output battery
Discussion in 'Audio & Video' started by pinktaco808, May 17, 2011.
  1. May 17, 2011 at 10:43 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    how do you find out how much output a battery can do to power amps watts???
    Let say i have a optima yellow top 35 running to a 2500 watt amp.
    How do you figure if you have to run another battery or a bigger alternator?
  2. May 18, 2011 at 6:03 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    What amp?
    What sub?
    What impedance is the sub wired at?
    And you may consider proofreading your next post.
  3. May 18, 2011 at 6:29 AM
    pinktaco808
    sundown SAZ-2500D
    2 dd 12 3500 Series
    sub wired paralllel to 1 ohm
    I was just using this as a example to figure out the wattage for the battery.
  4. May 18, 2011 at 11:19 AM
    ItalynStylion
    Steven
    DFW, Tx.
    2500/12=208amps (and that's at 100% efficiency which is not reality)
    Go buy a new alternator.
  5. May 18, 2011 at 11:35 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    You will need a new alternator with that setup. Why 2,500 watts? seems a little overkill especially in a regular cab.
    I have a 10" sub running 175watts RMS to it in my double cab and there is a plenty of bass.
    With today's speaker and amp technology you don't really need a lot of power to get good sound.
  6. May 18, 2011 at 9:34 PM
    pinktaco808
    what about the output of the battery?
  7. May 19, 2011 at 5:53 AM
    ItalynStylion
    Steven
    DFW, Tx.
  8. May 19, 2011 at 6:40 AM
    pinktaco808
    it doesnt matter if i have a bigger battery? i have a 1400 kintek that why
  9. May 19, 2011 at 7:04 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
  10. May 19, 2011 at 7:11 AM
    ItalynStylion
    Steven
    DFW, Tx.
  11. May 19, 2011 at 10:25 PM
    pinktaco808
    that mean it can power a 1400 watt system??? what about a diehard platinum battery
  12. May 20, 2011 at 5:17 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Unless you are talking about sitting and bumping for hours with the engine off in a parking lot, you are asking the wrong questions.
    1400 Watt rating from almost every amp OEM implies draw at 14V (or maybe 14.4V depending). That equates to an Ampere draw of 100.
    Almost all batteries can do this, pretty reliably too. Consider: Starter motors can draw well over 75 amps. Batteries deliver less current in cold conditions. Paradoxically, it requires more amps to turn over an engine in cold weather (thicker oil, etc). A big-block engine start up in January, in Chicago, would certainly exceed a 100A amplifier draw at the temps in your location.
    What you need to ask is can your alternator deliver enough juice to stay up with the current draw. In which case your best bet would be to pick up the trailer package alternator, which IIRC, supports 130 amps. Or pay an auto electrical shop to rewind the alternator - the trade-off there is they put out less amps at idle, no such thing as a free lunch.
  13. May 20, 2011 at 6:19 AM
    ItalynStylion
    Steven
    DFW, Tx.
    ^I doubt he's getting 14v. Especially over a long period of time. You also have to remember that a good bit of the output is dedicated to running the vehicle, lights and stuff.
    Regardless, the battery is the thing that makes the least amount of difference in the charging system. It's the holding tank, not the source. ;)
  14. May 20, 2011 at 6:38 AM
    pinktaco808
    Ok thankyou very much. I dont really know about sound system that why and was wondering.
