Outer tie rod replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by DanK83, Nov 1, 2019.
  1. Nov 1, 2019 at 10:39 AM
    DanK83
    DanK83 [OP] Well-Known Member
    Dan
    Maine
    2003 Tacoma SR5 V6 4X4
    So, I replaced my outer tie rod ends and the passenger side tie rod end nut was threaded on about 3/4" more on the tie rod than the driver's side. The only thing I can think of that would cause that would be if the passenger's side inner tie rod end was threaded in or out more than the driver's side. It causes my tire to rub on frame when the wheel is turned all the way to the right. Has anyone on here had this problem?
  2. Nov 1, 2019 at 10:41 AM
    eon_blue
    Azusa, CA
    If I remember right, one side of mine had the tie rod nut threaded on a few threads more than the other...they were not equal side to side. I just figured it was done during my alignments to get the alignment numbers correct for my truck. I guess ideally they would be the same on both sides, but suspension, bushings, tires, weight on each side, ect. all plays a role and can make one side different than the other (my guess anyway).
  3. Nov 1, 2019 at 11:13 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    also mfr defects can cause them to be no identical
    wear and tear on parts can cause them to be a little off.
    I replaced mine with Moogs this summer cause she's a street queen lately, and I had them equally set. yeah tires screeching when turning quickly made that change.
    eon_blue likes this.
  4. Nov 1, 2019 at 11:54 AM
    DanK83
    Dan
    Maine
    Okay, thanks! The nut is threaded on about 3/4" more than driver's side. I don't like rubbing on the frame when cut all the way but I can try to avoid that. Do you know if the inner tie rod ends are adjustable or is it just the rack that is in a fixed position? Thanks!
  5. Nov 1, 2019 at 11:58 AM
    eon_blue
    Azusa, CA
    I don't think the inner tie rod is, no. Rubbing on the frame is usually an issue with wheel backspacing, I have the same problem when I cut to one side especially on the trail. Tire grazes the frame. Either new wheels with better backspacing will fix it, or putting a small wheel spacer your current setup should fix it. Beware of those thin 1/4" spacers though, they reduce the amount of threads your lug nuts will grab on the studs which can be dangerous.
  6. Nov 1, 2019 at 12:26 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @DanK83 , I'm doing both inner and outer today, and part of tomorrow. I work slowwww. But I'm going to try and get mine even on both sides, counting the exposed threads on both sides. Good luck with your job when you tackle it.
  7. Nov 1, 2019 at 12:31 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I did both my tie rods yesterday. Eyeball it as best as you could so it drives straight and let an alignment shop deal with it.
  8. Nov 1, 2019 at 12:35 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Just replaced 04 prerunner inners .Had 14 turns on right tie rod and 20 on left . Inner tie rod just bolts to rack. No adjustments .Not like cars with drag link. First time replacement so came from factory like that. Which had me wondering if I counted correctly lol. Also ordered rotors and thought I measured 12.5 but was 11 something :facepalm:loose money:crazy:
    DanK83[OP] likes this.
  9. Nov 7, 2019 at 7:50 PM
    DanK83
    Dan
    Maine
    So, did the outer tie rods have different thread count? One screwed in mire than the other outer tie rod end? It's just a nuisance that when the wheel is turned all the way to the right, the front right tire rubs on the frame and i don't have that issue when the steering wheel is turned all the way to the left. I thought about getting 1" or 1.5" spacers but don't know much about the brands. I heard of a spider brand or something like that. I don't need the most expensive ones but not poor quality either. I just want to get the tire out and away from the frame when making tight turns. Thanks for any help!
  10. Nov 7, 2019 at 7:52 PM
    eon_blue
    Azusa, CA
    Just make sure you get hub centric spacers.
    Lug centric ones are the ones to avoid, they're the ones you hear horror stories of.
    DanK83[QUOTED][OP] likes this.
  11. Nov 7, 2019 at 8:37 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Yea was more turns on left than right . When you get it aligned , its not going to matter .
