Our Latest Project - MAX Modular Bed Racks
Discussion in 'KB Voodoo Fabrications' started by KB Voodoo, Aug 5, 2018.
  1. Dec 18, 2018 at 8:13 AM
    #61
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The bolt just holds the rack down. The weight is supported by the side of the truck.
  2. Dec 19, 2018 at 5:00 PM
    #62
    Black1Tacoma
    Black1Tacoma #TRUKTOY
    Carlsbad
    2017 Black Tacoma TRD OffRoad 4x4
  3. Dec 19, 2018 at 6:05 PM
    #63
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    That rack will not work with BakFlip covers.
    All of the racks here work with BakFlip covers, but you will not be able to open the cover: https://www.max-modular.com/shop-max-modular/
  4. Dec 22, 2018 at 9:21 AM
    #64
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    @KB Voodoo
    Question... I am looking for dimensions on the tacomax. I found all, BUT, the one(or 2) I am after.
    I am curious as to the OUTSIDE width.
    Please ignore the crappy lines, I did it on the fly...
    And, if the normal mounting tabs, are just flipped to work with tonneau brackets, or, if the tonneau bracket is a 2 piece package per leg, and if so, What is the same dimension as above with the brackets, WITHOUT the lower bracket....on the inside mounting surface.
    My thoughts are going back to a conversation we had about mounting with different covers, and usability. I have an idea to build a mount that will cover all my needs... and hoping to order this rack soon(before spring, as I need to put some money back away after buying the new bike), with some of your side mount bike brackets for my bikes, and be able to carry canoe, and yak.....
    Thanks man, I appreciate it.
  5. Dec 22, 2018 at 9:37 AM
    #65
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I’m helping my step dad move right now, but I’ll get you all the info you need tomorrow.
  6. Dec 22, 2018 at 9:43 AM
    #66
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Awesome, thanks man.
    I just happened do be doing something else for work, and moved a project I started a few years back, and it gave me an idea..... Ive got it jotted down(and a rough drawing), so I wont forget(i have a short attention span)... so, just wanted to get it out there before I forgot.
    Thanks again.
  7. Dec 23, 2018 at 3:43 PM
    #67
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The dimension you are looking for is 62.75".
  8. Dec 23, 2018 at 4:12 PM
    #68
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Awesome, thanks......
    Quick question, is that in reference to the first pic, or with the tonnuae brackets?
  9. Dec 23, 2018 at 4:22 PM
    #69
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The total outside width is the same with tonneau brackets or with our standard attachment clips.
    Chasespeed[QUOTED] likes this.
  10. Jan 7, 2019 at 7:33 PM
    #70
    ionakana619
    ionakana619 Active Member
    Jonathan
    San Diego, CA
    2018 Toyota Tacoma TRD Off-Road 4x4 Cement Grey
    Whats the turn around time on your orders?
  11. Jan 7, 2019 at 7:38 PM
    #71
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We stock everything, and usually ship within a couple days.
  12. Jan 23, 2019 at 6:39 PM
    #72
    Landpirate
    Landpirate Strong like horse, smart like tractor
    North Texas
    2018 Tacoma BBP SR5 4x4 DCSB
    OME HD leafs, 5100s, CaliRaised skids, UpTop Overland Bravo, KB Voodoo rack, Overlander RTT/awning, DECKED
    I ordered the awning mounts to go with my MAX Modular rack, however the sides of my tent stick out too far and the mounts wouldn't clear the RTT. So I had a friend cut the mounts, add a 6" horizontal bridge, and then bedlined them. I'm very happy with the results and now I have my awning mounted to my rack.
    I'm still extremely happy with my rack system, and I get asked about it constantly.
    KB Voodoo[OP] and Chasespeed like this.
  13. Jan 25, 2019 at 4:35 PM
    #73
    AltaTacoma
    AltaTacoma Well-Known Member
    2018 BRM Tacoma TRD Off Road
    How much height do the tonneau cover brackets add to the rack? I need a rack to be tall enough to allow a roof top tent overhanging the cab to clear the antenna on my Tacoma and figure the tonneau cover might help me get there and let me keep using my cover.
  14. Jan 25, 2019 at 7:34 PM
    #74
    Landpirate
    North Texas
    I believe it adds 2.5"
    KB Voodoo[OP] likes this.
  15. Jan 25, 2019 at 10:51 PM
    #75
    AltaTacoma
    Thanks! I just went back through and my question was already answered.
    Landpirate[QUOTED] likes this.
  16. Feb 23, 2019 at 6:18 PM
    #76
    amag413
    amag413 Well-Known Member
    Aaron
    Philly
    2014 Black Tacoma TRD Sport | Double Cab SB
    JD Fab 2.25 kit, Homemade flatbed, Four Wheel Camper
    would this system be able to be used as an internal support for my cap similar to how the ARE hd series is made? i would like to use this to tie into my roof rack from the inside so that i could put heavier loads up there than the standard fiberglass cap can hold. the 18" model seems like its almost tall enough to touch the interior top of the cap but are you able shim it to get a snug fit? also could you assemble it inside a cap? for reference, this picture shows the interior of the ARE hd cap and its internal support system. 2016-Tacoma-CX-HD-Topper-Frame-1200x900.jpg
    dpf88101 likes this.
  17. Feb 26, 2019 at 2:47 PM
    #77
    Nathan4byfour
    Nathan4byfour Well-Known Member
    Cody
    2005 Super White TRD Off-road
    Big thanks to Chad @KB Voodoo for excellent customer service. Got a 100$ promo code for a Taco MAX rack because my old one was rusting very badly, even though it was past warranty. Great company right here
    Chasespeed likes this.
  18. Feb 28, 2019 at 9:40 PM
    #78
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    I like it. Ordered Saturday, arrived today across the country (paid for it though).
    208bench and KB Voodoo[OP] like this.
  19. Mar 1, 2019 at 9:22 AM
    #79
    amag413
    Aaron
    Philly
    Any insight on this KB Voodoo?
  20. Mar 1, 2019 at 9:26 AM
    #80
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    There is no possible way that could work.
