outlet in bed question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coop1212, Aug 22, 2011.
  1. Aug 22, 2011 at 6:40 AM
    coop1212
    coop1212 [OP] Well-Known Member
    ms
    2010 TRD 4x4 double cab offroad
    none yet!
    Going camping for week in idaho . I sleep with a cpap machine. It draws about a amp. Will the outlet in the bed run it or do i need another method
  2. Aug 22, 2011 at 7:10 AM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    It should run that without a problem. Are you planning on idling the truck all night though?
  3. Aug 22, 2011 at 7:35 AM
    chacotaco
    chacotaco Well-Known Member
    Travis
    Lawrence KS
    2011 SSM TRD SPORT DCLB
    Black Snugtop XtraVision Sleep Deck.
    Get a marine deep cycle battery and use an inverter. Test it at home. This way you know of you can get through the night(s).
  4. Aug 22, 2011 at 7:59 AM
    joes06tacoma
    Joe
    Central Coast, CA
    The outlet will run it, but the amp draw on the truck battery is going to be more like 10 amps at 12volts. You'll kill the battery for sure. And you don't want to sleep in the bed with the truck idleing. The CO from the exhaust will get in.
  5. Aug 22, 2011 at 8:43 AM
    coop1212
    ms
    none yet!
    No, didn't want to leave it running. Problay go the inverter route
