Our AC system SUCKS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 30, 2018.
  1. Jul 24, 2018 at 4:46 PM
    #461
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Many different ways to skin this cat. To me the most obvious and easiest one is to increase capacity. I wonder if making something like a custom slightly overall larger condenser would be an easy endeavor for fabricators.
  2. Jul 24, 2018 at 5:03 PM
    #462
    Taco'09
    Taco'09 Well-Known Member
    I agree, just like the old R12 systems. Our systems just don't have any margin built into them. Unfortunately the AC designs are going the other way because the governing forces at work don't much care about our comfort. Its all about perceived issues related to the environment and weight reduction in order to chase CAFE requirements.... The next generation of auto AC systems coming soon to a vehicle near you has significantly less refrigerant and will operate at much greater pressures.
  3. Jul 25, 2018 at 1:06 AM
    #463
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Would making a loop or two in one of the lines increase the refridgerant capacity enough to make any difference?
  4. Jul 25, 2018 at 8:44 AM
    #464
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    a loop or two of lines wont hold much
  5. Jul 25, 2018 at 8:47 AM
    #465
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Per the title
    Actually it Blows
    12TRDTacoma[OP] likes this.
  6. Jul 25, 2018 at 1:58 PM
    #466
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is something which has not been mentioned on going this route that has the potential to become an impending Achilles heel. These compressors are only designed to spin up to certain RPM before they shut off, and increasing its upper RPM limits over what is otherwise safe operating decline limits may be detrimental for the compressor lifespan.
    I could be wrong however and simply overanalyzing that one.
    Much agreed. They are switching out these new cars to 1234yf and charging some $800 for a service alone. These new systems are becoming way overly engineered and using fancy refridgerants simply because the government keeps demanding more.
  7. Jul 25, 2018 at 2:19 PM
    #467
    12TRDTacoma
    Rob
    Concordia
    Boosted
    @Murphinator do you have any update on progress for retrofitting a different blower fan in these trucks?
  8. Jul 25, 2018 at 2:27 PM
    #468
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Removed the seal at the back of the hood and it has certainly seemed to help.
  9. Jul 25, 2018 at 4:14 PM
    #469
    Chubbz
    Chubbz Member
    Alex
    2015 Black Tacoma TRD
    3in Lift 20x9 Fuel Wheels with 33/12.5/20 Radar Tires Cold Air Intake LED Lights (All Around)
    I have taking the truck back to the dealership and i keep being told the A/C works fine. But i have explained to them that while driving it works just fine, but at an idle or a red light you can tell the difference of the "COLDER" air going away. They have "SUPPOSEDLY" drained and refilled my system each time and they cannot find an issue.
  10. Jul 25, 2018 at 4:26 PM
    #470
    Chubbz
    Chubbz Member
    Alex
    I called the dealership and the specs are to be 55 degrees at idle. Now they gentleman i spoke with did say try to keep the A/C on the level before HIGH during the real hot times. As that can cause a bypass and you feel the A/C not to be as cold (as in driving). I will try this out and keep everyone posted.
  11. Jul 25, 2018 at 5:02 PM
    #471
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    How realistic is it to convert the blower to an analog switch? Like I want to be able to have near infinite speed selections from 0 to 100%.
    I hate that the fan only has 4 speeds, the lowest is too high sometimes. I want to pick whatever speed I want.
  12. Jul 25, 2018 at 5:03 PM
    #472
    jross20
    Georgia
    Yeah no thanks r134 is good enough for me.
  13. Jul 25, 2018 at 5:11 PM
    #473
    Taco'09
    Sounds like a new mod. Who will be the first?
  14. Jul 25, 2018 at 5:18 PM
    #474
    Taco'09
    FWIW, our compressors are different than the older ones designed for R12 and even some designed for early R134A. Ours are called a swash plate compressor and their design was for higher pressures. Somewhere around here I have a file on these and if I can locate it I will post the specs. It is also a GM (Delphi) compressor and if one seeks out say a Denso it too is the same Delphi with the only difference being the stickers replaced by chimps using a dull screwdriver, really.
    12TRDTacoma[OP] and DoorDing like this.
  15. Jul 25, 2018 at 5:19 PM
    #475
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have noticed myself that the blower low speed is sometimes too much myself. It is pretty annoying actually.
  16. Jul 25, 2018 at 5:20 PM
    #476
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I am strongly contemplating doing that as well as physically opening up the slit of my sport hood scoop to turn it basically into a heat extractor.
  17. Jul 25, 2018 at 5:32 PM
    #477
    Taco'09
    Yes I have been following this for awhile. First it was that R12 was charged with being environmentally evil and so it was replaced with R134A which was supposed to be the fix for all time but then the powers that be have now decided that R134A is also evil so comes the new 1234yf. Meanwhile those who have revisited the purge of R12 and its sister refrigerants have found it to not be evil after all. But the damage has already been done as millions of poor all over the world have suffered and still suffer.
    Weissenheimer likes this.
  18. Jul 25, 2018 at 5:40 PM
    #478
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Sadly, I do not. Too much going on right now.
  19. Jul 25, 2018 at 5:54 PM
    #479
    jross20
    Georgia
    I would totally be down to do it if I just had the knowledge or something, I just need to know what the current stock motor if it's possible.
    Honestly it really pisses me off that fans are not sold this way in general. The close buddy of mine has a old fan from like the 70s on his reloading station, it just has a knob with no resistance, you can turn it in a smaller increments as you want. The motor speeds at whatever "percentage" you select.
    I mean almost every fan nowadays for like a room or a desk or something like that have only two or three speeds and all of them are ridiculously too high or too low.
    So basically a potentiometer controlled fan I believe is the correct electronic name.
  20. Jul 25, 2018 at 6:03 PM
    #480
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's exactly what it is called, and I do not see why some thing like that wouldn't not be doable. You can literally use the same knob on your AC head unit housing too if you are slick about it.
    jross20[QUOTED] likes this.
