outside air and smells getting into the cab.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Gadget, Jun 11, 2015.
  1. Feb 11, 2021 at 2:20 PM
    #41
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No, other than putting a plastic bag on your head. Not a good option either. :)
  2. Jun 26, 2021 at 5:30 PM
    #42
    enriquelfd
    enriquelfd New Member
    Enrique
    tacoma
    none
    I been reading all, I understand that the cabin is not completely sealed but, in reference I have a problem a very strong smell of exhaust comes in to the cabin only when i turn on the heater, but this only happens when I turn on the heater, unlike when i turn on the a/c. no smell nothing. where do y'all thing is the problem??
  3. Jun 26, 2021 at 5:42 PM
    #43
    Jimmyh
    SC
    2012 Prerunner SR5
    If it is coming in with the heater it is likewise coming in with the A/C, the air comes in the same location for both A/C and Heat. I am assuming you are in RECIRC Mode when using heat and A/C.
  4. Jun 26, 2021 at 5:45 PM
    #44
    enriquelfd
    Enrique
    tacoma
    none
    the smell drops down if i do not recycle, it gets worse if i recycle, but if I turn the A/C no smell in difference if I recycle or not :goingcrazy:
  5. Jun 26, 2021 at 6:47 PM
    #45
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    You shouldn't smell exhaust and have an exhaust leak somewhere. Carbon monoxide is nothing to screw around with so take it to a mechanic that has an emissions check wand. They can pass it the length of your exhaust and find the leak.
  6. Jun 26, 2021 at 8:09 PM
    #46
    enriquelfd
    Enrique
    tacoma
    none
    I guess. thank you..I'll head out to do just that. need it to renew the entire exhaust piping..
