Out of Warrant Toyota Assitance - A/C Failure 2017 Taco TRD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BlueTurdPro, May 30, 2025.
  1. May 30, 2025 at 12:31 PM
    BlueTurdPro
    BlueTurdPro [OP] New Member
    2017 Blue Tacoma TRD
    TRD Pro Wheels 31" BFG A/Ts Old Man Emu Upper Control Arms 2.5" Leveling Suspension Lift 4Runner TRD Pro Bilstein Front Struts
    Good afternoon all!
    My A/C failed on my 2017 Taco TRD OR and the dealer is currently quoting me $1,100 to replace both Schrader valves as a "starting point" because they honestly cannot guarantee if their recommendations are the only failure points or not. Needless to say, at 135k on the ODO, I'm a little bit disappointed to face such a catastrophic failure of what's supposed to be a lifetime system. I switched from BMW's to Toyota's specifically to avoid this kind of thing. /digress
    So far, I reached out to Toyota Corporate to inquire about repair assistance with poor results. My truck was rejected because I don't have regular service history with a Toyota stealer— another disappointment after hearing all of the altruistic Toyota assistance stories related to abnormal service problems.
    And so, before I go find an independent shop and shell out some money, I'm curious to know if anyone here has had any past success with Toyota Corporate offering out of warranty assistance to vehicles that were also NOT regularly serviced by the stealer? Basically, I'm trying to understand whether or not I just landed a useless agent, and some persistence may yield a different result.
    Cheers!
  2. May 30, 2025 at 12:34 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    A limited warranty period is just that, a limited warranty period! Just because you think that your AC system is a "lifetime system" (whatever that means), does not mean that it should /will last forever. My recommendation is find a good Indy-AC shop and let them fix it.
    PS: welcome to TW! :thumbsup:
  3. May 30, 2025 at 12:39 PM
    BlueTurdPro
    Lifetime means I've driven many vehicles upwards of 200-300k on the clock and I have never had A/C failures related to the refrigerant lines or compressor. A quick web search yields a recurring theme with 3rd gen Tacoma's and A/C problems; coupled with the lines blowing out the charge at 135k, I believe still warrants the disappointment and criticisms.
    None the less, thank you for the input and recommendation.
    And thank you for the warm welcome!
  4. May 30, 2025 at 12:52 PM
    TacoDell60
    TacoDell60 Well-Known Member
    I have a 2016 Tacoma and had a A/C hardline puncture near one of the shredder valves around 56k miles. Had that fixed then 30k miles later the A/C compressor clutch seized, replaced it with a new oem clutch and it's been trouble free for almost 2 years.
    It happens
    t0p_d0g and kahanabob like this.
  5. May 30, 2025 at 2:29 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Yea I can't see Toyota coming in to help on an 8 year old vehicle.
    And per previous advice find a good independent shop that specializes in Toyota and get their opinion/advice/price quote.
    I find these independent brand-specific shops tend to do very good work at very good prices and they are usually busy as hell.
    I know mine are sometimes 2 weeks out for even basic maintenance.
    MGMDesertTaco, TXpro4X4 and kahanabob like this.
  6. May 30, 2025 at 4:02 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Location? https://www.tacomaworld.com/forums/regions.36/ Tone of help here.
    Go do a search of your local area for the best independent Toyota repair shop that does AC work and come back with results.
  7. May 30, 2025 at 4:12 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It sounds like you prematurely jumping to conclusions. Take the truck to a different mechanic for a second opinion.
    $1100 to replace some shader valves makes no sense. If it isn’t obvious, those are the valves used by (some) bicycle tubes.
    kahanabob likes this.
