Outside temperature indicator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lakewoodbilly, Aug 28, 2008.
  1. Aug 28, 2008 at 6:46 PM
    lakewoodbilly
    lakewoodbilly [OP] Well-Known Member
    Bill
    Lakewood, CO
    White 08 DC V6 SR5 4WD TRD Sport
    Factory DRL's, Underhood Flood LED's, Underbody Multi-color LEDS, Red Line Tuning Elite Hood Struts, Anytime Fog Lights, PIAA 4100 Intense White, Luminics JDM Yellow H10 Fog Lights, OBX Sport Pedals, Sill Protectors, Bed Net, Front Bed Tie Downs, iPod and Aux Factory HU Interface, Sirius Sportster 5, Satellite Antenna through third brake light
    I was curious about where the outside temperature sensor is located on my '08 double cab.
    Does anyone know where this is located?
    The temperature that shows on the overhead console seems to be very inaccurate; even as much as 10 or more degrees off.
    My '03 Corolla has this same feature (shows up in the dash by the odometer); it has been amazingly accurate.
    I think this is a great feature on a vehicle as you are able to judge when you are starting to get down to the freezing point outside - meaning that the roads could be getting slippery around the 28-32 degree range depending on precipitation, fog, etc.
  2. Aug 28, 2008 at 6:53 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    i think its in the corner of your winshield on the inside.
  3. Aug 28, 2008 at 7:04 PM
    lakewoodbilly
    Bill
    Lakewood, CO
    should be on the outside of the vehicle since it is for the outside temperature.
  4. Aug 28, 2008 at 7:05 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    well i tried.
  5. Aug 29, 2008 at 4:27 AM
    CanTac
    CanTac Well-Known Member
    Peterborough On./Ocala Fl.
    09 TRD Sport 4X4 D/Cab Long Box
    Would be kinda nice to know where it is, don't ya think?
    CanTac
    Hal
  6. Aug 29, 2008 at 4:51 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    13 TRD OR DC MGM
    Stock for now
    Verticle Radiator support behind the grill.
  7. Aug 29, 2008 at 4:54 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    None!
    I thought I read somewhere that the sensor was in the front near the grill but I could be wrong. :confused:
  8. Aug 29, 2008 at 4:50 PM
    lakewoodbilly
    Bill
    Lakewood, CO
    found it. It is on the vertical support for the hood latch in front of the radiator. Seems like the heat from the radiator would affect this? Not sure why they put it there. I'll look for it on my corolla to see where it is located there now that I have a rough idea of what it looks like.
  9. Aug 29, 2008 at 4:53 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Mine seems to be fairly accurate.
  10. Aug 29, 2008 at 4:58 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    Mine's pretty damn accurate. Only time it is not accurate is on start-up when my truck has been sitting in the sun for any extended period of time, but as soon as you start moving it falls to a more accurate reading.
  11. Aug 29, 2008 at 8:46 PM
    ERdept
    ERdept Well-Known Member
    Agree totally.
  12. Aug 29, 2008 at 8:51 PM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    08, Double cab, 4WD, Off Road, Tow,
    +2 same here, mine works exactly the same way.
  13. Aug 30, 2008 at 6:09 AM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    How hard is this to have installed if you dont have one? I am really going to miss having the outside temperature readings
  14. Aug 30, 2008 at 6:16 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    While I also agree w/this. Has happend once after a few mins,mine went from 112-116. :eek: Yep,It's hot here. :D
  15. Aug 30, 2008 at 9:44 AM
    Wolfpack
    Wolfpack Well-Known Member
    Las Vegas
    08 Prerunner
    Mine is always off 5-10 degrees. It is worthless.
    I miss my '04 F-150 more everyday that I drive this "truck". :(
  16. Aug 30, 2008 at 2:28 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Mine's usually within a couple degrees of bank or other outdoor displays. I always take it with a grain of salt since the one at my house fluctuates with sun/shade a bit, and the weather channel is never that accurate either. :laugh: I use it to ball park freezing temps mostly.
  17. Aug 31, 2008 at 12:50 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    We get that you don't like your Tacoma and miss your Ford. Let it go.
    -Dan
  18. Aug 31, 2008 at 7:58 PM
    mainerinexile
    mainerinexile Well-Known Member
    central Maine
    2014 SR5 Access cab I4 4x4 5 spd
    You won't get much sympathy around here. Read Consumer Reports. Maybe you had the only good F150, but you don't need to drag us down.
  19. Aug 31, 2008 at 8:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You obviously never had to work on your Ford.
  20. Aug 31, 2008 at 8:09 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    Amen.
    Meh. My Family has had several Ford trucks and all of them have been completely problem free, even with my Dad beating the hell out of them. I know people with F150s that are pushing 200K and still run well. It all depends on how you maintain 'em, just like any other vehicle.
