outside temperature display wrong - always +4 degrees
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stinky, Jul 29, 2016.
  1. Jul 29, 2016 at 1:24 PM
    Stinky
    Stinky [OP] Member
    2016 Black Tacoma Limited 2X4
    My outside temperature display in the dash is always ~4 degrees off. It reads too hot pretty much always compared to my phone app. I trust the phone app because I have two that are always the same.
    Anyone else see this?
  2. Jul 29, 2016 at 1:30 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Where is your phone app recording it's temperature from? If it's a weather app It's probably getting the info from a local weather station which may not be the exact temp of your truck's location.
    I'm not sure where the temp sensor on the truck is to get it's temperature but it's possible to see a difference based on source. Best bet is to get a digital temp sensor and compare readings around the truck.
    0311K1LL and 0uTkAsT like this.
  3. Jul 29, 2016 at 1:36 PM
    Stinky
    Stinky [OP] Member
    Yeah, I'll do some more comparisons but I watch the local weather forecasts and pretty much know within a few degrees what it should be. Like right now weather.com says 87 and I'm leaving work now and I bet when I get in it will read 92.
  4. Jul 29, 2016 at 1:38 PM
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    This ^^^
  5. Jul 29, 2016 at 1:39 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Weather.com is pulling temp data from a nearby weather station under more controlled conditions. Your truck is likely sitting on hot pavement that is conducting that heat to the air you're driving through pulling the temp up. They're probably both right.
    I say screw the app and weather station data. Your truck is telling you the temp right where you are which is going to be more accurate.
    Also since I'm here I'm going to plug wunderground.com, far superior weather site that doesn't pummel you with constant ads and BS clickbait articles.
    MadDaddy likes this.
  6. Jul 29, 2016 at 1:39 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
  7. Jul 29, 2016 at 1:41 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I trust my phone because the other phone reads the same thing
    LOL
    can't make this up
    protip, there is no temp sensor in your phone, other than
    for the CPU/battery to shut down before it melts down
    niko5055, Caprizzy and Aussiek2000 like this.
  8. Jul 29, 2016 at 1:46 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Silver trucks are only reading 1 degree too hot.
    Catfish21 and growyourmind86 like this.
  9. Jul 29, 2016 at 1:46 PM
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    I have the same problem OP. Whenever I drive by a bank or somewhere else that has the temperature on their sign my truck always shows about 10 degrees higher.
    JoeyDel likes this.
  10. Jul 29, 2016 at 1:49 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Hell I have a 4 degree temp difference from front to back yards at my house depending on the shade.
    MadDaddy and Aussiek2000 like this.
  11. Jul 29, 2016 at 1:58 PM
    andrew61987
    Stop comparing the truck reading to other devices. Compare it to itself at different times only.
  12. Jul 29, 2016 at 2:00 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    read the manual
  13. Jul 29, 2016 at 2:39 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    that's unacceptable, I would get corporate involved.
    MadDaddy and t4daddy like this.
  14. Jul 29, 2016 at 2:52 PM
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
    Some times after my truck has been sitting all day and I start it up it will be like 80 degrees and then I start driving and it drops way down I think I have a lemon as well. Some times its sunny in my back yard and raining in the front.
    :eek::eek:
  15. Jul 29, 2016 at 2:57 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You can cross the street and get a difference of 5 degrees in actual temperature. Nothing to worry about.
  16. Jul 29, 2016 at 3:06 PM
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    All joking aside its designed to be a reference not an absolute. All temps/thermometers will vary depending on location you could have two identical vehicles sitting right next to each other and have to different readings.
  17. Jul 29, 2016 at 3:52 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    It's a characteristic of the truck, nothing wrong.
    Blazingbluesport likes this.
  18. Jul 29, 2016 at 3:55 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Who cares? Does this 4* cause you distress?
  19. Jul 29, 2016 at 4:20 PM
    Markc1024
    Markc1024 Well-Known Member
    I've found my white truck to be spot on.
    Abrams65 and Gus Gorilla like this.
  20. Jul 29, 2016 at 4:25 PM
    swimmer
    Tucson
    2016 TRDORAC4WD
    That's racist
