outside temperature display wrong - always +4 degrees
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stinky, Jul 29, 2016.
  1. Jul 29, 2016 at 4:27 PM
    Gus Gorilla
    Gus Gorilla Well-Known Member
    2016 White TRD OffRoad
    None...yet
    Scientific weather stations collect in very specific shade and no wind conditions. You, my Tacoma driving friend, are almost certainly in the sun over hot asphalt in traffic with 100 other asshats running engines hot enough to cook off of. Given modern electronics, I'd wager it's pretty damned close if not exact.
    Also, they use an algorithm as to how the temp updates. For example FoMoCo uses a system that'll almost immediately decrease a temp but needs several minutes sustained to raise a temp even 1 degree. (Think stoplight vs flowing air). Without this you'd jump 15degrees at every stoplight and lose 15 once air started flowing again.
    MadDaddy likes this.
  2. Jul 29, 2016 at 4:59 PM
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    Do people really not realize weather apps get the temperature from miles away? Do they realize miles make a difference?
  3. Jul 29, 2016 at 5:00 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    +1. I watched the temperature swing 20* within 10 miles on the interstate this afternoon
  4. Jul 29, 2016 at 5:02 PM
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
    This is an awesome thread:popcorn:
    :worthless:
    Aussiek2000 likes this.
  5. Jul 29, 2016 at 5:07 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    I think one more does now.... ;)
    JoeyDel[QUOTED] likes this.
  6. Jul 29, 2016 at 5:55 PM
    Stinky
    Stinky [OP] Member
    2016 Black Tacoma Limited 2X4
    Okay. Thanks.
  7. Jul 29, 2016 at 6:05 PM
    bongwhisperer
    bongwhisperer Well-Known Member
    horn that plays "la cuka racha,"
    I was reading a problem about thermometers in cars/trucks and the problems they have been experiencing. It's due to:
    https://youtu.be/IvmeUStFvz8
    Caprizzy and MadDaddy like this.
  8. Jul 29, 2016 at 6:07 PM
    cdntac
    cdntac Well-Known Member
    Ontario
    2016 Barcelona Red DCSB MT 4x4 w/Sport Upgrade
    Wait a sec...you're trying to tell me that two different phones using two different apps (yet which get their data from the same meteorlogical source from a location that is very likely miles away and providing a reading from an hour or more previously) is giving a different temperature than where your truck actually is at that exact moment?
    How can this be? The Internet is never wrong.
  9. Jul 29, 2016 at 6:30 PM
    Abrams65
    Abrams65 Well-Known Member
    Cliff
    Idaho transplant in WV
    16 Tundra Crewmax SR5 OR/15 Corolla S
    Oh hell lets just compare the temp. registered by the truck with a weather station that 5-10 miles from where you are. You know as a tech. I hate to here crap like that "well that's not what my app says it is" My answer to that is. Is the app measuring the temperature at the truck NO. So how can you say its not right. It's 4* get over it.
  10. Jul 29, 2016 at 6:35 PM
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    I'd dump the truck, that is unacceptable.
  11. Jul 30, 2016 at 2:54 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Never thought about that but it makes perfect sense. If the truck was reading the temp in real time it would be jumping all over the place and look like it's malfunctioning when in fact it's working perfectly.
    Thanks!
  12. Jul 30, 2016 at 11:04 AM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    OMG. Things must be getting better if all we have to bitch about is the temp indicator in the truck being 4 degree higher. Does anybody read their owners manual?! "The correct or outside temperature may not be accurately displayed when stopped or operating at less than 12 MPG, because of location of temperature sensor actual temperature may be +|- 5 degrees than ambient air temperature".
  13. Jul 30, 2016 at 12:02 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    all bs aside
    in conditions where I do know my outside temp... and also there is
    no heat coming off the road interfering or otherwise (gray day...stuff like that)
    ....my tacoma and yaris -and- 4runner have always
    been within 1 degree of true temp measured with a temperature probe
    but from road heat, sun, shade, cold or hot random breeze, they can be 4 degrees off. way more if parked.
    it is far more accurate near and below freezing than on warm
    or hot days 70deg and higher
  14. Jul 30, 2016 at 8:38 PM
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    It was 90 to day and my truck said 92. HELP
    Abrams65 likes this.
  15. Jul 30, 2016 at 8:58 PM
    #35
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Check with another vehicle owner, even a different make and model, in the same location as you. Practically every car in the past 5 years has an outside temperature gauge.
  16. Dec 14, 2017 at 7:53 AM
    #36
    baritone
    baritone New Member
    john
    tdr 4x4 extra cab
    I have a 2017. I have noticed frequently that the temp gauge is too high for the current temperature outside, noticeably. I have also noticed that when beginning to drive the truck, when cranking it, it reads the last temperature before the truck was turned off, then it will adjust down or up 2 degrees every 40 seconds to a minute. When the temperature drops dramatically, I want to know if it is below freezing, many times I am 4-5 miles into my trip before I get what appears to be an "accurate(ish)" read on the temp. This, like many of the little standard, non-running gear options on the truck, seems to be poorly thought out by the tech designers; a little disappointing for the price I paid. Like, why does the radio go off before I open the door after turning off the engine, why does it beep insanely when I get out with the truck open, telling me that the door is ajar; of course it is, I'm getting out, etc.
  17. Dec 14, 2017 at 7:55 AM
    #37
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    Pro tip to all reading this thread: the dealer can adjust the temperature shown on the display if you know how inaccurate it is. They can input a correction factor of a few degrees in either direction using Techstream.
  18. Dec 14, 2017 at 8:22 AM
    #38
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Vehicle sensors are not at specified 5' off ground and you are probably sitting over pavement. My Tacomas always read high in day time until I moved. I checked accuracy as I passed bank gauges and mine were always close. I don't normally look at Tindra gauge before I move but it is very close when driving.
  19. Dec 14, 2017 at 8:26 AM
    #39
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    But who would want it with such a lousy thermometer?
  20. Dec 14, 2017 at 8:31 AM
    #40
    Big_Roach011
    Big_Roach011 Well-Known Member
    J
    Dallas Texas
    2017 Quicksand Tacoma TRD OR
    Diamondback HD cover ; weathertech ; Carhartt seat covers, ride rite bags, RTT , general X3's, fab fours rear bumper
    if you want accurate weather data go to national weather service directly. Everyone gets their info from NWS and adds their spin to it. BUT YOU MUCH UNDERSTAND HOW THE MEASUREMENTS ARE TAKEN. that part is critical.
