Outdoor built in bbq
Discussion in 'Garage / Workshop' started by rondog, Jul 19, 2013.
  1. Jul 19, 2013 at 12:25 PM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    This will be the thread I post all my pictures from my homemade built in bbq. No welding skills whatsoever. Thought I'd give it a go and seems to be coming along nicely.
    Spending report
    Grill: $1,080
    Access door: $128
    Mini Fridge: $160
    Metal: $187
    Primer: $35
    Cement Board: $60
    Random stuff: $280
    Liquid membrane (the pink stuff): $100
    Aluminum Frame for fridge area: $15
    Stone veneer: $580 (12 boxes)
    bull nose tile: $300
    umbrella: $90
    $3,015
    Total hours so far: 60ish
    Current Pic
  2. Jul 19, 2013 at 12:31 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    A small part of me dies every time I see a gas grill bought :(
    To me, going through the effort of BUILDING your own MasterGrill area would seem so much more difficult than lighting up a chimney starter 20 mins before you wanna start cooking.
    On that note... very much looking forward to watching this happen :)
    Wish I knew how to weld :(
  3. Jul 19, 2013 at 12:34 PM
    rondog
    Ronnie
    Escondido/San Diego
    Well, I have natural gas running right where it's going...I've never had the patience for charcoal :crapstorm:
    My roommate knows how to weld, I don't. I'm sort of using this project to teach myself. I've played around welding, but I figure this is a good time to learn. He's been giving me tips on wire speed, heat etc. My weld don't look terrible, but they sure can use some practice. I welded the whole bottom frame last night
  4. Jul 19, 2013 at 12:39 PM
    linzy77
    linzy77 Does not suffer fools lightly
    Linzy
    Dumbfukistan
    2013 Access V6 TRD Off Road
    :popcorn: - You could build your own but I second the bad idea on the Char-Broil (Crap grills and It will be rusted out in a couple yrs)
  5. Jul 19, 2013 at 1:47 PM
    TurboGT
    Gabe
    Portland
    I won't give you grief, I know to each their own and all that.... just so long as you acknowledge that charcoal/wood is far superior :D
  6. Jul 20, 2013 at 5:22 PM
    rondog
    Ronnie
    Escondido/San Diego
    Well, I still haven't decided on what grill I am getting yet, but I got a lot of the main frame cut and welded. I must say, I am getting quite a bit better at welding :) You can almost see the progression of my first welds to my last ones. They are now at least smooth and not bubbly.
    one of my better welds :eek:
  7. Jul 20, 2013 at 5:23 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    make it a full size wood burner! peach would or maple wood in there.. mmmmmmmmmm
  8. Jul 20, 2013 at 5:25 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  9. Jul 20, 2013 at 5:42 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Works just fine.
    Buy the BBQ and simply don't assemble it to the cart. Take measurements and build the enclosure to fit.
    I rebuilt my buddy's brick BBQ a few years ago. The salt air had corroded the steel support structure, causing it to swell and break the tile and masonry work apart. I tore out the damaged areas and rebuilt it using stainless supports for the tile top.
  10. Jul 21, 2013 at 4:21 PM
    rondog
    Ronnie
    Escondido/San Diego
    so I ended up find a sweet deal on a pretty nice grill top. It was a bull-bbq 4 burner natural gas for $1k and also came with a 2 year warranty on the burners and 20 on the enclosure. I'll get pics of that later.
    The frame still has a bit of work to do, but I added most of the supports today. Had to stop because it started raining. Next part will be making the cage for the grill
    welds are looking way better! Not bad for only my second day of welding :p
  11. Jul 21, 2013 at 4:30 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Looking sharp... just be sure to protect the frame from rust. Even with the outside painted, water will get into the inside and rust it out from there.
    Buddy lives at the beach and the entire lower bar on the fence around his back yard was full of water.
  12. Jul 21, 2013 at 4:42 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Looks goods OP.
  13. Jul 22, 2013 at 9:25 AM
    TurboGT
    Gabe
    Portland
    Woot!! Progress :)
    still boo on the gas grill though ;)
  14. Jul 22, 2013 at 9:35 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  15. Jul 22, 2013 at 10:25 AM
    bmka87
    bmka87 Well-Known Member
    Josh
    Southern Maine
    97 Tacoma SR5
    coming along, end result should be pretty sweet!
  16. Jul 22, 2013 at 10:34 AM
    TurboGT
    Gabe
    Portland
    I have questions now...
    Why did you choose to arrange the grill built-in the way you did? Based on the original photo, and comparing to the more recent ones, it looks like you're putting the grill in the long leg of the L-shape, and why not flip the L-shape (again, referencing the original photo) so that as you're standing at the grill, you're facing into what I'm assuming is a more open area of the patio.
  17. Jul 22, 2013 at 11:48 AM
    rondog
    Ronnie
    Escondido/San Diego
    Actually I haven't posted a photo of where it is going to go. Let me see if I can find one
    edit: These pics should better explain its final resting spot
  18. Jul 22, 2013 at 11:58 AM
    rondog
    Ronnie
    Escondido/San Diego
    I'll be painting all the metal along with capping all the ends. It'll be right next to sprinklers so I'll do the best I can. I'll be mounting the frame to some trex to keep it off the ground
  19. Jul 22, 2013 at 12:00 PM
    Manwithoutaplan
    ID
  20. Jul 22, 2013 at 1:27 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Looking good!
