Outdoor Ambient Temp Sensor
Discussion in 'Technical Chat' started by cfree5119, Dec 24, 2016.
  1. Dec 24, 2016 at 6:42 AM
    cfree5119
    cfree5119 [OP] Well-Known Member
    So I replaced the UCAs on my Tacoma and in getting the upper bolts out I may have stressed one of the wire harness that connects the outdoor ambient temp sensor. Since I have done the project, my directional, temp sensor in the cab of the truck does not illuminate. Any thoughts here? I check the connections to the temperature sensor and it seems it didn't become disconnected. Thanks
  2. Jan 7, 2017 at 6:18 AM
    cfree5119
    Any thoughts in helping diagnosing the problem here?
  3. Jan 7, 2017 at 7:18 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    If it's not illuminating, it's most likely not getting power. Check your fuses first, then pull the overhead console and check for power. There's also a known issue with the overhead temp/direction boards having bad solder joints. It might just be dumb luck that it gave out at the same time as when you did your UCAs. There are threads on how to fix the board on here. Just don't have the link handy.
