F on the freeway.. I just got it recharged like 6-8 months ago. I think I have a problem and I agree this AC system is sht.
  16. Jul 8, 2018 at 11:49 AM
    #376
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    Some of the posts maybe due to a problem like a leak.
    BUT, the most part of the posts here are complaining a problem that is just part of refrigeration in general!
    Yes, most modern A/C's do not work as well as they did back in the 70/80's when we used R-12 for the systems.
    The newer R-134a will not remove the humidity as well! Period. As I said earlier in this thread it's the nature of an a/c. When it is above 100 outside and the cab is well above 115° the system will only cool air 20~25 degrees at a time. So it takes time to cool a cab down. Also when a truck is at idle the compressor will not be turning at it's fullest capacity. That is science.
    The changing of evaporators or condensers will not really fix the problem. In fact most of the time it makes more problems.
    If your truck can't cool you down, get it looked at.
    My 2009 has kept me cool in southern Arizona for almost 10 years and I have fixed nothing. Is it 40°, no, but 80° is great when the cab is 120°. And it will get cooler as I drive. Like it has been said, I have to turn it down after a while.
    Yuma,
    Roostfactor likes this.
  17. Jul 8, 2018 at 12:16 PM
    #377
    anthony250f
    Anthony
    San Diego, CA
    Mines blowing ice cold on the freeway. Like 48 today and it’s 101 degrees
  18. Jul 9, 2018 at 5:54 AM
    #378
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    20 pages and still waiting on someone to get out a thermometer and get some datapoints... Actually make some changes... and get some more datapoints
  19. Jul 9, 2018 at 8:30 AM
    #379
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    We should just keep on chatting about it from the arm chair.
    Mine is cold enough for me most days unless stopped in traffic around noon on a 95+ day which I don't do often
  20. Jul 9, 2018 at 9:02 AM
    #380
    anthony250f
    Anthony
    San Diego, CA
    Same here.
    I have provided data before and after the e fan and no changes. I washed out my condenser today so we will see if that changes anything for me.
    12TRDTacoma[OP] and b_r_o like this.
