Outer CV Excess Plunge
Discussion in 'Suspension' started by blackhawke88, Oct 15, 2013.
  1. Oct 15, 2013 at 12:10 PM
    blackhawke88
    blackhawke88 [OP] wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    After installing the 3.5" longer axles on Jen's truck, with her stock inner and outer CVs, we went on a trail ride. I think she might have turned on pavement by accident, because we started hearing a pop when she was turning at full lock on dirt and accelerating.
    I got out and noticed the passenger side outboard CV was popping when she was turned at full lock and moving forward. When going straight, nothing was wrong. I grabbed the CV and noticed I could plunge the outboard CV quite a bit. The drivers side outboard CV doesnt plunge at all, which is normal (only inner CV should plunge).
    When we got home, I peeled back the boot to see what was plunging. The shaft was not plunging in the star, so I know it's not the C-clip that was broken. What was plunging was the whole CV cage assembly with the ball bearing plunging in and out of the CV cup, as if the whole thing would come out. What could have caused this malfunction? Could the CV cup have become deformed when we turned on pavement?
  2. Oct 15, 2013 at 12:19 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    did you break the cage maybe?
  3. Oct 15, 2013 at 12:24 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    When i peeled the boot back and checked, the cage seemed fine and intact.
  4. Oct 15, 2013 at 12:30 PM
    4runnercaged
    cody
    arizona
    LOL
    hmm idk then.
    i have a couple tundra outers that i took off mine to make axles for my truck.
    they came off a 2001 tundra ADD if that will work for your application.
  5. Oct 15, 2013 at 12:31 PM
    4runnercaged
    cody
    arizona
    LOL
    was it popping in/out or side/side?
  6. Oct 15, 2013 at 12:40 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    the shaft, race, bearings, and cage, together as a whole, was popping out of the Outer CV cup at full turning lock, while moving. Not side to side, forward and backwardds towards and away from the diff/truck.
  7. Oct 15, 2013 at 12:49 PM
    4runnercaged
    cody
    arizona
    LOL
    im willing to bet something got worn down in the CV maybe so the tolerances are off then making it able to pop in and out?
    did you see my fist post about the 2001 tundra ADD outers?
  8. Oct 15, 2013 at 12:55 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    not sure if it will work. worst case i go to the junk yard and buy a tacoma CV. whats the spline count on your tundra outers?
  9. Oct 15, 2013 at 1:11 PM
    4runnercaged
    cody
    arizona
    LOL
    are you wondering the spline count on the shaft on the CV joint, or the spline count inside of the CV that the axle shaft goes into?
  10. Oct 15, 2013 at 1:26 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    The CV stub that goes through the wheel hub.
  11. Oct 15, 2013 at 1:46 PM
    4runnercaged
    cody
    arizona
    LOL
    i will count when i get home and get back to you.
