Outside air temp sensor location for thermometer
Discussion in 'Technical Chat' started by Popster, Mar 7, 2013.
  1. Mar 7, 2013 at 10:18 PM
    Popster
    Popster [OP] Member
    Southern Maryland
    Standard Tacoma
    Wipers, Cruise
    I want to add an inside/outside thermometer to my 07 standard Tacoma. I purchased a battery powered in/out thermometer and ran the outside sensor under the front fender and mounted it on the bracket for the front wheel well liner. It is behind the bumper, but close to the supporting bracket.
    When I stop at a light, the engine heat raises the displayed temperature.
    Does anyone know where the sensor should be located.
    I will have to splice the wire if it needs to go any further. I'm guessing that a careful splice will be possible- that is to say that the length of the wire should not affect to reading.
    Any help will be appreciated.
  2. Mar 8, 2013 at 3:17 AM
    Tacoma Mike
    Southern Maine
    Factory location is in the center support in front of the condenser/rad.
    Factory units have a buffer/delay because of this issue. Your unit is instant and will reflect the temp spikes.
  3. Mar 8, 2013 at 3:31 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I ran the temp sensor for my Gentex341 auto dimming/compass/temp/homelink/maplight rr view mirror to the center support of the radiator right behind the bumper skin/license plate. It is out of the direct wind flow but not close enough to the radiator/condensor to get any temp spike action when stopped.
  4. Mar 8, 2013 at 4:31 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    does it have a/c ?
    if so, scangauge should be able to fetch outside air temp
    otherwise temp is picked up at foglight level in the open
    part of the bumper near the plate
  5. Mar 8, 2013 at 3:53 PM
    Popster
    Popster [OP] Member
    Southern Maryland
    Standard Tacoma
    Wipers, Cruise
    Yes, it does have A/C. I emailed scangauge to confirm that it could monitor outside air temp.
    Thanks to all for the help!
  6. May 8, 2013 at 3:29 PM
    grandpapacker
    grandpapacker Member
    Bill
    Chesapeake,Va
    SR5 Club Cab extended bed 4X4 V6
    Added weston running bds.,added chrome Bull Bar,added In-Channel Ventvisors Added outdoor temperature reading device using sensor mounted in grill,installed Tri-Fold Tonneau cover on truck bed
    Just move the your sensor into your front wheel well away from any heat source.You must have it located in the bumper and close to your radiator.\\
  7. May 8, 2013 at 8:53 PM
    Popster
    Popster [OP] Member
    Southern Maryland
    Standard Tacoma
    Wipers, Cruise
    Thanks to all for the the help! I successfully installed a Cipa 36500 mirror with temp and compass. Took about an hour. I put the temp sensor on the bracket in front of the ac condenser. Works fine.
