Outside passenger door handle will not open door
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bajacomo, Dec 27, 2024.
  1. Dec 27, 2024 at 2:42 PM
    Bajacomo
    Bajacomo [OP] Member
    Mario
    1998 Toyota Tacoma limited
    Hi all,
    My '98 tacoma front door handle on the outside has lost it's ability to open the door. It just swings freely in place without that resistance and click of the locking mechanism opening the door. It's not the lock button I'm referring to but the actual silver door handle. I know I'll end up removing the inside door panel and figuring out what broke where, but...this site has been helpful to me in the past on another occasion that I'm hoping someone who has been there can help with any advice, trick or an understanding of what I'm in for and how to solve it. If I can purchase a part beforehand would be good also but I understand that I need to know what is wrong first. So, is there any procedure that is best in removing the cover caps over the inside door arm rest etc etc?
    Thanks
  2. Dec 27, 2024 at 3:02 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I find a set of trim tools handy.
    Bajacomo[OP] likes this.
  3. Dec 27, 2024 at 3:06 PM
    Bajacomo
    Mario
    Like a plasterers tool you mean, to lift off the covers?
  4. Dec 27, 2024 at 8:44 PM
    rnish
    Tacoma 2nd gen
    They make trim tools (sets) specific for automotive trim. Its handy to have the proper tools.
  5. Dec 27, 2024 at 9:37 PM
    Bajacomo
    Mario
    Ok got it, thanks. I've been y tubing it and am learning as I go. Also, I see that this is a common problem with handles that I'm learning about on tacomaworld.....so now I'm down the rabbit hole searching ALL the replacement exterior handles out there for sale and trying to figure out what's crap and what maybe is not for a reasonable price.
  6. Dec 28, 2024 at 2:27 AM
    Chadley22
    Chadley22 Well-Known Member
    Chad
    Tacoma
    Check the reviews, the one I installed on the driver side of my truck is finicky. It worked perfectly for about 6 months, but now I have to grab the handle a certain way, or it won’t open.
    I mean, if my hands are full and I try to open it with 2 fingers, or along the edge, it doesn’t work.
    Strange to me, because it still travels normally, just doesn’t unlatch the door.
  7. Dec 28, 2024 at 8:11 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
  8. Dec 28, 2024 at 8:29 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Another weak point on these.......they all eventually break
    Oem ones not much better than aftermarket ones and three times cost.
    Some smear by the metal ones.......but heard of them breaking too....bad reviews
    Amazon.com: Exterior Front Driver & Passenger Door Handle Set, Upgraded Metal, Compatible with 1995-2004 Toyota Tacoma - Textured Black - 69220-35020, 69210-35020, 79345, 91318, 79344, 91319, TO1311117, TO1310117 : Automotive
    when I buy any thing on Amazon I check for open box dorman ones of these that for go $7 or $8
    about half the time they're there....got a spare for each door..
    I got an oem one from Orisman(McGeorge) few years back.... and it was not smooth....crunchy feeling
    Chadley22 likes this.
  9. Jan 15, 2025 at 7:20 AM
    Chadley22
    Chad
    Tacoma
    Great idea on the open box OEM handles.
    Thank you!!
  10. Jan 15, 2025 at 7:50 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Harbor freight sells a pretty decent set for peanut money. You can also pick up their fastener set for around $10 that may have some to replace those you WILL break. If not, on line is way cheaper then dealer pricing.
  11. Jan 15, 2025 at 10:16 AM
    shankyjones
    shankyjones Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    SilverTaco speaks the truth. Also, I learned from a fb Taco guy that using white synthetic grease to lube up all moving parts makes the handles last longer.
    I spray it around the outside door handle (in-between the cracks) ever so often.
  12. Jan 15, 2025 at 11:57 AM
    O'Silver_Taco
    MD
    I'd recommend keeping a spare driver one around.
    also a backup open circuit relay.......and a spare ignition switch....
