Outer tie rod won’t spin off inner tie rod, help please
Discussion in '1st Gen. Tacomas (1995-2004)' started by StevenP, Jun 2, 2020.
  1. Jun 2, 2020 at 7:20 PM
    StevenP
    StevenP [OP] Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    Trying to put new outer tie rods on my truck and I removed the tie rod from knuckle and got the lock nut off just fine, but the outer tie rod doesn’t spin freely out of the inner tie rod.
    Every video I can find shows the tie rod spinning out like it was nothing, the inner tie rod stays still and it just comes out like a cake walk.. well, mine just spins together in unison.
    Any ideas on a solution?
  2. Jun 2, 2020 at 9:37 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Put a pipe wrench on the inner to hold it while you unscrew the outer.
    StevenP[OP] likes this.
  3. Jun 2, 2020 at 9:43 PM
    StevenP
    Steven
    Alta, Ca
    I will give that a go tomorrow, I have many a tool, but I’m embarrassed to say I don’t have a pipe wrench, I’ll have to borrow one from a neighbor.
    I do have one concern that has crept up on me after quitting for the day.. do you think the fact that it won’t freely spin off is an indicator that the inner tie rod is shot?
    I should’ve been more mindful while down there and given it some side-to-side and in-out movements to check for play, I don’t remember feeling any slop but I wasn’t really focused on it in that moment of “crap.. what now” with the outer tie rod.
  4. Jun 5, 2020 at 8:49 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Buy yourself a decent pipe wrench. Consider it an investment. You'll never know when it will come in handy.
    Cast iron is fine, you don't need an aluminum one. Get a Rigid wrench that's at least 13 inches long (15" would be better). It will be a tool you'll have for the rest of your life and will be well worth the investment. ;)
  5. Jun 5, 2020 at 8:51 AM
    Jebediah
    Jebediah Well-Known Member
    Eli
    Colorado
    1998 White TRD.. 'Augustus'
    Did you loosen the jam nut? I think the jam nut is a 27mm and the inner takes a 28mm you just hold the inner while you turn the jam nut off then the outer should spin off.
  6. Jun 5, 2020 at 9:04 AM
    StevenP
    Steven
    Alta, Ca
    Forgot to update, apologies.
    I bought a nice pipe wrench (Milwaukee) and got it taken care of. Just put the pipe wrench on the outermost part of the inner tie rod so that it’s’ handle was resting on the sway bar bracket and was able to crank the outer tie rod off. It was a tough turn all the way out, pretty rusty through the entirety of the threads, but the inner tie rod is still really firm with no play so that was good news!
  7. Jun 6, 2020 at 8:12 AM
    skeezix
    Colorado
    1998 Limited
    If you are going to reuse the OTR be sure to clean the threads using solvent and a wire brush, and then oil it lightly before reinstalling it.
