Outside Air Temp / Compass Display Fix
Discussion in 'New Members' started by jbuder, Sep 21, 2011.
  1. Sep 21, 2011 at 9:58 AM
    jbuder
    jbuder [OP] New Member
    Jamie
    Ontario, Canada
    Tacoma SR5 TRD
    The overhead outside air temp/compass display on my 07 TRD suddenly went dead. I read about a fix from another member and tried it. It involved removing the overhead console and resoldering both ends of the two '510' resistors on the pc board. The instructions were 'bang on'! It works again. The total time it took was about 20 minutes. His estimated cost for solder at 10 cents was somewhat high. I estimate I used about one cent's worth!:) This little fix probably saved me a few hundred dollars.
  2. Sep 21, 2011 at 10:03 AM
    jammdogg
    jammdogg Well-Known Member
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    6" ProComp lift on 35 MT's. ARB Bumper.
    SWEET! Saved you some big bucks as opposed to buying from the dealership.
    Welcome to TW. Now you can spend you money on mods!
  3. Sep 21, 2011 at 2:05 PM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    Welcome to TW! :wave:
  4. Sep 21, 2011 at 2:07 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV. [​IMG]
  5. Sep 21, 2011 at 2:09 PM
    tALOHAma
    tALOHAma Well-Known Member
    Oakland, Ca
    07 4X4
    Anytime fog mod, debadged, drop in k&n, smoked taillights, led inside and out,
    That quick fix is what got me to join TW. Now I'm obsessed with modding my truck! Its a mixed blessing I suppose
  6. Sep 21, 2011 at 6:42 PM
    jbuder
    Jamie
    Ontario, Canada
    Tacoma SR5 TRD
    You won't believe this! After I did this fix, I called our local Toyota dealer to get a quote on fixing this problem to see how much money I saved. As usual, the answer was, it can't be repaired - it will have to be replaced. Hold onto your hat: 1 1/2 hrs of labour ($140) PLUS a whole new overhead console at $1,750.00 !!!!!!!! Apparently they are not able to order console replacement parts.
  7. Oct 14, 2011 at 9:20 AM
    TXFF41587
    TXFF41587 Well-Known Member
    Tucker
    Santa Fe, TX
    07 TRD Prerunner
    can you send me the link to this tread?
  8. Oct 14, 2011 at 9:37 AM
    TXFF41587
    Tucker
    Santa Fe, TX
    07 TRD Prerunner
    found it
  9. Oct 15, 2011 at 5:41 AM
    jbuder
    Jamie
    Ontario, Canada
    Tacoma SR5 TRD
    Great! Have you tried it yet? If so, did it work?
  10. Oct 18, 2011 at 5:30 AM
    benlorenzo
    benlorenzo Member
    wv
    LongBed TRD Sport
    Carpeted ARE Topper with BedRug
    The soldering fix worked for me too.. thanks a bunch!!!