  8. May 30, 2025 at 4:24 PM
    CrashZone
    CrashZone Well-Known Member
  9. May 30, 2025 at 9:34 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    First of all you don’t need to use the Yoyota Services to keep your truck in warranty, and if it’s broken due to something covered by a TSB, you still should qualify. Can you give better details what was wrong with it? There is a TSB for underperforming AC in hot weather you may still be able to get if it’s partially keeping cool, and maybe the older one for component failure. Did they say there is a refrigerant leak? A private AC shop may be able to help fix it for much less, but if it is something covered under the AC TSB’s I’d try that first.
    https://imgur.com/a/0PpKgw7
    and this one:
    https://imgur.com/a/J3Ic95k
  10. May 30, 2025 at 9:57 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Especially corporate. They suck
  11. May 30, 2025 at 10:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There's nothing "lifetime" about an a/c system, they do a lot of work over the life of the vehicle and that refrigerant gas is hard to keep sealed up.
    Leaks can be hard to find, especially if its a long slow leak. They dont always leave a lot of evidence behind. I never tell the customer I found the leak, I tell them I found a leak.. Murphy's law, as soon as you over promise and tell them "it should stay sealed up for a while" something else will start leaking
    Yes we have several electronic leak detectors but they often dont provide much help. I usually end up looking closely for oil residue and sniffing around. A spray bottle of soapy water helps too..
    $1,100 is a lot but its not catastrophic. Wait until you need a compressor or a evap core, those can be even more expensive
    Sounds like they're selling you the entire line assembly (for hi and low side) with fittings and valves already installed. Pretty sure the low side valve can be replced separately, not sure about the hi side on a 1234YF system
    We keep boxed assortments of valve cores at work, but we're really just starting to see new style refrigerant vehicles at my shop. For the first few years those cars were basically only going to the dealer. Now theyre starting to trickle in last few years..
    Maybe try a reputable indie shop? You dont necessarily need a toyota mechanic, a/c systems are all pretty much the same.
    OnHartung'sRoad, joba27n and Dm93 like this.
  12. May 30, 2025 at 10:37 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    This, ridiculous price. With the correct tool you don't even have to purge the system. We are talking about less then a half hours work while drinking coffee and the parts are less then that cuppa joe. [wholesale price]
    I replaced schrader valves all the time on residential units. I'd buy new valves by the container full. I think I went thru two or three tools in a couple of decades simply because they wore out from use. It's basically the same setup [but WAY smaller] we used for tapping steel gas mains and inserting and removing rubber plugs and removing coupons. [from the cuts]
  13. May 31, 2025 at 1:17 AM
    OnHartung'sRoad
    Curious- How to replace schrader valves without purging the system?
  14. May 31, 2025 at 4:44 AM
    LongDukDong
    LongDukDong Oh sexy girlfriend
    Eastern Seaboard
    2022 TRD OR
  15. May 31, 2025 at 5:44 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    That is interesting. To get the correct charge after a leak though you still have to evac, vacuum, recharge. Yes you can use ac pressure dials to adjust the freon charge but its not exact and modern vehicles work best at the correct charge not at just about the correct charge
  16. May 31, 2025 at 7:56 AM
    LongDukDong
    Eastern Seaboard
    2022 TRD OR
    Wut? If it was just leaking at the valve, didn't completely lose pressure and replacing the core resolves, the system does not need to be evacuated. You absolutely would use gauges and a pressure chart to correct charge. You'd never charge a system by refrigerant weight.
  17. May 31, 2025 at 8:06 AM
    joeyv141
    New Jersey
    You should do as you would like. From a shop point of view if you want a warranty you would charge it by weight.
  18. May 31, 2025 at 8:20 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    In a professional shop, using a service machine that calculates by weight is the only way to truly guarantee the correct amount
    In your driveway you can get close with manifold gauges but its still "backyard" at best. You might add what appears to be the correct amount, the cooling performance improves but 2 days later the ambient temp changes and the performance drops off.. As a DIY it's no big deal, you just get out your tools and add or subtract a little more to your liking
    A professional only has a limited amount of time with each vehicle and it has to be perfect when the car leaves.
    joeyv141 likes this.
  19. Jun 1, 2025 at 11:41 AM
    jpg366
    jpg366 Well-Known Member
    AL
    09 Silver Prerunner SR5
    Hitch, Running Boards
    Refrigeration systems can’t always be fixed in one step. One thing reveals another.
