Our AC system SUCKS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 30, 2018.
  1. Jul 25, 2018 at 6:08 PM
    #481
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    resistors , A potentiometer is nothing more than a variable resistor. there are 4 positions and 3 resistors on the fan circuit now.
    the reason the resistor is not in the dash is because of HEAT, it will self destruct over time. the blower resistors are in the blower case and cooled by the air flowing over it ( and they still burn out)
    Reinvent the wheel and let the rest of us know how to do it
    CurtB, 12TRDTacoma[OP] and TomTwo like this.
  2. Jul 25, 2018 at 6:29 PM
    #482
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    That is more or less how I remember it as well.
    12TRDTacoma[OP] likes this.
  3. Jul 25, 2018 at 6:31 PM
    #483
    Taco'09
    Taco'09 Well-Known Member
    Yes, the resistor gets hotter than blazes and they put it directly in the air stream to help cool. If you remove it there is a cutout where the ceramic part protrudes into the fan's air duct downstream from the fan. I have peeled the skin off my fingers reaching back in here and accidentley touching the hot resistor.
  4. Jul 25, 2018 at 6:40 PM
    #484
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    A company made a lot of money when we were forced to switch from R12 to R134A.. coughDupontcough.
  5. Jul 25, 2018 at 6:42 PM
    #485
    Blkvoodoo
    Kevin
    Near Clayton NC
    know anyone who uses or has used aerosol propelled inhalers for asthma ? wanna guess what the propellent was up until early '00 ? and after that until they developed dry power inhalers ?
    R12 was used as part of the treatment and propellant and then they redeveloped the dose and used R134a which had a bad taste at first, they worked that out. Now most aerosol propellent inhalers are defunct and dry power is used.
  6. Jul 25, 2018 at 6:43 PM
    #486
    Blkvoodoo
    Kevin
    Near Clayton NC
    no way they could be behind this latest change out, that would be unethical......
  7. Jul 25, 2018 at 6:49 PM
    #487
    Scott B.
    Scott
    Georgia
    Not the first time, doubt it will be the last time...
  8. Jul 25, 2018 at 6:50 PM
    #488
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    There is a shortage of slickness these days so it may look a bit Micky mouse.
  9. Jul 25, 2018 at 6:51 PM
    #489
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Checked the price of R22 lately? :(
  10. Jul 25, 2018 at 7:09 PM
    #490
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I've tested this myself. I agree. But, if you block the airflow the amps drop but the motor gets hotter and hotter and the amps go up. Keep going and the motor will burn up.
  11. Jul 25, 2018 at 7:15 PM
    #491
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Dig up sources that say ozone depletion is not a naturally occurring event. :)
  12. Jul 25, 2018 at 7:17 PM
    #492
    Taco'09
    I thought I would park this here since the thread is about poor cooling especially when at idle. I have had the entire HVAC box apart, and I mean every small and large piece. There is no regulation of the hot water that flows to the heater core such as you will find on older vehicles. The heater core also site immediately adjacent to the AC evaporator core.
    The air flow goes like this:
    Air inlet to cab >> fan motor >> duct to AC evaporator >> heater core >> blend doors >> duct works.
    So the heater core has engine-temperature coolant flowing through it all the time. Its seems a bit inefficient to first cool the air through the evaporator and then heat it again through the heater core. I wonder if a valve could be used to reduce or shut off the hot water flow? Or perhaps it is leaks in the blend door seals themselves?
  13. Jul 25, 2018 at 7:23 PM
    #493
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Good point, where does that hot air from the heater core go?
  14. Jul 25, 2018 at 7:28 PM
    #494
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I made no claims either. And I'm not reading internet stuff. I can't prove anything one way or the other. We just have to live with what we have.
  15. Jul 25, 2018 at 7:33 PM
    #495
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I'm going to add to this. In '95 when R12 was starting the phase out, I was required to find and fix a leak, no matter how small. But! a large system like you might see in a supermarket could leak up to 50 pounds a year and no repair was required. Sound kosher?
  16. Jul 25, 2018 at 7:34 PM
    #496
    Taco'09
    It seems to go to the cold air from the evaporator. At least that is what it looked like when I had it apart. Otherwise there is no outlet from the HVAC box where we find dumping of hot air to the outside :notsure:
  17. Jul 25, 2018 at 7:37 PM
    #497
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Okey doke. Not gonna argue, no point in it.
  18. Jul 25, 2018 at 7:38 PM
    #498
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Not a damned thing.
  19. Jul 25, 2018 at 7:39 PM
    #499
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    There is a valve. If you don’t call for heat. Hot water doesn’t go to the heater core. It is bypassed.
    When you do
    Call for heat the valve operates sending engine heated water to the heater core. Unless it operates differently than any of my other vehicles, as I haven’t delved in my taco heat system as of yet
  20. Jul 25, 2018 at 7:43 PM
    #500
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Where is this valve? I know what you mean about older systems, but Tacomas don;t have a water valve, do they?
