Outdoor cover
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mintcondition, May 7, 2021.
  1. May 7, 2021 at 8:53 PM
    Mintcondition
    Mintcondition [OP] New Member
    Tacoma sr5
    Just purchased a 2021. I have a lot of oak trees anD already getting lots of unknown substances all over. Any recommendations for a good outdoor cover.
    Thanks
  2. May 7, 2021 at 9:09 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Personally, I will never use another outdoor cover as I had a Porsche 930 turbo under restoration waiting in a paint shop's lot in Miami with an outdoor cover on it and when they removed the cover the black paint came off in sheets.
    Only thing we could figure happened was that condensation was building up under the cover overnight and then steamed up in the next day's hot sun causing it to lift the paint. No real harm as paint was being totally stripped for new paint anyway, but taught me a lesson.
    BSFord and Dr.Lou like this.
  3. May 8, 2021 at 5:41 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Garage if you have one or a awning that you will be able to park under if you don’t have a garage .
    Big tall dave and Tacospike like this.
  4. May 8, 2021 at 8:29 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Take the time and ceramic coat your paint or have shop do it and shouldnt have to worry about your paint job . If you ceramic coat your self make sure you clay bar then do a paint correction then apply ceramic coating . Also with ceramic coating you can apply layers of protection just be sure to let applications cure for 24 hrs
    BSFord likes this.
  5. May 8, 2021 at 9:24 AM
    Kevin Jones
    Kevin
    Va
    My 2018 TRD Sport looked like hell, pollen all over it and in every nook and cranny. All it took was 1.5 hours and the below items and it looks beautiful again.
    Like I recommend above forget the cover.
