Our AC system SUCKS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 30, 2018.
  1. Jul 2, 2018 at 6:28 AM
    #121
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    90's here and mine was working just fine.
  2. Jul 2, 2018 at 6:29 AM
    #122
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Can we trade air conditioner parts?
  3. Jul 2, 2018 at 6:32 AM
    #123
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    was 100 yesterday and my taco did well in the heat
    recirc was needed
    Plain Jane Taco likes this.
  4. Jul 2, 2018 at 7:11 AM
    #124
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Did you make your brackets for mounting those fans? That is a very clean setup.
    12TRDTacoma[OP] likes this.
  5. Jul 2, 2018 at 7:14 AM
    #125
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Mine works fine
  6. Jul 2, 2018 at 7:36 AM
    #126
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    So update on this, with employee pricing the tsb parts kit is $512.00
    Also another thing to consider, since our trucks have an extra rad in the front. Should we not be adjusting our fan clutch to compensate? Either by swapping in thicker fluid or changing the engauge temp?
  7. Jul 2, 2018 at 7:41 AM
    #127
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I wouldn't think it would need to be changed. If you have the pink clutch then that's the one that comes with the tow package....and supposedly is the heavier duty clutch
  8. Jul 2, 2018 at 7:48 AM
    #128
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I think pink is the only ome that came on the trucks. Also I had to upgrade my radiator because in the summer months my truck would run hotter than it should. New rad keeps things much more managable.
    I wish trd made a heavy duty fan clutch like they did for the 1st gens, sadly the 2nd gen gets no love.
  9. Jul 2, 2018 at 8:02 AM
    #129
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    My tacoma (2015 Silver DoubleCab) is always parked in the Sun (Houston). I have a cheap front windshield reflective screen, and then the AVS window vents so I keep the windows cracked a bit. I get in the truck after work and it's not too bad. I have noticed we have a Micky Mouse AC system.
    Color has a lot to do with it I'm sure.
    I was curious if we could just pull the dash and wrap all the AC duct work in some sort of foil/AC duct tape or some other type of Insulation. That way as the insulation cools, the air continues to cool faster as it passes through. I don't have a long commute home, but My truck gets cool pretty fast.
  10. Jul 2, 2018 at 8:12 AM
    #130
    Plain Jane Taco
    USA
    I'm pretty sure pink is only with the tow package. But I could be wrong
  11. Jul 2, 2018 at 8:43 AM
    #131
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    So from my research, the 07+ Tundra and the 13+ avalon, camry, highlander, and venza to the aftermarket use the same exact part # even though the Toyota part #s are different for the tundra.
    Also the plug type for those and the Sienna/Sequoia are the same plug type. It uses a 3 pin and the tacoma uses a 2 pin.
    I cannot find an aftermarket blower for the 16+ tacoma, but I assume it uses a similar 3 plug style. It seems toyota switched to that style some time ago. I’ve tried looking at older model years of the above, and while they use the 2 pin style connector, they all seem to have different plugs.
    I am probably going to subscribe to TIS for a few days and see if I can find what is the deal with the 3rd pin, maybe our blower can be converted. I will keep you all updated on my research.
    12TRDTacoma[OP] and Roostfactor like this.
  12. Jul 2, 2018 at 9:36 AM
    #132
    B ill y
    B ill y Well-Known Member
    Billy
    Sarasota County, Florida
    2018 4Runner Trd OR, 1997 FZJ80,1985 FJ60
    yes they are just on off switch. one of those air on board switches with a fan image with relays . one switch two relays one for each fan. one 3amp fuse for switch and each fan has 15amp fuse. they have been on there for almost 4 years no issues. have had them on my 80series for 10 yrs no issues . there pushers so they just spin freely when I move forward.
  13. Jul 2, 2018 at 9:36 AM
    #133
    B ill y
    Billy
    yes just some 100mil 6061 aluminum.
    WebberLander[QUOTED] likes this.
  14. Jul 2, 2018 at 9:43 AM
    #134
    B ill y
    Billy
    I've used the mishimoto fans for a really long time with no issues.
  15. Jul 2, 2018 at 9:46 AM
    #135
    B ill y
    Billy
    if you wrap aluminum foil around your new foam it will work even better. 3-4 layers
  16. Jul 2, 2018 at 10:05 AM
    #136
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    That’s weird, my AC system BLOWS.
    Sandman614 likes this.
  17. Jul 2, 2018 at 10:05 AM
    #137
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    The third pin may be for automatic climate control. I wonder if the plugs will still physically connect just not using the third pin. It's probably a reference pin for the auto climate control so wouldnt br needed or used for us.
  18. Jul 2, 2018 at 10:20 AM
    #138
    Plain Jane Taco
    USA
    Nicely done :thumbsup:
  19. Jul 2, 2018 at 10:23 AM
    #139
    Roostfactor
    TX panhandle
    Traveled all day yesterday and just got home but here is my take on all that's been talked about so far.
    1. My fan blows hard enough but its weird. Low is low, next is barely any higher, third is a little higher, then high blows really well. I would like more progressive settings but it's not a killer for me. I also have a k&n cabin filter which works well but I dont know if it actually flows more air than the stock filter.
    2. Yes a warm intercooler in front of the condenser will obviously cause some extra heat and restriction so better airflow is required IF you have a/c cooling issues.
    3. My a/c has shut off when I was idling for 30mins in 105° temps. It was when I was getting my initial UCON tune done so I couldn't shut off the truck and couldn't rev it or anything since Scott was actively manipulating the tune.
    3. @loginfailed and myself have some experience now with our clutch fans and they work better than stock. I drained the stock fluid and added 50ml of 10k csf silicone fluid. It locks up much better at idle blowing significantly more air and the a/c is now much better at idle. It definitely sucks some power though as you can feel it in stop and go traffic when hot outside.
    4. I am planning an electric fan install using an Autocoolguy fan controller and a mid 90's Ford Thunderbird fan. $70 from Rockauto. My plan is to fit it in a DJ cruiser shroud.
    Murphinator and Plain Jane Taco like this.
  20. Jul 2, 2018 at 10:23 AM
    #140
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Get an electric fan and use it when stopped. I can tell a differance on the trail and traffic
