Outer CV boot keeps ripping, why?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tbell502, Jun 7, 2023.
  1. Mar 26, 2024 at 1:57 PM
    Low Tide
    Low Tide Active Member
    2015 4WD SR5 DCLB
    265 / 75 R16s, Method 305 NV (16”), anti-tailgate theft, tonneau cover, tailgate lock.
    Mine are leaking on my 2015. So, from this thread it sounds like I can have my OEM’s rebooted instead of needing to replace the axels. is this true?
  2. Mar 26, 2024 at 2:43 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    That is true. You just have to do it yourself or find someone who will do it for you.
    Low Tide[QUOTED] likes this.
  3. Mar 26, 2024 at 8:24 PM
    Low Tide
    2015 4WD SR5 DCLB
    Thanks! I’ll look into it and see if my mechanic will do it.
    4WDTrout likes this.
  4. Mar 27, 2024 at 12:01 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Toyota Outer Rubber Boots are more durable than the Napa ones.
    The inner boot mod can work for the inner boot, but I wouldn't do it on the outer boots. At one point I did all 4 of my boots and both outer ones leaked grease from the clamped area of the boots and I used the correct clamps with the correct toyota tool to clamp it down as well. I have rebooted before too.
    I have used the Dobinson High Angle inner and outer boots on a rebuild, and they were ok, lasted about 50-60k on driver's side and the Pass side is dry rotting pretty good on my 4runner.
    CVJ axles are my favorite with the red inner boot and the OEM outer boot. The red inner boot also has a thick rubberband on them that helps to separate the inner two most ribs.
